Wed, Jan 1, 4:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 01 3:25 am)
Subject: Thrifty Person's HUD FX shader for Poser 7
infinity10 ( ) posted Sun, 31 May 2009 at 3:38 AM · edited Wed, 01 January 2025 at 4:11 AM
Maybe it's cheap and nasty, but it can work...
You'll need to use your own stash of tech-type graphics.
The shader set-up is here:
HUD FX Poser 7 shader by ~ibr-remote on deviant[ART
I](http://www.deviantart.com) applied the shader to the Poser default Hi-res Square.
Eternal Hobbyist
infinity10 ( ) posted Sun, 31 May 2009 at 5:00 AM
 Notional application example
Eternal Hobbyist
pitklad ( ) posted Sun, 31 May 2009 at 5:21 AM
interesting effect!
My FreeStuff
befanini ( ) posted Sun, 31 May 2009 at 7:43 AM
Those are awesome ^_^
Not to mention cheeky! "Thrifty Person" - I like that! ;D
chriscox ( ) posted Sun, 31 May 2009 at 11:17 AM · edited Sun, 31 May 2009 at 11:18 AM
I personally don't like this set up.  The hex pattern is plug into Diffuse node which means it will be affected by the lights and shadows in the scene.   I would composite all my images together in Photoshop and then plug that image into the Alternate diffuse and transparency nodes.  I would also add a blender node between the texture and transparency nodes to aid fine tuning of the texture's transparency.
Chris Cox
hborre ( ) posted Sun, 31 May 2009 at 1:41 PM
I agree with you chriscox; the shader arrangement does look odd.  Your solution seems much more logical.
infinity10 ( ) posted Sun, 31 May 2009 at 7:25 PM
I understand your version, chriscox. That would have been the alternative - using an external graphics editor. I was trying to avoid that. But yes, the alternate diffuse node can also be used on its own for the HUD effect.
Eternal Hobbyist
infinity10 ( ) posted Mon, 01 June 2009 at 12:52 AM
 Re: notional Application example -
credit for the cylinder is D3D, not DDU.
Apologies.
Eternal Hobbyist
