Thu, Feb 20, 7:52 AM CST
Forum Moderators: RedPhantom
Subject: PoseMorphLoader/Autofit Looking for smoke test help at this weekend
Letterworks ( ) posted Mon, 24 October 2011 at 11:48 PM
The converted clothing can be exported using the included exporter and adjusted in your modeler of choice then re-import the corrected morph. You can also use poser's built in morph tool, but I find this isn't as versatile as a modeler for larger or more complicated adjustments, but works great for minor adjustments for poke thru and some smoothing. As with any of the morph/shape transfer tools it's necessary to do a bit of external work for perfect looks, but the "out of the box" conversion is a great starting point. It also fits to posed figures, morphed or base shaped, which is a great feature for still renders, although again it's not always a one step process, depending on the clothing and just how realistic a shape you are looking for. It's uses for content creation can't be over rated. How much use the average artist will get depends on their expectations and skill.
arcebus ( ) posted Mon, 24 October 2011 at 11:50 PM
I guess it'll be simply impossible to beat all rats that come with morph transitions and the infinite possibilities that sit in there.
Any mathematical solution will always be an approximation. Luckily, thus the modelers amongst us won't get redundant.
www.skin2pix.com
arcebus ( ) posted Mon, 24 October 2011 at 11:52 PM
Quote - It's uses for content creation can't be over rated. How much use the average artist will get depends on their expectations and skill.
Well put.
www.skin2pix.com
colorcurvature ( ) posted Tue, 25 October 2011 at 12:18 AM
Here you also see an example of failure:
colorcurvature ( ) posted Tue, 25 October 2011 at 12:20 AM · edited Tue, 25 October 2011 at 12:21 AM
To make it a bit better I disabled the morph on the legs, and smoothed the transitions with morph brush. The render on the right above is without postwork.
colorcurvature ( ) posted Tue, 25 October 2011 at 12:23 AM · edited Tue, 25 October 2011 at 12:24 AM
And here is what I said about bangs. An idea would be to move them out of the face before refitting, with a bit of luck you can still again dial them after refit finished. It depends a bit how far away source and target are.
colorcurvature ( ) posted Tue, 25 October 2011 at 12:27 AM · edited Tue, 25 October 2011 at 12:28 AM
Tight things tend to reflect the body shape. What is good about is that they will reflect the figures JCMs when fitting into a pose. Here you see how the common shoulder problem evaluates. The shoulder gets nice, but on the armpits, you see the known bending problem reflect into the cloth. I did not yet try how it looks when Corvas fix morphs are active before refit.
Rose2000 ( ) posted Tue, 25 October 2011 at 12:29 AM · edited Tue, 25 October 2011 at 12:29 AM
Colorcurvature... That looks like an awesome tool for us poser users.. :)
colorcurvature ( ) posted Tue, 25 October 2011 at 12:30 AM · edited Tue, 25 October 2011 at 12:31 AM
The tightening can sometimes help, I think. But no doubt, when tightening is strongly used, it will finally degregate into a second skin and/or suffer from pokes.
colorcurvature ( ) posted Tue, 25 October 2011 at 12:35 AM
Hair prop tightening, to compensate differences in size.
colorcurvature ( ) posted Tue, 25 October 2011 at 12:54 AM
And I assume that of course the DAZ refitter is a far more advanced tool. No doubt. But I refuse to shift to DAZ because it doesnt have a python interface for me :). I also came in doubt about genesis, because of the morphing joints and weight map joints we will be more able to create custom characters easily, and with a bit of refitting, should it work which I hope, I think one can get some quite decent results still. And Gen4 meshes still have more polys, which I also like. I do not know when SR1 comes out, but I heard philc posted a script somewhere to convert a whole figure to weightmaps. Should they, maybe in a SR2, also allow python access to the individual weight data (to get or set it), then you could also blend smoothly across shapes without destroying the entire rig, I think. Either way, I think I'm done with regard to the refit for now. There are advanced methods that I can think of, but one milestone after the other. There is one memory leak I have to investigate, and to evaluate about shoes and gloves. Are there any free gloves somewhere? Regarding availability in a store: I am very careful with stores. I'd rather sell a few copies cheap through paypal with money-back-if-not-happy option, to find out if it would actually be regarded as a a benefit or not. I won't push a thing to a market place that doesnt create at least a bit of happiness. A small charge I would ask, to cover a part of my expenses and the burden of making it "round", and I will need some resource to research for a cross-fitting solution.
alexcoppo ( ) posted Tue, 25 October 2011 at 1:19 AM
Quote - Regarding availability in a store: I am very careful with stores. I'd rather sell a few copies cheap through paypal with money-back-if-not-happy option, to find out if it would actually be regarded as a a benefit or not. I won't push a thing to a market place that doesnt create at least a bit of happiness. A small charge I would ask, to cover a part of my expenses and the burden of making it "round", and I will need some resource to research for a cross-fitting solution.
After having read a lot of horror stories about PayPal, I would not buy the Graal even if it was offered for 1$ if it was available only thru PayPal. Please consider solutions which can be accessed thru credit cards.
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
bwldrd ( ) posted Tue, 25 October 2011 at 8:13 AM
... Just waiting for the word when it is available. Lol.
Consider me insane if you wish, but is your reality any better?
arcebus ( ) posted Tue, 25 October 2011 at 9:03 AM
Quote - After having read a lot of horror stories about PayPal, I would not buy the Graal even if it was offered for 1$ if it was available only thru PayPal. Please consider solutions which can be accessed thru credit cards.
Not that this would belong here, but I'm using PayPal since 2005 for an average of 40 transactions ( 2-5 purchases, the rest sales) per week, without one single problem.
www.skin2pix.com
WandW ( ) posted Tue, 25 October 2011 at 9:39 AM
Hi Hannes,
Anton has some free gloves as part of the Apollo Epic Clothing Vol. 2  (the zip password is above the download links)...
http://www.antonkisieldesigns.com/~akfiles/htmlpages/ApolloMaximusFree3dhumanfigure.htm
I held off getting PML this past summer because I wanted to see what was new in the new Poser; I'm looking forwared to getting this added functionality... 😄
As far as PayPal goes, I've been using it for nearly ten years for hundreds of purchases and have never had a problem.
Afrodite-Ohki ( ) posted Tue, 25 October 2011 at 11:32 AM
This is so full of WANT. Really really WANT.
Feel free to call me Ohki!
pjz99 ( ) posted Tue, 25 October 2011 at 12:34 PM
Batman approves!
My Freebies
colorcurvature ( ) posted Wed, 26 October 2011 at 1:18 AM
I am extremly short on time these days :(
What I liked with paypal is that there is a "send money back to sender" button.  Thats all.
For Apollo Gloves, I could only do a short try but it seems to work. His cloths seem to have all the morphs already, but these were not dialed here. His fingers are spread when zeroed, that is also a good thing as the refitter can learn the proper shape more easily
Madbat ( ) posted Wed, 26 October 2011 at 7:43 AM
Oooh, I like it, I like it!
colorcurvature ( ) posted Thu, 27 October 2011 at 11:14 AM
Totally crammed with work currently. Please excuse if I could not reply to emails. Its one more power-week to go at work and I must focus on that. But then we are good to go, I am happy with the features how they are and thats it.
If one really needs to, with a little extra effort one can xeno-refit with a helper figure. I box-modelled that in blender with a subsurface modifier and the shrink wrap/mesh relaxation, and I can adopt this dummy head to any figure in blender within a few minutes. After that is done, one can use the helper to refit xeno.
Afrodite-Ohki ( ) posted Thu, 27 October 2011 at 11:18 AM
CC, just to let you know I'm trying to morph V4's body into Antonia's shape for you. Wish me luck, those fingers are already becoming nightmare fuel for me LOL
colorcurvature ( ) posted Thu, 27 October 2011 at 11:30 AM
Oh wow :). I think its not so urgent with fingers because most cloth do not come near them. This looks impressive already. If the body somehow matches that wuld be enough for a proof of concept test :) can you email this to morph to me somehow? Cheers!
Afrodite-Ohki ( ) posted Thu, 27 October 2011 at 11:50 AM
When I have a full body shape (going in sections here), I'll turn it into a FBM injection and send it your way ;)
Afrodite-Ohki ( ) posted Thu, 27 October 2011 at 6:15 PM
Hey, CC, PML has an option to ignore+correct vertex orders, right?
The tools I'm using here don't allow symmetry... so the whole thing is asymmetric. Was wondering if I could cut it in half then mirror the entire geometry...
colorcurvature ( ) posted Thu, 27 October 2011 at 11:29 PM
If its a bit asymetic it won matter so much i hope. I also have a morph symmetry script. Hope it works on antonia.
Afrodite-Ohki ( ) posted Thu, 27 October 2011 at 11:33 PM
It's actually VERY asymmetric. I'm using Zbrush's Zproject tool for a tight fit, and it behaves very badly with symmetry, so I switched symmetry completely off.
How does the morph symmetry script work? Depending, it might be just what I'm looking for - for way too many projects.
colorcurvature ( ) posted Fri, 28 October 2011 at 11:58 AM
It aligns morph deltas across the x-axis. But requires the base figure to be perfectly symmetrical. I found that only that basic human figures are symmetrical. maybe antonia is, we might investigate.
colorcurvature ( ) posted Fri, 28 October 2011 at 12:07 PM
OK release candidate is done, 32 and 64bit.
Known problem left: memory consumption. Restart of poser frees memory though. I do not know when I have the time to fix everything and make a nice manual.
But for private use, I think it should still do good, hopefully.
Some early couragous buyers wanted :D.  Like said, paypal would be preferred, because I can easily refund you. $19 for both reverse deformation morph loader plus my autofit experiment. But for personal usage only until it has proven its doing well. No warranty, whatsoever. If interested, mail pml2012 at colorcurvature.com.
Poser Pro 2012 required. P9 is untested. The cloth refitter is not super-automatic like DAZ tools. You have to setup your figure/cloth twice, as shown earlier in this thread.
If there are some that would buy it and if you are happy, I would aim at getting it into a marketplace/rendo again, otherwise you get your money back and I retire :).
Afrodite-Ohki ( ) posted Fri, 28 October 2011 at 12:19 PM
Gotta wait till I get paid from here Rendo and RDNA so I have some paypal money - dollars are ridiculously expensive for us brazilians right now.
ghostman ( ) posted Sat, 29 October 2011 at 6:04 AM
Would love to test this one. :)
Email sent. :)
Ghostman
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
Cage ( ) posted Sat, 29 October 2011 at 12:12 PM
Antonia is symmetrical, at least within tolerable limits.  I've used morph symmetry scripts with the figure frequently.
colorcurvature ( ) posted Sat, 29 October 2011 at 1:20 PM
Ah thats good. When I fought with symmetry, I came to the conclusion that its a very interesting and challenging problem indeed. The DAZ4 were perfectly symmetrical. That helps a lot. If lots of noise is in it, then its very difficult to automatically find a good seed out of which the symmetry relation of the rest can be computed.
Other thing:
Anybody knows if we can get genesis out of DAZ with the (hidden) M4 V4 morphs? These could be used to refit cloths.
bblogoss ( ) posted Sat, 29 October 2011 at 1:30 PM
Impressive !!
I want it, e-mail sent ;)
yapaplukon ( ) posted Sat, 29 October 2011 at 3:23 PM
Damn... This seems a very good job, indeed !
When do u intend to release on the marketplace ?
colorcurvature ( ) posted Sun, 30 October 2011 at 3:52 AM
After I got some feedback, I think. I also wanted to check wether I could make a xeno-refit bodysuit that could be used for an easier refit among different figure types. Like from M4 to apollo. like in the pic above where I refit onto andi which such a helper cloth.
GeneralNutt ( ) posted Sun, 30 October 2011 at 10:13 AM
Awesome, must have tool for poser.
colorcurvature ( ) posted Sun, 30 October 2011 at 11:03 AM · edited Sun, 30 October 2011 at 11:08 AM
I think a refit-bodysuit would be a good thing to have. Here is a first attempt to go from V4 to Antonia. To do this, I made a body suit for antonia in blender, then shrink-wrapped it in blender onto V4. The item was made for V4.
colorcurvature ( ) posted Sun, 30 October 2011 at 11:07 AM
The refit-suit. What I think is to have an "open-sourced" refit suit that can be adopted to each figure with middle effort, so that everything is fittable to everything. Not sure if it would work, though :). And how to host such a thing, it would need frequent updates. Maybe on github, or something.
Afrodite-Ohki ( ) posted Sun, 30 October 2011 at 11:08 AM
Does that mean you won't need me to finish that Antonia-shape morph for V4 anymore?
colorcurvature ( ) posted Sun, 30 October 2011 at 11:17 AM
Just refitting the refit suit with the shrinkwrap takes only a couple of minutes, but has some weakness. I think one has to assure that the most important body points correlate smoothly. A direct projection of one mesh to the other tends to move some points not as intended. If I had a more beautiful fit for the refit suit, the outcome would come out better. So, the problem is to morph the refit suite properly. But its a managable task I would think.
colorcurvature ( ) posted Sun, 30 October 2011 at 11:19 AM
@Afrodite-Ohki: It would be very interesting to compare the results. Can you email me what you already have made?
Afrodite-Ohki ( ) posted Sun, 30 October 2011 at 11:55 AM
It's not done... can do it today though, already have Zbrush open fixing something else. But would you take care of making it symmetrical? Or how would I do that with PML, could I delete a side and mirror the other to replace it? If so, what options in PML should I use to make that work?
esha ( ) posted Mon, 31 October 2011 at 5:53 AM
Colorcurvature, you're my hero 👍 :thumbupboth:
I'm especially interested in the morph loader. I heard it allows to import a morph target onto a posed and/or morphed figure. I really hope that's true because I was so missing this functionality in Poser! 🤤
Please keep us updated on your progress, I'll definitely buy it as soon as it's available :biggrin:
Afrodite-Ohki ( ) posted Mon, 31 October 2011 at 9:35 AM
Quote - I'm especially interested in the morph loader. I heard it allows to import a morph target onto a posed and/or morphed figure. I really hope that's true because I was so missing this functionality in Poser! 🤤 Please keep us updated on your progress, I'll definitely buy it as soon as it's available :biggrin:
That functionality exists since the previous version of PML, which I used a lot. Works amazingly well ;)
esha ( ) posted Mon, 31 October 2011 at 10:01 AM
If I had known that earlier, it would have saved me a LOT of problems...
But it seems I'm living behind the hills, never noticed this script before people started mentioning that it would be reworked for P9+ g
bblogoss ( ) posted Mon, 31 October 2011 at 10:17 AM
The refitting works on the Genesis CR2 export :)
On left zero shape and a custom morphed shape on the right.
bblogoss ( ) posted Mon, 31 October 2011 at 11:17 AM
Refitting to basic Child
colorcurvature ( ) posted Mon, 31 October 2011 at 12:00 PM
Ooh :) that is super!!  Now i want genesis too >_<
bantha ( ) posted Mon, 31 October 2011 at 12:40 PM · edited Mon, 31 October 2011 at 12:41 PM
Just get Daz Studio 4, Genesis is included. It's still free if I'm not mistaken, the base version is enough.
-"Amazing Grace" Hopper
bblogoss ( ) posted Mon, 31 October 2011 at 2:22 PM
5 morphs of Genesis all made in poser.
  1. From DAZ Victoria 4 Basic wear refited first for Genesis in DAZ Studio with autofit
  2. I export the refited clothing as OBJ and import that OBJ in Poser to setup a conforming cloth for the CR2 Genesis.
After that you can morph your Genesis as you want and use PML2012 to fit your custom morph.
