Mon, Oct 7, 9:18 AM CDT
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
Carrara Free Stuff here.
Subject: Adding wave to Gradient Shader.
Analog-X64 ( ) posted Sun, 12 December 2010 at 2:44 PM · edited Mon, 07 October 2024 at 7:34 AM
My skills in photoshop are better than Carrara, I'm trying to bring an effect from Photoshop into Carrara.
Analog-X64 ( ) posted Sun, 12 December 2010 at 2:45 PM
So here it is in Carrara.  I'm just not sure how to add the Wave into the gradient like I can in photoshop.
ewinemiller ( ) posted Sun, 12 December 2010 at 3:08 PM
Try the Elevation shader and use its Wiggle parameter.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave plug-ins
Analog-X64 ( ) posted Sun, 12 December 2010 at 4:29 PM
Quote - Try the Elevation shader and use its Wiggle parameter.
Regards,
The above sample was done with the Environment function.  If I switch to Elevation I lose that look all together and it becomes 1 color.  However in the shader editor I can see the wiggle effect.  I tried playing with all the different Elevation settings but no luck.
ewinemiller ( ) posted Sun, 12 December 2010 at 5:01 PM
Feed the Elevation shader into the Color Gradient so your Color Channel looks like
Color Gradient
|__Elevation
Since you're comfortable with photoshop, another option is build the color gradient there and use projection mapping to texture your text.
Regards,
Eric Winemiller
Analog-X64 ( ) posted Sun, 12 December 2010 at 5:16 PM
> Quote - Feed the Elevation shader into the Color Gradient so your Color Channel looks like > > Color Gradient > > |__Elevation > > Since you're comfortable with photoshop, another option is build the color gradient there and use projection mapping to texture your text. > > Regards,
Hmmm building the gradient in photoshop and mapping as a texture is an interesting idea.
Here is a shot of my shader setup.
NOw here is what the render looks like with elevation.
MarkBremmer ( ) posted Sun, 12 December 2010 at 5:47 PM
This should answer your questions, hopefully.
ewinemiller ( ) posted Sun, 12 December 2010 at 6:10 PM
> Quote - Hmmm building the gradient in photoshop and mapping as a texture is an interesting idea. Here is a shot of my shader setup.
You're pretty much there. Just make sure the Height parameter is set to the center of your object and the Blend is about the height. Here's my shot at it.
Regards,
Eric Winemiller
MarkBremmer ( ) posted Sun, 12 December 2010 at 7:42 PM
That works too!
GKDantas ( ) posted Mon, 13 December 2010 at 5:12 AM
Uouu... a real shading lesson here!
Follow me at euQfiz Digital
Analog-X64 ( ) posted Mon, 13 December 2010 at 5:28 AM
Tried both of the above screenshots and still not getting the look that both of you got.
I'll keep trying.
GKDantas ( ) posted Mon, 13 December 2010 at 5:43 AM
I think object size is important here too... value are dependent of the object size.
