Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
It only affects things plugged into reflection color, so it is not likely this is necessary. I tell people to turn those off only when we are doing a shader using that channel, but some people mistook it for instructions at all times.
Quote - It only affects things plugged into reflection color, so it is not likely this is necessary. I tell people to turn those off only when we are doing a shader using that channel, but some people mistook it for instructions at all times.
Ahhh! Then that makes it much easier! Thanks.
And Erick, thanks for posting the script.
say." - Ghandi
heres one of mine
just copy the line inp = nod...
inp.SetFloat
for the KD value and you can so both in one script.
I changed the script of markschum so that it does ignore materials that do not have "...Mult" attributes. Should now work with VSS loaded and BB's sphere with the gradient material.
EDIT: Name of script is misleading: ReflectionKdMult will also switched off by it.
EDIT 2: Ahem, I am not sure if it really was the markschum script initially. Could have gotten it from another kind soul here.
Is there a script to delete "Reflection Lite Mult and KD Mult from all material zones of all items in the scene at once? Having to do it one material zone at a time, for so many figures and props is a real PITA!
