Hmm, I had downloaded those but had not read that some of the material were built using SSS. I'll check that out. But I'm still waiting to see if some material guru will come and give an opinion. I could try using BB's Scatter + Blinn set up on the coat and see what it looks like.
Weapons of choice:
You could also add the Poser SSS in the material room to see what it looks like.
Quote - You know, it wouldn't be too hard to use EZSkin to add SSS to a leather coat - just treat it as another figure.
Hee hee, talk slowly and use small words when you explain how to do that! :)
Weapons of choice:
EZSkin allows users to add support for additional figures by adding definitions to the ezskin.xml file included with the distribution. Instructions for doing so are in the readme.txt file in the zip file.
There's no reason why a leather coat couldn't be treated as another figure. After all, leather is skin, sort of :-)
I'm happy to help more if you need it, but if you fancy giving this a try I suggest you have a go yourself first (it's quite easy, I think) and then if you get stuck at any point you can ask for specific help then.
Free stuff @ https://poser.cobrablade.net/
I guess what you have to figure is not just the node set up for an sss leather but also the parameter values. I mean yes leather is skin, but it possibly doesnt have the same qualities as living skin which the sss skin shaders are designed to approximate. I'm just a bit lost as to where to start defining the properties it may have.
Weapons of choice:
Okay, totally frustrated now. None of the trench coats that I have will work for this project. I even tried two that I had converted from M3 with Crossdresser. So, if any modelers are out there, please look at the photo I posted. I want a coat similar to that. Closed on the front with a few straps. Tight in the arms and chest and flairs out at the bottom, and ankle length! Not calf length, not knee length--ankle length, nearly brushing the floor. Thanks, rant over. :)
Weapons of choice:
Hello,
I tried that as well, as leather is made of skin. See for example the render here: http://www.renderosity.com/mod/gallery/index.php?image_id=2286957&user_id=475250&np&np
(Cannot post nodes right now, as the scene is on another computer, will post them later).
Don't overdo the SSS effect, as leather is quite thick.
Best regards,
Michael
Probably not exactly what you're after, with wanting to have an SSS node in leather, but I'll just throw it in anyway ... just in case =)
Have you tried BB's Leather?
To be found here: http://sites.google.com/site/bagginsbill/free-stuff/leather
Quite amazing stuff, very flexible and versatile, I might add :)
Weapons of choice:
i tried using the material room wacro to add SSS to a dress.
the node says skin scatter, but it doesn't have the drop down arrow for skin, apple, etc options.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
I am working on an M4 character and the duster coat is a very important part of the character's persona. I just wondered if you could use P2012's SSS on a leather coat and how would the shader be set up?
Weapons of choice:
