Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Specular needs to be zero or masked off and you can use the same map as the trans map
LukeA
Make sure that you plug your mask into the Specular_Value.
Poser transparency is very flexible and can implement "nothing here" as well as "clear plastic here". The difference is whether or not you allow a specular reflection in the transparent area.
![file_448505.jpg](https://live.cdn.renderosity.com/forum/threads/2795431/file_448505.jpg)
I am trying to make part of this mask prop appear broken so I decided to try to make my own trans map. Now the way I understand it is black is transperent and white visiable correct?Well when I load the map and set the value to 1.00000 in the material room and render you can still see part of the mask I want gone :( any ideas of what I did wrong?
HEre is a picture of the render version
