Blender F.A.Q (Last Updated: 2024 Sep 29 9:06 pm)
Doesn't make any difference, if you re-name the mesh object name the same as the object name is exports as Piston_Piston. i.e objectname_meshname.
The weird thing is that occasionally it will export just the objectname without the meshname and I'm just trying to find out what the criteria for that is.
Could it be a buggy exporter????
I've gone so far as to load Blender onto a clean machine and I can't replicate this problem.
Are you using the library function?
Could it be OS related? I'm on Windows.
LOL There is a certain measure of irony in this situation. You are trying to eliminate this problem, I'm trying to create the problem to understand it but neither of us is making any progress.
There has to be something simple we are both overlooking.
I share Touchwood's experience, regardless of whether I run Blender in Ubuntu Linux or Windows XP Pro.
Quote - I've gone so far as to load Blender onto a clean machine and I can't replicate this problem.
I'm on windows (x64 but using 32bit Blender). Using 2.49b to test as the obj export in 2.5 is not working properly. Which Library function are you referring to? I suppose though if I have to ask it means I'm not using it.
Have been trying to replicate the problem using primitives only rather than a full model. So far using the primitives it appears only to happen if the object name differs from the mesh name.
If the object name = mesh name it exports using the object name only. If the mesh name is different, it exports as object name_mesh name. The anomaly though is that in complex meshes, if both OB+ME names are the same, the behaviour is not consistant.
Can you replicate this so far? Am still testing using more complex models though.
Is there any way to export to .obj format and not have blender tack on the mesh name after the object name and the image name for the materials?
i.e. Body_Cube.001 or material: tyre_tyre.jpg
I think I've tried every option for it to not do this but do not seem to have hit it yet. Is it at all possible as it gets to be a bit of a pain having to hand edit the obj file all the time.
