Fri, Oct 4, 10:31 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
Subject: Script to delete "Reflection Lite Mult and KD Mult?
Acadia ( ) posted Wed, 07 September 2011 at 11:04 PM · edited Fri, 04 October 2024 at 10:25 AM
Is there a script to delete "Reflection Lite Mult and KD Mult from all material zones of all items in the scene at once? Having to do it one material zone at a time, for so many figures and props is a real PITA!
ErickL88 ( ) posted Thu, 08 September 2011 at 4:11 AM
file_472668.txt
Here is one.
I'd gladly credit the writer of this script, but I don't know who did it (nor where I found it back then). :/
bagginsbill ( ) posted Thu, 08 September 2011 at 6:28 AM
It only affects things plugged into reflection color, so it is not likely this is necessary. I tell people to turn those off only when we are doing a shader using that channel, but some people mistook it for instructions at all times.
Acadia ( ) posted Thu, 08 September 2011 at 8:17 AM
Quote - It only affects things plugged into reflection color, so it is not likely this is necessary. I tell people to turn those off only when we are doing a shader using that channel, but some people mistook it for instructions at all times.
Ahhh!  Then that makes it much easier!  Thanks.
And Erick, thanks for posting the script.
markschum ( ) posted Thu, 08 September 2011 at 1:21 PM
file_472674.txt
#set reflection lite multi off   import poser mats = poser.Scene().CurrentFigure().Materials() for mat in mats:     nod = mat.ShaderTree().NodeByInternalName("PoserSurface")     inp = nod.InputByInternalName("ReflectionLiteMult")     inp.SetFloat(0)     mat.ShaderTree().UpdatePreview() poser.Scene().DrawAll()
heres one of mine
just copy the line inp = nod...
inp.SetFloat
for the KD value  and you can so both in one script.
madno2 ( ) posted Sun, 11 September 2011 at 3:47 AM · edited Sun, 11 September 2011 at 3:52 AM
file_472750.txt
I changed the script of markschum so that it does ignore materials that do not have "...Mult" attributes. Should now work with VSS loaded and BB's sphere with the gradient material.
EDIT: Name of script is misleading: ReflectionKdMult will also switched off by it.
EDIT 2: Ahem, I am not sure if it really was the markschum script initially. Could have gotten it from another kind soul here.
