Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
1; Your lights from P7 and P8 are not the same.
2; You have a problem with the normals of the obj file.
Check obj in external proggie. Wings or blender or anim8or or.....
Check normals
Check light set betwee 7 and 8
Check Smooth polygons on all obj parts and in Posers general preferences.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
It looks like you have a number of backwards-facing polygons. If you set "Normals Forward" in the Materials Room, that might help it render better. Are you importing with "Make polygon normals consistent" checked? Possibly that might improve something.
I know UV Mapper Pro has some tools to help correct backwards polygons. I seem to recall that Wings 3D might correct backwards polys on import. If that's the case, importing and exporting with Wings might fix it.
Quote - Load the obj file into the latest version of PropViewer, click on remove duplicated faces and fix normals and then export it again as obj file (with a new name).
PropViewer fixes all what is wrong with obj file's geometry.
I,m on Mac too bad: An utility for viewing Poser files (pp2, cr2, hr2) and obj, 3ds, dxf and ply files. Stand alone Windows PC application
MacBook Pro OSX El Capitan Ver 10.11.6
I emailed a reply with some suggestions for those .
It all imported into Poser 7 sr2 with no problems, just using center and floor options.
The pic is what I get as a render with a simple color texture applied to the glass
I examined the obj files in wordpad for any issues with continuation lines and there are none.
Sorry, but I dont see a problem with the models. There may be a bug in obj import :(
