Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
I personally don't like this set up. The hex pattern is plug into Diffuse node which means it will be affected by the lights and shadows in the scene. I would composite all my images together in Photoshop and then plug that image into the Alternate diffuse and transparency nodes. I would also add a blender node between the texture and transparency nodes to aid fine tuning of the texture's transparency.
You'll need to use your own stash of tech-type graphics.
The shader set-up is here:
HUD FX Poser 7 shader by ~ibr-remote on deviant[ART
I](http://www.deviantart.com) applied the shader to the Poser default Hi-res Square.
Eternal Hobbyist
