Mon, Jan 13, 11:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: How to animate a Conveyor belt??in poser7
uncle808us ( ) posted Wed, 02 June 2010 at 9:38 AM · edited Thu, 26 December 2024 at 7:39 AM
Poser 7 Mac Leopard. How can I animate a Conveyor belt in Poser 7 any advice appreciated. any tutorials etc.
MacBook Pro OSX El Capitan Ver 10.11.6
bagginsbill ( ) posted Wed, 02 June 2010 at 10:06 AM
Assuming you have a texture on the belt, animate the appropriate offset on the Image_Map node.
Which to animate (U_Offset, or V_Offset) will depend on the orientation of the UV map of the belt.
Let's suppose the belt is UV mapped horizontally. So you have to change the U_Offset from 0 to 1 to do one full "rotation".
If you want it to rotate around 3 cycles, then animate U_Offset from 0 to 3.
If you have a color map and a bump map, animate both identically.
uncle808us ( ) posted Wed, 02 June 2010 at 10:31 AM
I will try this. But this will not really move the belt will it, I don't know. sounds like it just animates the texture. Thanks
ockham ( ) posted Wed, 02 June 2010 at 10:59 AM · edited Wed, 02 June 2010 at 11:01 AM
If the texture and displacement are drawn to match, AND if the UV mapping is proper,
this method will work neatly.   For most belts, the only thing you really see is a moving
texture anyway.  (Imagine the fan belt on a car, where you see the label zooming past
repeatedly.)
The exception is when the belt has compartments or buckets like a
grain elevator "leg", in which case you'll need real physical motion.
The UVmapping is really the hard part.  I found it best to model the belt as a nice
round cylinder, then map it as cylinder, then morph it into the long belt shape.
Or you could try Draw-A-Cord, now that it works for you... :)
My python page
My ShareCG freebies
uncle808us ( ) posted Wed, 02 June 2010 at 11:14 AM · edited Wed, 02 June 2010 at 11:15 AM
I didn't think of that good idea.Looks like I'll be having some fun.
pakled ( ) posted Fri, 04 June 2010 at 11:06 AM
having had to stare at converyor belts for a good portion of me workin' life, you could probably get away with just having the seam move down the line at regular intervals....;)
uncle808us ( ) posted Fri, 04 June 2010 at 11:12 AM
I can't figure out how to animate the texture in Poser 7, I have got it working in my 3d software Cheetah 3d. I'm searching the ref in Poser now.
uncle808us ( ) posted Fri, 04 June 2010 at 11:39 AM
OK I figured it out and can see the animation in the Material room the texture moves but in the scene Pose window I see no movement. Now I'm at a stand still.
Apple_UK ( ) posted Fri, 04 June 2010 at 12:11 PM
There are some battle tanks with catapillar treads in the MP, that is a similar problem - maybe the vendors have solved the rotation, but it would cost to see how
bagginsbill ( ) posted Fri, 04 June 2010 at 12:21 PM
The Pose Window preview does not pay attention to scaled, offset, or animated textures.
Why do you care? Aren't you planning to render?
uncle808us ( ) posted Fri, 04 June 2010 at 12:29 PM
Doh Yep that works. Thanks to everyone.
Helgard ( ) posted Fri, 04 June 2010 at 6:48 PM
There are some battle tanks with catapillar treads in the MP - but it would cost to see how
Or you could download the free one:
http://www.ontarget3d.com/Products/185-m1-abrams-for-poser.aspx
But that solution is not ideal for a conveyer belt. The tank track programming works for tracks, and things like an escalator, belt fed machine gun, etc, where the links are seperate pieces of geometry. For a conveyer belt the method above of animating the texture is the best solution.
Your specialist military, sci-fi, historical and real world site.
