Thu, Dec 26, 8:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Weird .obj import between Poser 8 and Poser 7
uncle808us ( ) posted Wed, 09 March 2011 at 1:24 PM · edited Thu, 26 December 2024 at 8:39 PM
When I load this .obj into Poser 8 I get this result, but when I import into Poser 7 there is no problem. Any one have an idea what is causing this?
MacBook Pro OSX El Capitan Ver 10.11.6
uncle808us ( ) posted Wed, 09 March 2011 at 1:25 PM · edited Wed, 09 March 2011 at 1:26 PM
> Quote - When I load this .obj into Poser 8 I get this result, but when I import into Poser 7 there is no problem. Any one have an idea what is causing this?
SteveJax ( ) posted Wed, 09 March 2011 at 1:51 PM
Poser 8 as well as Poser Pro are much less forgiving of errors than Poser 7 or earlier were. OBJ's that won't import into Poser 8 or Pro 2010 will import just fine in Poser 4,5,6 & 7.
uncle808us ( ) posted Wed, 09 March 2011 at 1:56 PM · edited Wed, 09 March 2011 at 1:57 PM
Well That ain't right. lol
If I save in Poser 7 as a Poser scene then open it in Poser 8 it works as it should.
hborre ( ) posted Wed, 09 March 2011 at 2:17 PM
Have you tried re-exporting it as an Obj from Poser 7, then importing it into P8?
uncle808us ( ) posted Wed, 09 March 2011 at 2:45 PM
Nope did not work but has diffrent flaws.
TheOwl ( ) posted Wed, 09 March 2011 at 3:25 PM
This only made me hungry.
Passion is anger and love combined. So if it looks angry, give it some love!
SteveJax ( ) posted Wed, 09 March 2011 at 5:20 PM
It should work fine in Poser 8 after you import into Poser 7 and save as a PP2 file.
vilters ( ) posted Wed, 09 March 2011 at 5:29 PM
1; Your lights from P7 and P8 are not the same.
2; You have a problem with the normals of the obj file.
  1. Smooth polygons, (last pic) is ON and at a different setting as before.
Check obj in external proggie. Wings or blender or anim8or or.....
Check normals
Check light set betwee 7 and 8
Check Smooth polygons on all obj parts and in Posers general preferences.
Miss Nancy ( ) posted Wed, 09 March 2011 at 5:49 PM
seems to be comparing a depth map render in poser 8 with a preview img in poser 7.
Cage ( ) posted Wed, 09 March 2011 at 9:53 PM
It looks like you have a number of backwards-facing polygons.  If you set "Normals Forward" in the Materials Room, that might help it render better.  Are you importing with "Make polygon normals consistent" checked?  Possibly that might improve something.  😕
I know UV Mapper Pro has some tools to help correct backwards polygons.  I seem to recall that Wings 3D might correct backwards polys on import.  If that's the case, importing and exporting with Wings might fix it.
markschum ( ) posted Wed, 09 March 2011 at 10:58 PM
If you want the original obj looked at I would be happy to have a look
send it to marks542004@yahoo.com
Try importing WITHOUT checking the standardise normals (or whatever its called) on import options .
kawecki ( ) posted Thu, 10 March 2011 at 12:41 AM
Load the obj file into the latest version of PropViewer, click on remove duplicated faces and fix normals and then export it again as obj file (with a new name).
PropViewer fixes all what is wrong with obj file's geometry.
Stupidity also evolves!
uncle808us ( ) posted Thu, 10 March 2011 at 9:01 AM
Quote - Load the obj file into the latest version of PropViewer, click on remove duplicated faces and fix normals and then export it again as obj file (with a new name).
I,m on Mac too bad: An utility for viewing Poser files (pp2, cr2, hr2) and obj, 3ds, dxf and ply files. Stand alone Windows PC application
uncle808us ( ) posted Thu, 10 March 2011 at 9:15 AM
Quote - If you want the original obj looked at I would be happy to have a look
Thanks I have sent the objs.
markschum ( ) posted Thu, 10 March 2011 at 10:57 AM
I loaded the models sent to me in Lightwave and the glass looked fine , except for a hole  and the 'sauce' was ok but for some non-planar n-gons.
I emailed a reply with some suggestions for those .
It all imported into Poser 7 sr2 with no problems, just using center and floor options.
The pic is what I get as a render with a simple color texture applied to the glass
I examined the obj files in wordpad for any issues with continuation lines and there are none.
Sorry, but I dont see a problem with the models. There may be a bug in obj import :(
uncle808us ( ) posted Thu, 10 March 2011 at 11:06 AM
Thanks
markschum ( ) posted Thu, 10 March 2011 at 11:32 AM
a modelling point , if using a curve to 'lathe' a shape one vertex of the curve needs to be at the axis to close the shape. If its not you get a hole.If you start and end the curve at the axis you can create both inner and outer shapes and have a thickness to the sides.
