Thu, Dec 12, 10:41 AM CST
Forum Moderators: Staff
Subject: replace body part with prop, do goals have to be redone?
MistyLaraCarrara ( ) posted Thu, 04 June 2009 at 2:11 PM · edited Thu, 12 December 2024 at 10:34 AM
I swapped Simon's left foot with a boot using the replace body part command.  Now, when I move his foot, the toes stay. (looks like he stepped in gum.)
When I look at the goals for his right foot, the goal is the foot, not the toes.
And there is a bunch of toes parts, if it is a goal issue, which toe?
or, do I need to divide the boot into a foot and toe group and then swap the toe with the boot toe?
Poser gave me a message about turning off bends to make the new 'foot' act properly, but when I turn bends off, the boot doesn't bend when I bend the foot, the upper part of the boot comes off his shin.
it's not actually a boot, I sized James's grey sock to Simon.
PhilC ( ) posted Thu, 04 June 2009 at 2:57 PM
If you replace two adjacent body parts with props they will become unwelded at the seam.
The way I would do this would be by editing the geometry declaration in the CR2 file.
In place of:-
actor rFoot:1
storageOffset 0 0 0
geomHandlerGeom 13 rFoot
You put:-
actor rFoot:1
storeageOffset 0 0 0
objFileGeom 0 0 :Runtime:Geometries:Your Directory:Your File.obj
Then just set the original toe invisible.
Other methods are available, parenting, conforming but if it were me I'd try this.... "just because" :)
MistyLaraCarrara ( ) posted Thu, 04 June 2009 at 3:07 PM
I'll give it a try.  Thanks!
MistyLaraCarrara ( ) posted Fri, 05 June 2009 at 8:43 AM
This is what the gooey toe looks like.
