Tue, Feb 4, 4:37 AM CST
Subject: The "Isn't Dynamic Cloth Brilliant" thread
anupaum ( ) posted Mon, 27 June 2011 at 2:05 PM
I could do that, but why bother if it works ok with 5 drape frames and normal simulation?
ShaaraMuse3D ( ) posted Mon, 27 June 2011 at 2:13 PM
Try it out, with the dress parented, and then the figure's body scaled down a little.
SteveJax ( ) posted Mon, 27 June 2011 at 4:26 PM
Quote - > Quote - Doesn't parenting the prop to the figure before the simulation negate any benefits of shrinking or growing the figure because the prop will shrink or grow with the parent? I know I've had that happen to me before. I've always waited to parent the finished simulation to the figure.
No, it won't negate the effects. In fact it creates a very smooth stretch. When the cloth is "clothified" it seems to stay the size that it starts with on the first frame of the simulation, and is then forced to stretch if the figure grows, or to drape if the figure shrinks.
I think it depends on which part of the figure you parent it to because when I parent a dress to the "BODY" and then do scaling, the dress scales with the figure.
ShaaraMuse3D ( ) posted Mon, 27 June 2011 at 4:35 PM · edited Mon, 27 June 2011 at 4:35 PM
Really? From my experience, parenting a dress to the body and scaling the figure down in the first frame will make the figure stretch into it, and if you scale it up it will make it looser. You need to make sure that the figure is 100% in size in the target frame. I can show you examples if you want, but try it for yourself, it's always worked for me.
ShaaraMuse3D ( ) posted Mon, 27 June 2011 at 5:04 PM · edited Mon, 27 June 2011 at 5:05 PM
Providing an image with the angel dress parented to the body at small scale, normal scale and bigger scale at starting frame and the result of the simulation at the target frame. Due to the very loose fabric of the dress I had to use a fairly big difference when scaling it down. Normally that much is not needed.
Note that the waistband stays the same way due to that it's constrained.
Anyways, there you go :)
Afrodite-Ohki ( ) posted Mon, 27 June 2011 at 6:03 PM
I used to say dynamic cloth takes too long to calculate.
That it's too buggy.
That it's not worth the time when most of the times it'll give you artifacts and blotches and holes.
That it's annoying to make the animation just for that.
And so on~~
I take it back. I take it ALL back. Look at this. It's completely stunning, and I'm taken and stunned and saving to buy a commercial MarvelousDesigner license so I can make products like this and better like crazy. I don't want to sound arrogant, but this image made my jaw drop, and it's all because of dynamic cloth. I'm in love.
Feel free to call me Ohki!
AVANZ ( ) posted Mon, 27 June 2011 at 6:29 PM
@Grappo
Wow, that is a simple yet impressive result. Who would have thought......
@Afrodite-Ohki
Very nice drape. I also like the apparent thickness of the material. Is that displacement?
Afrodite-Ohki ( ) posted Mon, 27 June 2011 at 6:56 PM
Quote - @Afrodite-Ohki
Only on the collar and sleeve straps... that was a cheat. Those parts (that were modelled as trims above the cloth) had major pokethroughs after the simulation, so I put a 4mm pure-white displacement on them LOL
AVANZ ( ) posted Mon, 27 June 2011 at 7:20 PM
Hi Maira,
Smart, and looks convincing to me!
Afrodite-Ohki ( ) posted Mon, 27 June 2011 at 8:33 PM
Thanks! :D
Coleman ( ) posted Tue, 28 June 2011 at 5:08 AM
Awesome thread!!
I've wanted to do a feudal Japan comic but all the flowing clothing can only be done really with dynamic cloth. Lots of great techniques here.
SteveJax ( ) posted Tue, 28 June 2011 at 1:01 PM
Frame 1. No Scale. Dress parented to body.
SteveJax ( ) posted Tue, 28 June 2011 at 1:04 PM · edited Tue, 28 June 2011 at 1:06 PM
Frame 30. Body Scaled to 143%,, ZScaled to 158%. Dress parented to body. Notice the dress has scaled exactly with the body! This happens consistantly when I parent to the figure with ALL props as it is supposed to!  Otherwise you would always have to rescale each parented prop individually! This is why I don't parent dynamic clothing to the body until after the simulation is finished if I'm shrink wrapping.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 1:20 PM
Quote - Frame 30. Body Scaled to 143%,, ZScaled to 158%. Dress parented to body. Notice the dress has scaled exactly with the body! This happens consistantly when I parent to the figure with ALL props as it is supposed to!  Otherwise you would always have to rescale each parented prop individually! This is why I don't parent dynamic clothing to the body until after the simulation is finished if I'm shrink wrapping.
Have you scaled it in frame 30?
You need to scale it on frame 1, and reset all values to 100% on frame 30 in order to get the effect you see on the picture I posted.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 1:24 PM
And it doesn't look like you've run the simulation on your pictures. The point is to do the following to get different 'size' for the dress, tighter or looser.
  1. Parent the dress to the figure.
  2. Scale the figure up and down as you please on frame 1. (The dress should follow)
  3. Make sure that the scale of the figure is set to default 100% on the target frame, (ie frame 30)
  4. Clothify the prop in the clothroom, set the simulation length to at least the target frame.
  5. Run the simulation. Different scale for the figure on frame 1 will give different draping results on frame 30. Perfect to scale down x and z if you want a tighter dress.
SteveJax ( ) posted Tue, 28 June 2011 at 1:34 PM
Did you not just read what I posted? I am shrink wrapping the dress to the figure, not the other way around. Go back and read what I said.
Here Is the dress NOT parented to the body. Started with the figure at 100% on frame 1 and ended with the figure ZScaled to 150 at frame 30. As the figure grows into the dress it effectively shrink wraps. If it had been parented to the figure like my first example it wouldn't have shrink wrapped as the figure scaled out.
Somebody else in the thread has already pointed out to you that you are doing the exact opposite of what I do to get the same effect. Regardless, props scale with the figure when you parent them.
SteveJax ( ) posted Tue, 28 June 2011 at 1:37 PM · edited Tue, 28 June 2011 at 1:40 PM
Quote - And it doesn't look like you've run the simulation on your pictures. The point is to do the following to get different 'size' for the dress, tighter or looser.
  2. Scale the figure up and down as you please on frame 1. (The dress should follow) < This is exactly what I said about parented props. They scale with the figure and do NOT shrinkWrap to the figure!!
You are NOT shrink wrapping. You are merely scaling the figure to different scales and the dress follows the scale! Exactly what I said it would do if parented to the body. This is NOT the shrink wrap process!!
In order to Shrink Wrap, either the dress must be shrunken to the figure or the figure must "GROW" into the dress and stretch it out to the figures new scale.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 1:40 PM · edited Tue, 28 June 2011 at 1:41 PM
I get your point, and I see what you are doing. However, I cannot see that the prop scales with the figure if it's parented. If it did, I would not get the results that I showed earlier in the post.
Normally it would scale, but it seems that the cloth simulation "locks" the size of the prop when it starts it. Unless the -prop- has been given any scaling values by itself, which it hasn't.
Having to make the figure larger than normal in the target frame would be counter productive to me if I am just trying to get a tight or loose fit for the clothing. If you look at the picture I posted you can clearly see the effect.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 1:52 PM
Here's another example. In both images the dress is parented to the body of the figure. In the left image, all scales are 100%. In the right image z and x xcale are 50% on frame 1, and 100% on frame 21.
The dress is not scaling with the figure, but is being stretched out as the figure grows into it. It wouldn't do this if it scaled with the figure.
SteveJax ( ) posted Tue, 28 June 2011 at 1:53 PM
Here I have parented the dress to the body, then scaled the body down to 50% Zscale on FRAME 1. The dress has AGAIN, followed the scale of the body as I keep saying it would and as you yourself have admited it would do. You are either not doing it the way you are describing or you are skipping a step in your description. I would guess that you scaled the body down at frame 1 BEFORE you parented the dress or the dress would just have scaled down with the body as shown here but you have specifically said you parent and then scale.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 2:00 PM
Nope. I parent dress to figure. Scale figure in frame 1 (and making sure last frame has scaling set back to 100%), then I run the simulation. Have been doing it that way all the time, with tons of different clothes.
I am wondering though, in your example, is your figure's zscale 100% on frame 30?
SteveJax ( ) posted Tue, 28 June 2011 at 2:18 PM · edited Tue, 28 June 2011 at 2:19 PM
Ok, I see what is happening now. When using your method, and you start the simulation, even though the dress scaled down with the body before the simulation, it snaps back to it's original scale at frame 1 during the drapping process while the body stays scaled down. This is why I have been unable to shrink wrap a dress down to a figure while parented because if I scaled the dress up at frame 1 in order to shrink it down to fit by frame 30 it just snaps back to it's default scale when the simulation starts.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 2:27 PM
Yeah it seems you have been doing it the other way around. If you are using the method I'm using, and you want to shrink wrap the dress, you need to scale the figure down rather than up at frame 1.
I used to do it without parenting, but then I had to scale the dress manually with the figure in frame 1, which never got really exact, and constrained groups would get wonky, with pokethroughs or gaps.
SteveJax ( ) posted Tue, 28 June 2011 at 3:49 PM · edited Tue, 28 June 2011 at 3:50 PM
In this image I parented the dress to Jessi in frame 1. Left Jessi at 100% through the whole simulation and only shrank the dress in the Z Axis at frame 30 to tighten it to her normal size. You'll notice the stretch wrinkles mostly around her breast/ribcage area.
ShaaraMuse3D ( ) posted Tue, 28 June 2011 at 4:09 PM
Looks nice. :) What matters is that we get the results we're after.
SteveJax ( ) posted Tue, 28 June 2011 at 4:23 PM
Quote - Looks nice. :) What matters is that we get the results we're after.
Actually, as part of this particular discussion. Accurate descriptive information on the process matters very much. Otherwise people will not be able to use this thread to recreate the same effects you display.
RobynsVeil ( ) posted Tue, 28 June 2011 at 5:48 PM
Quote - The girl in the image in very big in the shoulders, breast, hips and thighs.  She's also taller than average, a feat I accomplished by slightly increasing the length of her legs and abdomen.  As has been suggested in this thread, I thought I'd shrink her down in frame one and allow her to "grow" into her actual size.  It didn't really work that well, though. Most of the time, cloth simulations work for me without too much effort.  Occasionally I'll have problems, but the vast majority of my dynamic simulations progress without any trouble at all.  I've scratched my head for a long time at people who find it so confusing.
My initial experiences with dynamic cloth have been quite the opposite - they have nothing but massive (confused) effort with rubbish as result. Which is why I threw together that little "Try-This" - hope it makes sense to the newbies - a basic starting point, which is what I needed, and which I'm pretty sure more dynamic neophytes need. I've since changed parameters a fair bit with better results, but I still think that those starting points will get even the most frustrated wanna-do-dynamics started with 99% of what's out there.
I only do dynamic cloth, now. And I have KobaltKween to thank for that brilliant recipe!
Metaphor of Chooks
Afrodite-Ohki ( ) posted Tue, 28 June 2011 at 6:42 PM
One simple question, as the content creator that I am: for dynamic cloth, quads or tris for the mesh?
RedPhantom ( ) posted Tue, 28 June 2011 at 7:13 PM
Site Admin
From my observation, and from arguments here, it doesn't seem to matter. What does help is higher polygon count. It allows for smaller bends.
bagginsbill ( ) posted Tue, 28 June 2011 at 7:30 PM
I demonstrated why quads are trouble quite clearly I thought in the last dynamic cloth thread.
Afrodite-Ohki ( ) posted Tue, 28 June 2011 at 8:50 PM
Link to said thread please, BB?
bagginsbill ( ) posted Tue, 28 June 2011 at 9:24 PM
Attached Link: Dynamic cloth - the cloth room For Compleat Dummies - page 7
It's a long thread - I'm giving you a link straight to the business about why quads are bad.
If you look on that page 7 a little earlier than the link, you'll see I posted a link to some cloth simulation test squares I built with various polygon shapes and densities. You can use these yourselves to test settings.
Afrodite-Ohki ( ) posted Tue, 28 June 2011 at 9:53 PM
Thank you muchly mister :3 Goes to read some
ShaaraMuse3D ( ) posted Wed, 29 June 2011 at 3:08 AM · edited Wed, 29 June 2011 at 3:23 AM
In spite of this, for some clothes, quads ended up with nicer drapes for me than tris did. Sometimes tris look better. Note that these were straight triangles. I haven't worked much with uneven tris because Wings doesn't have much support for it.
What is really important to me, possibly most important is how the clothing is modelled, and where. For collars, seams etc, you want to give them surfaces that outline their shape, which will enable the clothing to drape more realistically. It also makes it much easier to texture the UV map later. Say you have a shirt, you don't want tris or quads crossing over where the seams go. Make sure the seams go where they should, so they can bend properly there. :)
RobynsVeil ( ) posted Wed, 29 June 2011 at 5:10 AM
So, there is no "best-mesh-type" for all types of cloth, sounds like. All depends what the mesh is meant to deform to / look like when deformed / be UV-map-friendly / other considerations that haven't been explored yet.
This has got to be the most exciting areas of Poser to get into, and possibly one of the least charted: dynamic cloth making. It'll be a while before I venture there! Gonna mess with a few more conforming -> dynamic conversions first: it's a real eye-opener! 😄
Metaphor of Chooks
ShawnDriscoll ( ) posted Wed, 29 June 2011 at 9:37 AM
Quote - So, there is no "best-mesh-type" for all types of cloth, sounds like.
Correct.  That goes for wrinkles, too.  And the underlying mesh handles different mesh type cloth differently.
MistyLaraCarrara ( ) posted Thu, 30 June 2011 at 8:43 AM
i made this a few days ago, before reading quads vs tris.
it's bunching too much.  :huh:  i'm using wings, too.
a different set of problems with it, when i try to make it conforming.
ShaaraMuse3D ( ) posted Thu, 30 June 2011 at 9:19 AM
To deal with the bunching I usually make a hires version of the cloth for final renders. How many polys are those shorts? Fabric in real life bunches too, and a high poly count tends to make it more forgiving.
Sometimes adding more calculation steps per frame can decrease bunching.
MistyLaraCarrara ( ) posted Thu, 30 June 2011 at 9:22 AM
the poly count was close to 3,000.
i left the calc steps at 2.0.
thanks!  - i'll experiment again with the steps
SteveJax ( ) posted Thu, 30 June 2011 at 12:37 PM
Quote - i made this a few days ago, before reading quads vs tris.
You should also see what your cloth density settings are set as. Lowering them should help with the bunching as well.
AVANZ ( ) posted Thu, 30 June 2011 at 9:16 PM
If it needs to be good, i.e for a commissioned illustration, I export it back to my modeller and subdivide and smooth polygons until it's right. I am not so worried about polygon count...
I know Sculptris and Marvelous Designer create delaunay tris when modeling, but I don't think they can convert quads to delaunay tris. Any ideas on an affordable program...?
ShaaraMuse3D ( ) posted Fri, 01 July 2011 at 2:39 AM
Quote - the poly count was close to 3,000.
For a final version you could easily subdivide the shorts. I love detailed drapes, and for that you need more details in the mesh. It'll take longer, but looks very nice. 10k polys shouldn't be a problem for the shorts.
ShaaraMuse3D ( ) posted Fri, 01 July 2011 at 2:42 AM
My free Mystic Shirt has a highres version with around 30k polys. It takes a while longer to calculate and is a case of more extreme high detailed mesh, but gives really detailed folds.
http://www.renderosity.com/mod/freestuff/details.php?item_id=62376
RobynsVeil ( ) posted Fri, 01 July 2011 at 6:29 AM · edited Fri, 01 July 2011 at 6:34 AM
Quote - > Quote - the poly count was close to 3,000.
I've found that if i want a bit more detail in a given area, I'll go ahead and add some mesh (subdivide) that area only - did this for this dress:
Wow
...right around the abdominal area, where I knew I needed a bit more mesh to make finer folds. Is this a reasonable strategy? No clue. This is a conforming dress that was well-enough designed to convert nicely to dynamic, with a few tiny mods.
Metaphor of Chooks
NanetteTredoux ( ) posted Fri, 01 July 2011 at 7:13 AM · edited Fri, 01 July 2011 at 7:18 AM
I just uploaded this little dress to freestuff, it is awaiting approval. I needed a natural looking African girl child, and the best one I could find was Keisha by Cyllan. Unfortunately Keisha is for Kate, and there are very few clothes for Kate around in Poserdom. For the purpose of the story I am doing, my character also has to be able to sit down in the dress, mostly sitting on the ground. So I used PhilC's basic clothing to make a simple dress, modifying it in Blender and also triangulating the polygons in the skirt. I made it conforming with obj2cr2 converter, and now the dress works as a hybrid, clothifying the skirt in the cloth room. The dress has seven different textures, using patterns I created with Gliftex. All colourways share the same displacement map.
Poser 11 Pro, Windows 10
MistyLaraCarrara ( ) posted Fri, 01 July 2011 at 9:43 AM
Quote - > Quote - > Quote - the poly count was close to 3,000.
Wow
oooo.  i've been wanting an off one shoulder dress for Olivia. 🤤
rjjack ( ) posted Fri, 01 July 2011 at 1:27 PM
> Quote - oooo.  i've been wanting an off one shoulder dress for Olivia. 🤤
i have one in work for Antonia, Olivia and Victoria4, currently i finish the antonia version and the olivia version must be ok for the end of this week and the V4 version a few days later.
MistyLaraCarrara ( ) posted Tue, 05 July 2011 at 12:01 PM
i don't understand what a hex triangle is?
bagginsbill ( ) posted Tue, 05 July 2011 at 1:23 PM
When I published cloth sim test squares, I created five patterns, each with a name. See the image. One of them I called hex because they formed hexagons.
Afrodite-Ohki ( ) posted Tue, 05 July 2011 at 1:31 PM
Hm... I wonder how I get C4d or Zbrush to convert shapes into that.
