Tue, Jan 21, 1:30 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Using symmetry when adding new spheres to existing vertex model?
diomede ( ) posted Wed, 04 January 2012 at 8:45 PM · edited Fri, 17 January 2025 at 10:00 PM
This is my first attempt to model a human.  I am using Carrara 8 pro.  I don't have ZBrush or anything like that.  I've used symmetry and the extrude tool with some success.  Now that I have the basic form, I am adding details. I want to keep everything symmetric, but I also want to add spheres for the eyes.  The eyes in the pic are primitives just to see what it would look like (and the hair is Amy hair from DAZ).
If I already have a symmetric model in the modeling room, is there a way to use the  Construct, add Sphere tabs and still maintain symmetry for the eyes?
ProPose001 ( ) posted Thu, 05 January 2012 at 2:00 AM
I am doing the exact same thing.  Modeling a character entirely in Carrara.  For the eyes I ended up creating a separate vertex object, aligning it carefully and then duplicte the eye with symetry.
GKDantas ( ) posted Thu, 05 January 2012 at 5:04 AM
Yes, dont use mesh for the eyes inside the base mesh. If you do that you cant animate it without using ONLY morphs. When you nested a eye ball to the mesh in the Assembler Room, its more easy to control the eye position and move it.
Follow me at euQfiz Digital
diomede ( ) posted Thu, 05 January 2012 at 7:53 AM
Thanks. I won't nest the eyes within the base mesh. Eye morphs are vital.  Are there other similar best practices.?  Teeth?  What else?
GKDantas ( ) posted Thu, 05 January 2012 at 9:17 AM
In animation we use targets for the Eyes. So you add a Target Helper to point the eyes to the right position, thats why the eye are parented to the base mesh. Morphs in eyes are used to adjust pupil morphs and other things.
If you use to model the eye inside d emesh, you can create one and simple duplicate the mesh, in this case you will need to use bones to animate them.
Teeth can be a mesh inside the base mesh, since exopressions are based in morphs too, so you can adjust the teeths according to the morphs.
UVDan ( ) posted Sat, 21 January 2012 at 1:40 PM
Forum Moderator
Nice job on the human female model.
