Mon, Feb 3, 8:32 PM CST
Subject: Need Help with transparency in material room
CStrauss ( ) posted Mon, 22 February 2010 at 12:50 AM · edited Mon, 03 February 2025 at 6:04 PM
I am trying to make part of this mask prop appear broken so I decided to try to make my own trans map. Now the way I understand it is black is transperent and  white visiable correct?
Well when I load the map and set the value to 1.00000 in the material room and render you can still see part of the mask I want gone :( any ideas of what I did wrong?
HEre is a picture of the render version
LukeA ( ) posted Mon, 22 February 2010 at 12:59 AM · edited Mon, 22 February 2010 at 1:00 AM
Specular needs to be zero or masked off and you can use the same map as the trans map
LukeA
My latest novel
CStrauss ( ) posted Mon, 22 February 2010 at 1:21 AM
not sure what you mean by masked off. I would like to try to keep the specular value if possible but not a deal breaker could you explain a bit more please? thank you.
TetsuTora ( ) posted Mon, 22 February 2010 at 2:09 AM
is the trans edge set to 100% and fall-off set to zero?
hborre ( ) posted Mon, 22 February 2010 at 6:05 AM · edited Mon, 22 February 2010 at 6:05 AM
If you can, provide a screencap of your material setup.
bagginsbill ( ) posted Mon, 22 February 2010 at 6:39 AM
Make sure Transparency_Falloff is 0. Poser transparency can vary with viewing angle and if did not program both transparency and transparency edge identically, you will get variation. Unless you're *trying* to do that, set falloff to 0.
Make sure that you plug your mask into the Specular_Value.
Poser transparency is very flexible and can implement "nothing here" as well as "clear plastic here". The difference is whether or not you allow a specular reflection in the transparent area.
LukeA ( ) posted Mon, 22 February 2010 at 9:05 AM
Yeah what he said :)
LukeA
My latest novel
