Tue, Jan 21, 6:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Antonia - Opinions?
amy_aimei ( ) posted Sun, 02 May 2010 at 9:46 PM
Hi lesbentley,
As you know from the current version of the Beach Volleyball Bottom has 5 JCMs on each side just for kicking; 3 JCMs on each side for spreading.  The question I asked is related to that.  I wonder if I need 15 JCMs on each side just for the "2-ways JCM"!  It is way too many!  Or I just need 5 or even less?
For the new version, I modified the mesh already, I hope I can cut down the number of JCM but still produce the same quality.  I'm working on the spread (zrot) now.  Just one JCM is not fine!
lesbentley ( ) posted Sun, 02 May 2010 at 11:04 PM · edited Sun, 02 May 2010 at 11:17 PM
file_452203.TXT
> Quote - I don't think I've seen this problem with propagatingScale, but I wouldn't swear by it.
Yes, propagatingScale seems to avoid the problem (I was mistaken about that before).
Quote - It may be possible to compute a combination of x-, y- and z- scale values for the thumb that would make it scale consistently with the hand.
That possibility also crossed my mind, though I haven't plucked up the courage to dive in and try it as yet.
Attached above is ERC injection I have so far, in case it is any use to you as a basis for modification. Of course it is meant  to be used with the smoothScale channels removed from the hands and fingers.
lesbentley ( ) posted Mon, 03 May 2010 at 1:04 AM · edited Mon, 03 May 2010 at 1:05 AM
I found that when applying xScale to the hand, changing the slaving code in Thumb1 to the following, made an improvement.
        scaleX xScale
            valueOpDeltaAdd
                Figure
                lHand
                xScale
            deltaAddDelta 0.75000000
            valueOpDeltaAdd
                Figure
                BODY
                One
            deltaAddDelta -0.75000000
lesbentley ( ) posted Mon, 03 May 2010 at 2:21 AM · edited Mon, 03 May 2010 at 2:27 AM
Hi amy_aimei,
Quote - As you know from the current version of the Beach Volleyball Bottom has 5 JCMs on each side just for kicking; 3 JCMs on each side for spreading.  The question I asked is related to that.  I wonder if I need 15 JCMs on each side just for the "2-ways JCM"!  It is way too many!  Or I just need 5 or even less?
When I made my (not very good) JCMs for the kick + spread, to the best of my memory I think I just made one JCM for each leg, that was on top of the JMCs you had already put in there. I don't know if there is any theoretical minimum number you should have. I'm no expert on making JMC morphs. Personally I would hope to get away with no more than two morphs for each movement, one for the positive movement, and one for the negative movement. So, kick, spread, kick+spread, times that by two, that's 6. If you need morphs for twist as well, that's another two, equals 8 per leg. That's what I would aim for, but hope and reality are not the same thing. I guess it takes as many as it takes to get the job done. For the 2-ways kick+spread I think you should be able to get away with one morph for each leg, but I may be wrong.
Did I send you the cr2 I made with the 2-ways kick+spread JCMs? I can't remember now, it seems so long ago.
odf ( ) posted Mon, 03 May 2010 at 4:44 AM
Les, I think I've found the problem with the smooth scaling. As it turns out, the channels were all messed up. There was a smoothScaleZ channel on the hand with otherActor = thumb1 and a smoothScaleY on thumb1 with otherActor = hand. Both should have been smoothScaleX. After I fixed it in the CR2, scaling the hand produced almost usable results. So I think a little bit of tweaking, and we may finally have hands for Antonia that scale properly.
Why the heck did I not figure that out earlier? facepalm
odf ( ) posted Mon, 03 May 2010 at 5:13 AM
Follow-up on the last post: okay, I've tried that "little bit of tweaking", and it's still looking like a major pain in the butt. I think it's mostly the way the thumb and pinky are attached to the hand that Poser can't really deal with that well. At least the results make some kind of sense now, unlike before when it was more like "what the heck is Poser now???"
amy_aimei ( ) posted Mon, 03 May 2010 at 8:31 AM
Yes, you did.  Right! That's long time ago.  It took me about few hours to make a good JCM.  And I put few hours into 3D in a week.  Now, you understand why I'm so concern about how many JCM I need to make.
With you descriptions, I think the 2-ways JCM is independent from the JCM that made for the 2 rotation directions it covers.
lesbentley ( ) posted Mon, 03 May 2010 at 11:51 AM
> Quote - With you descriptions, I think the 2-ways JCM is independent from the JCM that [I] made for the 2 rotation directions it covers.
Yes my JCMs were new independent morphs, not based on your morphs, but used in conjunction with your morphs to make slight adjustments to the shape when the thigh was both kicking and spreading. The new morphs were made to suit Antonia's "LegUp" pose, which has a 90° kick and 45° spread. This seemed like a good point to aim for, as I think a high kick is rarely associated with a spread of more than 45°. Your kick morphs can't quite cope with a 90° kick without some poke-through, and your spread morphs can't quite cope with a 45° spread. If they could, perhaps you would not even need an extra 2-way morph. Your original question was about how to produce such a 2-way morph, so that's what I answered. As to whether you actually need a 2-way morph, I don't know.
With Antonia in the LegUp pose, and your morphs active, I just used magnets to tweak the shape in that pose until the poke-through was eliminated. Then I zeroed the figure before spawning the new morph from the magnets. I would have had great difficulty in producing the morphs for the Beach Bottom from scratch, I'm not very good at producing complicated (for me) morphs like that. Fortunately your morphs were already doing most of the work. My new morph only needed to make small adjustments to the shape your morphs were already producing.
lesbentley ( ) posted Mon, 03 May 2010 at 12:08 PM
I might add that, as you can see from the image, my morph pulls the bottom of the panties down to compensate for where they are disappearing into the buttock in your morph. It also pulls the bottom of the hip strap up and in, to make a better fit where the thigh meets the hip.
Rogerbee1 ( ) posted Mon, 03 May 2010 at 12:47 PM
I got round this ages ago by making the .obj into a dynamic prop.
CHEERS!
lesbentley ( ) posted Mon, 03 May 2010 at 1:10 PM
odf,
Quote - Follow-up on the last post: okay, I've tried that "little bit of tweaking", and it's still looking like a major pain in the butt. I think it's mostly the way the thumb and pinky are attached to the hand that Poser can't really deal with that well. At least the results make some kind of sense now, unlike before when it was more like "what the heck is Poser now???"
Well at least we have options now, ERC, or tweaking the rigging. Unfortunately it seems like neither of the options are producing the type of results we would like to see, yet. The ERC seems to work perfectly for the overall scale, and I have got it working to what I consider an acceptable degree with xScale (hand/finger length), but I'm still in a state of despair over zScale and ySacle. I did try adding some translation of Thumb1 into the mix, and it looked promising for a while, but seemed to come to nothing in the end.
It's interesting to turn Bend Body Parts off (Display menu), when the fingers are being scaled via ERC. The fingers stay close to where they should be, but the thumb breaks apart badly, see image above.
Rogerbee1 ( ) posted Mon, 03 May 2010 at 1:21 PM
Ouch!
CHEERS!
lesbentley ( ) posted Mon, 03 May 2010 at 1:22 PM
Quote - I got round this ages ago by making the .obj into a dynamic prop.
   If I had to do a cloth sim every time I moved a figure, I would not have time to eat, sleep, or go the the pub!
Don.t get me wrong, dynamic clothing can produce some spectacular results, but it's nice to have conforming clothing as well.
Rogerbee1 ( ) posted Mon, 03 May 2010 at 1:25 PM
That's so true, but it gave me something to use while the others were being sorted out.
CHEERS!
SaintFox ( ) posted Mon, 03 May 2010 at 3:32 PM
No, we did not forget about you all. Blame it to the first of May and more cat-babies (now we have six of them) LOL But now we are sober again and I catched up with what happened so far. We will replace the mirrored Antonia with the recent version in some hours and I will let you know when she's ready again.
About the online store: We have a small one for our "outdated" products that where pulled from the Renderosity marketplace and so far we had no problems with charge backs.
Our refund policy is pretty much the same as the one here at Renderosity:
http://www.german-3d.com/market/refund_policy.htm
But for brandnew products I would recommend the marketplace here, the audience you will reach is far, far larger.
If you, on the other hand, plan to release very small add-on's, worth let's say up to five Dollar a private little store can make sense - and you will hardly have to deal with fraudulent purchases as your products are simply not expensive enough.
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
SaintFox ( ) posted Mon, 03 May 2010 at 4:18 PM
Done! Leo has uploaded the recent Antonia to the Freestuff-site (under Base-Figures) and changed the link that held the mirror to point directly to the Freestuff site. This way it's easier to prevent things like having an outdating mirror.
Leo just asked of a "test area" on the freestuff site is useful where things like the eyelid-correction or the hand-finger scale can be uploaded (and deleted as soon as they are part of a new version)?
lesbentley ( ) posted Mon, 03 May 2010 at 4:59 PM
Quote - Leo just asked of a "test area" on the freestuff site is useful where things like the eyelid-correction or the hand-finger scale can be uploaded (and deleted as soon as they are part of a new version)?
Basically that sounds like a very good idea. One thing I think you might have to watch out for though. I think a "test area" could become clogged up with junk that people have uploaded then forgotten to delete, eating up space that could be used more productively. Perhaps the area should have  a warning "Items older than 3 [or 2, or 6, what ever] months may be deleted without warning". Then you could have a periodic clean up, without it coming as an unexpected shock to those who posted stuff there.
SaintFox ( ) posted Mon, 03 May 2010 at 5:50 PM
Good idea, Les!! I'll pass it to Leo as soon as he comes in with his macaroni with olive-tomate sauce 😉 As said we are a bit exhausted as our second cat gave birth to a band of five and it all happened so quickly that we had to care for cutting the cord and such  - now we both need a good portion of carbohydrates :laugh: .
by the way: I am about to finish the first makeup. With the combination of the new blink-morph, sazzyazzca's liner and a mask for the shadow that Leo painted in C4D I have finally something nice that doesn't stretch more than on any other figure. A render will follow as soon as I found the right amount of gloss for the lipstick.
SaintFox ( ) posted Mon, 03 May 2010 at 6:24 PM
That's the first of a little series of Makeups (VSS version) - I think that this looks far better now than what I had before the new blink-morph.
lesbentley ( ) posted Mon, 03 May 2010 at 7:40 PM
SaintFox, that looks really good!
SaintFox ( ) posted Mon, 03 May 2010 at 7:52 PM
I am glad that you like it!  😄 I will add some more styles and upload the whole set once it's finished. So far I have "Topaz", "Smoky Quartz" and "Amethyste",  the one on the previous sample is "Smokey Quartz". This is Amathyste - what else 😉
SaintFox ( ) posted Mon, 03 May 2010 at 7:54 PM
..and here's "Topaz"
lesbentley ( ) posted Mon, 03 May 2010 at 7:54 PM · edited Mon, 03 May 2010 at 7:56 PM
A Walk Cycle for Antonia?
I noticed that there were a pair of shoes for Antonia on the Antonia's Free Stuff site. It got me thinking (not for the first time) that one thing Antonia is lacking is a Walk Cycle. I remember trying to make a walk cycle for one version of the Victoria, without any success. I'm wondering if I am masochistic enough to try it again with Antonia. If anyone has any insights into the arcane world of walk cycles, and the best way to create them, please speak up.
Tashar59 ( ) posted Mon, 03 May 2010 at 8:11 PM
There is a tutorial or was one for making walk cycles for other figures at DAZ. I've made a few but don't have much time for a few days.
lesbentley ( ) posted Mon, 03 May 2010 at 8:14 PM
Thanks for the heads up Tashar59. I'll see if I can find the tutorial at DAZ.
amy_aimei ( ) posted Mon, 03 May 2010 at 8:50 PM
SaintFox, your makeup is really good, so realistic!  I like "Amethyste" the most.
Tashar59 ( ) posted Mon, 03 May 2010 at 8:56 PM · edited Mon, 03 May 2010 at 9:06 PM
Quote - Thanks for the heads up Tashar59. I'll see if I can find the tutorial at DAZ.
It was written using the Girl. I can't remember who but had Girl products. So if you look up the original girl and find walk cyles, you will know who to look up for the tutorial.
It was Cliff Bowman, I remember but I can't seem to get the DAZ search to work to find the tutorial. kind of would like to read it again myself as a refresher.
sazzyazzca ( ) posted Mon, 03 May 2010 at 10:41 PM
Very lovely SaintFox! :D
lesbentley ( ) posted Tue, 04 May 2010 at 1:19 AM · edited Tue, 04 May 2010 at 1:20 AM
Tashar59,
I found the Walk Cycle tutorial!
Tashar59 ( ) posted Tue, 04 May 2010 at 2:18 AM
Thanks.
Rogerbee1 ( ) posted Tue, 04 May 2010 at 5:04 AM
Great work SF can't wait till it's up.
CHEERS!
SaintFox ( ) posted Tue, 04 May 2010 at 1:05 PM
Okay, I am glad about the feedback, in fact I need it as I would (athough I like to wear MakeUp) never paint my face in such a colorful way. So everything beside taupe, gray, sand and maybe a dull violet or anthrazite can not be found in my little box with eyeshadows. With V4 I am used to create such flashy makeups but Antonia is different because she looks more natural.
I will see what I have in some hours and then need some more time to write matposes for both versions (vss and classic) and for the lips only (and I plan to give people a choice if they want real gloss or just some shine).
@sazzyazzca: As I already said: The eyeliner is a big help for me, somehow my attempts did not look so soft and natural!
SaintFox ( ) posted Tue, 04 May 2010 at 8:04 PM · edited Tue, 04 May 2010 at 8:06 PM
And here is the complete set in it's VSS-version with glossy lips. Additional mats with lipstick only (glossy and silky matt)  and the whole collection for the "Classic" material system are the next to-do's. If tomorrow will be as calm as I hope for I should be able to post the set before the weekend.
http://www.german-3d.com/SaintFoxEU/picture-host/MUPreview.jpg
odf ( ) posted Tue, 04 May 2010 at 8:19 PM
Those look great, SaintFox. I've hardly ever used make-up in a render, but with such nice options, I definitely will in the future.
SaintFox ( ) posted Tue, 04 May 2010 at 8:33 PM
*I've hardly ever used make-up in a render, but with such nice options, I definitely will in the future.
That's the reason why I've added some pretty subtle styles (the last three in the preview)* as these will go together well with everyday-clothes and nude renders*.* But as soon as Antonia has a glamorous wardrobe she may need the more flashy looks as well*.* I was amazed how Antonia's attitude can be changed with just a bit lipstick and powder - like a real woman she can be a vamp, a business lady or a young girl*.* You've created a very believable 3d-being!*
RorrKonn ( ) posted Tue, 04 May 2010 at 8:40 PM
Very nice makeup SaintFox
odf ( ) posted Tue, 04 May 2010 at 8:47 PM
Quote - You've created a very believable 3d-being!*
Thanks! That was the plan.
sazzyazzca ( ) posted Tue, 04 May 2010 at 8:47 PM
Gorgeous!
SaintFox ( ) posted Tue, 04 May 2010 at 9:06 PM · edited Tue, 04 May 2010 at 9:09 PM
Thanks for the flowers! Once I found the right shapes for everything it was pure fun. As I saw that most of the renders of Antonia with the Toni Polygon-texture use the face with the asymetric eyebrows I've created everything with this set. I hope that you all understand that I am not very fond of the idea to do all sets with the other eyebrows and the browless version as well. But if someone very badly wants to have for instance a browless version it is not too hard to combine the basic browless face texture with this makeup in a grafic application. Just be sure to not compress the textures any more. I use a quality of 10 in Photoshop for all the textures - unfortunatly ImageReady/"Save for Web" refuses to save 4000x4000 textures and doesn't care for me wanting more control over the compression...
Rogerbee1 ( ) posted Wed, 05 May 2010 at 2:21 AM
They are superb!!
ghost13 ( ) posted Wed, 05 May 2010 at 7:21 AM
great looking job on the makeup  :)
SaintFox ( ) posted Wed, 05 May 2010 at 8:07 PM
I'm done, just uploaded the MakeUps to the Freestuff-site
http://antonia.bluecho4u3d.com/start.htm
You can find it under Character-Texture-Sets. In fact this does not make much sense as the file contains nothing but textures. But when I uploaded the Basic set (Toni Polygon) I dropped it there and this way people will not have to browse the complete site to find both sets.
sazzyazzca ( ) posted Wed, 05 May 2010 at 8:09 PM
Thank you sooooo much! :D
theprojectionist ( ) posted Wed, 05 May 2010 at 8:12 PM
Super, thanks.
Faery_Light ( ) posted Wed, 05 May 2010 at 11:10 PM
just checking in.
too tired for comments but will catch up soon. :)
SaintFox ( ) posted Wed, 05 May 2010 at 11:48 PM · edited Wed, 05 May 2010 at 11:49 PM
While waiting for all those thumbnails to render I did a little body- and headmorph (named "Anna" so far). If there is any interest I would upload it to the freebie site as soon as I have created an Injection for each, head and body. Additional morphs used for the images come from the clever dial-a-nipple morph set by LesBentley. As this add on gives perfect results I saw no sense in creating my own morphs for areola and nipple.
Oh and: Yes, I am aware that she is floating on some images 😉
RorrKonn ( ) posted Thu, 06 May 2010 at 3:20 AM
Float all ya want to.SaintFox
What softwares do you use to make the texures , maps n stuff ?
Rogerbee1 ( ) posted Thu, 06 May 2010 at 4:35 AM
Perfectly formed!
CHEERS!
Faery_Light ( ) posted Thu, 06 May 2010 at 7:53 AM
SF, that is a stunning set of morphs!
lesbentley ( ) posted Thu, 06 May 2010 at 8:17 AM · edited Thu, 06 May 2010 at 8:19 AM
That looks good SaintFox, not just the morphs, the poses are very nice too, interesting hair, and a very nice render. Yes, please upload the morphs to the freebie site. I wouldn't mind having some of those poses too, if they are something you can distribute.
