Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Try the Elevation shader and use its Wiggle parameter.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave
plug-ins
Quote - Try the Elevation shader and use its Wiggle parameter.
Regards,
The above sample was done with the Environment function. If I switch to Elevation I lose that look all together and it becomes 1 color. However in the shader editor I can see the wiggle effect. I tried playing with all the different Elevation settings but no luck.
Feed the Elevation shader into the Color Gradient so your Color Channel looks like
Color Gradient
|__Elevation
Since you're comfortable with photoshop, another option is build the color gradient there and use projection mapping to texture your text.
Regards,
Eric Winemiller
plug-ins
Hmmm building the gradient in photoshop and mapping as a texture is an interesting idea.
Here is a shot of my shader setup.
You're pretty much there. Just make sure the Height parameter is set to the center of your object and the Blend is about the height. Here's my shot at it.
Regards,
Eric Winemiller
plug-ins
I think object size is important here too... value are dependent of the object size.
Follow me at euQfiz Digital
![file_462891.jpg](https://live.cdn.renderosity.com/forum/threads/2817726/file_462891.jpg)
My skills in photoshop are better than Carrara, I'm trying to bring an effect from Photoshop into Carrara.
