Tue, Jan 28, 3:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Real Dia Effect in Poser 7 ?
megaionstorm ( ) posted Sun, 30 May 2010 at 11:59 PM · edited Mon, 27 January 2025 at 4:06 AM
Is it impossible to render a real dia effect in poser ?
Light is falling through a colored front object and colored the white object behind ?
templargfx ( ) posted Mon, 31 May 2010 at 3:27 AM
I dont think so, I just did some quick tests but the light color was always the same as the actual light, regardless of the color of the semi-transperant (or refractive or transulent) object
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
RobynsVeil ( ) posted Mon, 31 May 2010 at 5:38 AM
I thought BB was able to make light traveling through coloured transparent objects change that light colour. Think it was in the node cult on RDNA...
Metaphor of Chooks
dphoadley ( ) posted Mon, 31 May 2010 at 6:12 AM
If not, then just put another light inside the object shining the same color as the the object, and be done with the nonsense!
dph
TrekkieGrrrl ( ) posted Mon, 31 May 2010 at 6:52 AM
 If I remember BB¨'s explanations right, it's not possible. Not without cheating at least. I once tried to make a stained glass window and not even BB could make it work L
RobynsVeil ( ) posted Mon, 31 May 2010 at 7:15 AM
Oh, okay... maybe with the Gather() node? IDL? Grasping at straws...
Metaphor of Chooks
IsaoShi ( ) posted Mon, 31 May 2010 at 7:53 AM · edited Mon, 31 May 2010 at 7:54 AM
What is "dia" an abbreviation of? I looked it up and this is all I found:
**Dia is a harmful status effect that burns the afflicted with light and illuminates their weaknesses until it wears off or is removed. Afflicted characters experience light Damage Over Time and reduced defense. As with other forms of DoT, damage dealt by the Dia effect will wake characters under the effect of sleep.
Poser won't do that. You need Final Fantasy. :O)
Seriously though, caustics is a subset of this with curved surfaces. Poser can't do it, so you have to find a way to simulate it.
megaionstorm ( ) posted Mon, 31 May 2010 at 8:50 AM
I have tried to render the dia effect in carrara 7 express. And ? Yes, in this program it works. But the result is greycolored !
  1. I have placed a spot lightsource.
  2. I have placed a rectangle object in front of it. Textured with a picture and transparency.
  3. I have placed a second retangle behind the first. Only white color.
In poser 7 i see nothing on the second retangle. In carrara 7 express can i see a greycolored and zommed picture. Like a real dia. Now i must find a way to transport the color to in carrara !
WandW ( ) posted Mon, 31 May 2010 at 9:14 AM
BB said it can't be done in Poser (although it can be done in Firefly; just not Poser's implementation of it.).  It's in the Fresnel Effect thread at RDNA...
megaionstorm ( ) posted Mon, 31 May 2010 at 10:14 AM · edited Mon, 31 May 2010 at 10:19 AM
Example:
But it looks in both pictures not as it realy should !
In poser you see nothing. Thanks to firefly renderer !
In carrara it's a grey picture and it looks inverted !
IsaoShi ( ) posted Mon, 31 May 2010 at 11:23 AM
Without caustics, an object cannot transfer its colour to the light passing through it.
I can see something on the square in the Poser render - illumination from the light. Did you set Cast shadows on the square? Is the render Cast shadows option switched on? If you are using RT shadows, is RT switched on?
Carrara is showing illumination plus shadow from the transparency map, which is why it is inverted. With white light and white surface, this can only ever be grey.
I thought Carrara supports caustics.
basicwiz ( ) posted Mon, 31 May 2010 at 1:38 PM
I like Hoadley's answer... simple, elegant, WORKABLE!
Besides... if BB can't do it, I suspect the rest of use are shooting marbles with bb's (no pun intended!) :)
IsaoShi ( ) posted Mon, 31 May 2010 at 2:15 PM
Quote - Besides... if BB can't do it, I suspect the rest of use are shooting marbles with bb's (no pun intended!) :)
Not really. We know that Poser can't do what the OP wants.
But the test renders in Poser and Carrara needed an explanation.
megaionstorm ( ) posted Mon, 31 May 2010 at 2:24 PM
Explanation: If you stand in a church. In front of a colored window. You look down to the ground. You can see the light on the ground, falling through the colored window. It's colored in the same way like the windows !
Khai-J-Bach ( ) posted Mon, 31 May 2010 at 2:26 PM
Quote - Explanation: If you stand in a church. In front of a colored window. You look down to the ground. You can see the light on the ground, falling through the colored window. It's colored in the same way like the windows !
the effect is called Caustics and no, poser cannot do it properly at this time with the render engine it has.
FrankT ( ) posted Mon, 31 May 2010 at 2:28 PM
Can you apply a coloured "gel" to a poser light ? if you can, then you could put a pointlight or somesuch in front of the window with the gel on it and maybe fake it that way
My Freebies
Buy stuff on RedBubble
IsaoShi ( ) posted Mon, 31 May 2010 at 2:54 PM
Yup, we understood that.
Above is the same setup in Poser as you had in Carrara. You must have had shadows disabled in your test render.
Quote - Can you apply a coloured "gel" to a poser light ? if you can, then you could put a pointlight or somesuch in front of the window with the gel on it and maybe fake it that way
Yes, you can. That might work, with careful light placement.
IsaoShi ( ) posted Mon, 31 May 2010 at 3:11 PM · edited Mon, 31 May 2010 at 3:13 PM
First attempt using a gel. I would have increased Angle Start and Angle End to reduce the fall-off (vignette, I think it's called), but Poser crashed on me and I lost the scene.
RedPhantom ( ) posted Mon, 31 May 2010 at 3:19 PM
Site Admin Online Now!
I asked about this a few years back see this thread for an answer on how to do it
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2695748
IsaoShi ( ) posted Mon, 31 May 2010 at 3:37 PM
That's a good link.
It's exactly the way I'm doing it above, except that the colours are coming from the spotlight's gel image map, rather than its Diffuse_Color.
Miss Nancy ( ) posted Mon, 31 May 2010 at 3:41 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3523037&ebot_calc_page#message_3523037
it works in carrara with refractive squares of zero thickness (see att lnk).  ask in carrara forum for details.  they don't always answer the hard questions, but this is an easy one.
in re: poser 7, the short answer is no.  poser 8 or later, yes, but it's either gonna be a lousy-looking
diffuse effect using IDL and translucent channel and some fake lighting tricks, or a crazy-looking
effect involving a coloured image map applied to diffuse and/or specular channels of directional lite.
it's not strictly a caustic effect, as it works in carrara with caustics disabled.
Miss Nancy ( ) posted Wed, 02 June 2010 at 6:22 PM
OP indicated he wanted a simple slide projector effect.  in poser, attach img map to diffuse
channel of spotlite.  point lite and infin. lite will give strange results (tiling and other probs).
IsaoShi ( ) posted Wed, 02 June 2010 at 6:27 PM
Err, yes... as above!
Apple_UK ( ) posted Wed, 02 June 2010 at 6:40 PM
Would it not be simpleu to add the image as a texture map to the object is supposed to be projected on ?
megaionstorm ( ) posted Wed, 02 June 2010 at 6:55 PM
Yes, sounds simple with this projection.
Here the complete idea:
The only houses i know with colored glass are church and similar.
You stand in the building, through the windows can you see the colored lightrays and the projection on the ground. Outside the sun is moving, the lightrays and the projection moves with the sun. That's it.
megaionstorm ( ) posted Wed, 02 June 2010 at 7:02 PM
Quote - First attempt using a gel.
What poser version do you use ? Version Nr. ? Standart or pro ?
Miss Nancy ( ) posted Wed, 02 June 2010 at 8:22 PM
in poser spotlite, fall-off = 0 at start angle; fall-off = 1 at stop angle, hence let
start angle  =  stop angle for no fall-off.  stained glass transmissive effect not supported
in current versions of poser.
bagginsbill ( ) posted Wed, 02 June 2010 at 10:26 PM · edited Wed, 02 June 2010 at 10:26 PM
This is not strictly caustics, but simply colored transparency, and as has been pointed out, I've been told by stewer that Firefly can do it. A caustic is a focus/defocus of otherwise near-parallel light beams from the source, causing localized variations in luminance that don't obey the inverse square law.
Color transparency could be performed easily if only the Poser Surface "Transparency" channel was a color instead of a number. I can't remember why this was not exposed. Might be in a future version. The code is already there.
Michael314 ( ) posted Thu, 03 June 2010 at 3:42 AM
Hi,
I did some tests a while ago, I tried to link the diffuse light input to the ambient channel.
In short, it also did not work out as expected. Plus, the resulting light would have lost
its direction (no longer spotlight or inifinite).
Best regards,
   Michael
bopperthijs ( ) posted Thu, 03 June 2010 at 12:49 PM · edited Thu, 03 June 2010 at 12:59 PM
It's possible in poser, but you have to do some postwork. The image above was done in three passes with different colored lights and the images were combined in Paintshoppro.
best regards,
Bopper.
bopperthijs ( ) posted Thu, 03 June 2010 at 1:20 PM
This one is even better, I messed up some things in the first one.
IsaoShi ( ) posted Sun, 06 June 2010 at 10:22 AM
Quote - What poser version do you use ? Version Nr. ? Standart or pro ?
Sorry, I missed your question because I signed off the thread.
You can do this in any Poser version that allows connection of an image map to the diffuse colour of a spotlight. P7 supports this, I don't know about P6 or before.
I use PPro2010.
IsaoShi ( ) posted Sun, 13 June 2010 at 6:04 AM
