I dont think so, I just did some quick tests but the light color was always the same as the actual light, regardless of the color of the semi-transperant (or refractive or transulent) object
TemplarGFX
3D Hobbyist since 1996
I use poser native units
I thought BB was able to make light traveling through coloured transparent objects change that light colour. Think it was in the node cult on RDNA...
If not, then just put another light inside the object shining the same color as the the object, and be done with the nonsense!
dph
If I remember BB¨'s explanations right, it's not possible. Not without cheating at least. I once tried to make a stained glass window and not even BB could make it work L
Oh, okay... maybe with the Gather() node? IDL? Grasping at straws...
What is "dia" an abbreviation of? I looked it up and this is all I found:
**Dia is a harmful status effect that burns the afflicted with light and illuminates their weaknesses until it wears off or is removed. Afflicted characters experience light Damage Over Time and reduced defense. As with other forms of DoT, damage dealt by the Dia effect will wake characters under the effect of sleep.
Poser won't do that. You need Final Fantasy. :O)
Seriously though, caustics is a subset of this with curved surfaces. Poser can't do it, so you have to find a way to simulate it.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
I have tried to render the dia effect in carrara 7 express. And ? Yes, in this program it works. But the result is greycolored !
In poser 7 i see nothing on the second retangle. In carrara 7 express can i see a greycolored and zommed picture. Like a real dia. Now i must find a way to transport the color to in carrara !
BB said it can't be done in Poser (although it can be done in Firefly; just not Poser's implementation of it.). It's in the Fresnel Effect thread at RDNA...
"Oh - the manual says that? I have never read the manual - this must be why."Without caustics, an object cannot transfer its colour to the light passing through it.
I can see something on the square in the Poser render - illumination from the light. Did you set Cast shadows on the square? Is the render Cast shadows option switched on? If you are using RT shadows, is RT switched on?
Carrara is showing illumination plus shadow from the transparency map, which is why it is inverted. With white light and white surface, this can only ever be grey.
I thought Carrara supports caustics.
what I should be."
Murakami)
Quote - Besides... if BB can't do it, I suspect the rest of use are shooting marbles with bb's (no pun intended!) :)
Not really. We know that Poser can't do what the OP wants.
But the test renders in Poser and Carrara needed an explanation.
what I should be."
Murakami)
Quote - Explanation: If you stand in a church. In front of a colored window. You look down to the ground. You can see the light on the ground, falling through the colored window. It's colored in the same way like the windows !
the effect is called Caustics and no, poser cannot do it properly at this time with the render engine it has.
Can you apply a coloured "gel" to a poser light ? if you can, then you could put a pointlight or somesuch in front of the window with the gel on it and maybe fake it that way
My Freebies
Buy stuff on RedBubble
Yup, we understood that.
Above is the same setup in Poser as you had in Carrara. You must have had shadows disabled in your test render.
Quote - Can you apply a coloured "gel" to a poser light ? if you can, then you could put a pointlight or somesuch in front of the window with the gel on it and maybe fake it that way
Yes, you can. That might work, with careful light placement.
what I should be."
Murakami)
what I should be."
Murakami)
I asked about this a few years back see this thread for an answer on how to do it
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2695748
That's a good link.
It's exactly the way I'm doing it above, except that the colours are coming from the spotlight's gel image map, rather than its Diffuse_Color.
what I should be."
Murakami)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3523037&ebot_calc_page#message_3523037
it works in carrara with refractive squares of zero thickness (see att lnk). ask in carrara forum for details. they don't always answer the hard questions, but this is an easy one.in re: poser 7, the short answer is no. poser 8 or later, yes, but it's either gonna be a lousy-looking
diffuse effect using IDL and translucent channel and some fake lighting tricks, or a crazy-looking
effect involving a coloured image map applied to diffuse and/or specular channels of directional lite.
it's not strictly a caustic effect, as it works in carrara with caustics disabled.
Yes, sounds simple with this projection.
Here the complete idea:
The only houses i know with colored glass are church and similar.
You stand in the building, through the windows can you see the colored lightrays and the projection on the ground. Outside the sun is moving, the lightrays and the projection moves with the sun. That's it.
This is not strictly caustics, but simply colored transparency, and as has been pointed out, I've been told by stewer that Firefly can do it. A caustic is a focus/defocus of otherwise near-parallel light beams from the source, causing localized variations in luminance that don't obey the inverse square law.
Color transparency could be performed easily if only the Poser Surface "Transparency" channel was a color instead of a number. I can't remember why this was not exposed. Might be in a future version. The code is already there.
Quote - What poser version do you use ? Version Nr. ? Standart or pro ?
Sorry, I missed your question because I signed off the thread.
You can do this in any Poser version that allows connection of an image map to the diffuse colour of a spotlight. P7 supports this, I don't know about P6 or before.
I use PPro2010.
what I should be."
Murakami)
Is it impossible to render a real dia effect in poser ?
Light is falling through a colored front object and colored the white object behind ?
