Sat, Jan 11, 6:23 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Subject: Developer Issue with Textures for CR2s
3-d-c ( ) posted Wed, 19 August 2009 at 8:34 AM · edited Tue, 07 January 2025 at 8:10 AM
Hi all
i am usually creating poser content, but have an issue whenever i want to load one of my figures into DAZ...
The props all work ok, but the CR2s mess up the textures. I have removed all the Downloads: in the file and they all purely point to runtime:textures ... etc. the files are there but none of the CR2s load any textures in DAZ3. the Props work all fine.
Any idea? I guess i will stop supporting DAZ at all as its so combersome to work around it. Poser is all fine and easy...
Thanks for your input !
3-D-Cs Facebook Page: 3-D-C on Facebook
Check the K-Azonica Story and World Evolving:   K-Azonica
Check my website and products and the large freebie section:   3-D-C
mishamcm ( ) posted Wed, 19 August 2009 at 8:58 AM
That's very strange -- I've never had that problem loading a .cr2.  Do you have the runtime listed under Edit>Preferences>Directories with the pull-down set to "Poser format content folders"?  What version of Poser was the .cr2 created in, and did you have "Binary Morph Targets" turned off?
3-d-c ( ) posted Wed, 19 August 2009 at 9:07 AM
Thanks for your answer ... there are not morphs in it. Its Poser 7 content but only one bone, so very simple. The directories are added as usual and as said, loading a prop using the same texture path works fine.... there are also no spaces in the name or material name ...
Pret-a-3D ( ) posted Wed, 19 August 2009 at 9:21 AM
That's a common problem, it seems that in some cases Poser doesn't store the path correctly. It should be ":Runtime:textures:rest_of_thepath_here". Note the colon at the beginning.
Poser seems to be a bit sloppy and work with it but the path is basically incomplete without the colon at the beginning.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
mishamcm ( ) posted Wed, 19 August 2009 at 9:22 AM
And is the runtime containing the texture listed in "Poser format content folders" under Edit>Preferences>Directories?
3-d-c ( ) posted Wed, 19 August 2009 at 9:34 AM
hm. no. i tested the path again, its is complete
:runtime:textures:3dc:.... etc. the same path works fine for a prop using the same path.
Thats so odd, but happens to all my figures, that i created....
Pret-a-3D ( ) posted Wed, 19 August 2009 at 9:43 AM
3-d-c ( ) posted Wed, 19 August 2009 at 9:46 AM
Hi PretA3D, whats your email add? I will send you the CR2 and the Textures...
Pret-a-3D ( ) posted Wed, 19 August 2009 at 9:51 AM
3anson ( ) posted Wed, 19 August 2009 at 3:30 PM
just in case, Studio cannot read or 'see'  .mc6 files
lisarichie ( ) posted Thu, 20 August 2009 at 7:13 AM · edited Thu, 20 August 2009 at 7:16 AM
Does the texture load correctly when the CR2 is opened in Poser?
If so check the DS3  log file for errors pertaining to any actors in the CR2.
Quite often a morph or actor related error will cause DS to drop the texture loading section of the CR2 even though it loads in Poser.
As an example I have had a missing bracket after editing a CR2 cause this to happen.
Also check the CR2 in DS2 if possible to further determine if the error is general to DS or is only DS3 related.
3-d-c ( ) posted Thu, 20 August 2009 at 7:46 AM
Hi lisarichie.
i guess it must be something like this. It loads all fine in Poser.
Well i will try the transfer of the Mat files into the DS files and see if this helps.... elsewise i forget about DAZ support. ...
cheers!
lisarichie ( ) posted Thu, 20 August 2009 at 2:35 PM
Transferring the mats to DS format and applying them after loading the model will work (as should PZ2 MATS) since the textures would be loaded separately from the CR2 in both cases.
However, if you want the CR2 to load correctly and automatically apply the textures then you'll need to discover and correct the problem in the CR2.
3-d-c ( ) posted Sun, 11 October 2009 at 10:23 PM
HI There.
Wanna let you know, that i finally found the problem. Simple, but i have no idea Why DAZ Does that: The issue always only appears when a figure was loaded, however, not on all figures. So i began comparing the CR2 files line by line.
The problem is, Poser some writes the core of a figure as BODY, sometimes as BODY:2 or so, depending if you have more than one in your scene. My figures with a ":x" at the end all worked ok in DAZ, so i replaced all the BODY entries in the CR2 with BODY:1 and BOOOM it works in DAZ.
So whyever, if you use BODY:1 instead of BODY in your CR2, the textures load fine.
Just to let you know, this was really annoying...
theschell ( ) posted Fri, 16 October 2009 at 8:59 PM
I'm guessing that it's a DS3 issue... i work in Daz 2.5 and have never encountered a prob like that... and i use it to create poser content models... odd... hmmmmmmmmm... i've even looked over some of my cr2's for freebie items and stuff and i've seen body 2 intsead of body 1 or just body... never had a prob loading a cr2... but i've been noticing that DS3 has ALOT of issues.. it's all over the forums here and most other places... including Daz's... which is why i haven't changed up to the new version...
