Sun, Nov 24, 4:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 1:33 pm)
Subject: SSS On a Leather Coat?
Latexluv ( ) posted Wed, 15 February 2012 at 5:33 PM · edited Thu, 21 November 2024 at 7:55 PM
I am working on an M4 character and the duster coat is a very important part of the character's persona. I just wondered if you could use P2012's SSS on a leather coat and how would the shader be set up?
Weapons of choice:
meatSim ( ) posted Wed, 15 February 2012 at 5:40 PM
I dont know.. but I'm listening for an answer.. I've been wondering  for a while about how to incorporate sss in clothing materials
Glitterati3D ( ) posted Wed, 15 February 2012 at 5:45 PM
Perhaps not an answer, but you might want to take a look at this freebie.  He/She used SSS on the materials, and they are a lovely addition to any runtime:
http://www.renderosity.com/mod/freestuff/details.php?item_id=67396
Latexluv ( ) posted Wed, 15 February 2012 at 5:56 PM · edited Wed, 15 February 2012 at 5:57 PM
Hmm, I had downloaded those but had not read that some of the material were built using SSS. I'll check that out. But I'm still waiting to see if some material guru will come and give an opinion. I could try using BB's Scatter + Blinn set up on the coat and see what it looks like.
Weapons of choice:
Glitterati3D ( ) posted Wed, 15 February 2012 at 6:05 PM
> Quote - Hmm, I had downloaded those but had not read that some of the material were built using SSS. I'll check that out. But I'm still waiting to see if some material guru will come and give an opinion. I could try using BB's Scatter + Blinn set up on the coat and see what it looks like.
You could also add the Poser SSS in the material room to see what it looks like.
Snarlygribbly ( ) posted Wed, 15 February 2012 at 6:10 PM
You know, it wouldn't be too hard to use EZSkin to add SSS to a leather coat - just treat it as another figure.
Free stuff @ https://poser.cobrablade.net/
Latexluv ( ) posted Wed, 15 February 2012 at 6:15 PM
Quote - You know, it wouldn't be too hard to use EZSkin to add SSS to a leather coat - just treat it as another figure.
Hee hee, talk slowly and use small words when you explain how to do that! :)
Weapons of choice:
Snarlygribbly ( ) posted Wed, 15 February 2012 at 6:30 PM
EZSkin allows users to add support for additional figures by adding definitions to the ezskin.xml file included with the distribution. Instructions for doing so are in the readme.txt file in the zip file.
There's no reason why a leather coat couldn't be treated as another figure. After all, leather is skin, sort of :-)
I'm happy to help more if you need it, but if you fancy giving this a try I suggest you have a go yourself first (it's quite easy, I think) and then if you get stuck at any point you can ask for specific help then.
Latexluv ( ) posted Wed, 15 February 2012 at 7:11 PM
Okay, I'll give that a try tonight. I really want a coat that looks like this one tho.
Weapons of choice:
meatSim ( ) posted Wed, 15 February 2012 at 7:20 PM
I guess what you have to figure is not just the node set up for an sss leather but also the parameter values.  I mean yes leather is skin, but it possibly doesnt have the same qualities as living skin which the sss skin shaders are designed to approximate.  I'm just a bit lost as to where to start defining the properties it may have.
Glitterati3D ( ) posted Wed, 15 February 2012 at 10:07 PM
This is the M4 Cowboy Duster with a leather shader and Poser SSS.
Latexluv ( ) posted Wed, 15 February 2012 at 11:15 PM
Okay, using an older Leather shader that BB made and using the SSS macro, I've got this. The problem, I realized, with this coat, is that it unrealistically has no buttons or button holes.
Weapons of choice:
vilters ( ) posted Thu, 16 February 2012 at 3:51 AM
leather is quite shiney, and light does not go deep in leather as it does in human skin.
Latexluv ( ) posted Thu, 16 February 2012 at 5:10 AM
Okay, totally frustrated now. None of the trench coats that I have will work for this project. I even tried two that I had converted from M3 with Crossdresser. So, if any modelers are out there, please look at the photo I posted. I want a coat similar to that. Closed on the front with a few straps. Tight in the arms and chest and flairs out at the bottom, and ankle length! Not calf length, not knee length--ankle length, nearly brushing the floor. Thanks, rant over. :)
Weapons of choice:
Michael314 ( ) posted Sat, 18 February 2012 at 8:09 AM
Hello,
I tried that as well, as leather is made of skin.  See for example the render here: http://www.renderosity.com/mod/gallery/index.php?image_id=2286957&user_id=475250&np&np
(Cannot post nodes right now, as the scene is on another computer, will post them later).
Don't overdo the SSS effect, as leather is quite thick.
Best regards,
   Michael
Michael314 ( ) posted Sat, 18 February 2012 at 11:55 AM
nodes part 1....
Michael314 ( ) posted Sat, 18 February 2012 at 11:56 AM
nodes part 2 (image was too big to post in one part)
Michael314 ( ) posted Sat, 18 February 2012 at 12:01 PM
Hello,
some final explanations: (units were meters), the image map node is just a regular tilable leather texture (I think from the set "PD into leather" here at RMP).
Color can be tweaked as required.
Best regards,
   Michael
ErickL88 ( ) posted Sat, 18 February 2012 at 12:04 PM · edited Sat, 18 February 2012 at 12:06 PM
Probably not exactly what you're after, with wanting to have an SSS node in leather, but I'll just throw it in anyway ... just in case  =)
Have you tried BB's Leather?
To be found here: http://sites.google.com/site/bagginsbill/free-stuff/leather
Quite amazing stuff, very flexible and versatile, I might add :)
Latexluv ( ) posted Mon, 20 February 2012 at 7:29 PM
Okay, test render one of the Glitterati coat!
Weapons of choice:
Glitterati3D ( ) posted Mon, 20 February 2012 at 7:37 PM
And, one I did with a standard texture with Poser SSS applied.
GeneralNutt ( ) posted Mon, 20 February 2012 at 8:05 PM
Great looking model!
Latexluv ( ) posted Mon, 20 February 2012 at 11:46 PM
Okay, I made a quickie texture and combined it with one of BB's Leather Shaders and got this.
Weapons of choice:
Glitterati3D ( ) posted Tue, 21 February 2012 at 1:55 AM
Quote - Great looking model!
Thanks, GeneralNutt!
Latexluv ( ) posted Tue, 21 February 2012 at 2:32 AM
Been having fun testing out the coat all day! I found that Kobaltkween's Metalic Lycra shaders look nice on the coat too, but I wanted leather. I've now got the character in the scene he's supposed to go in. I know you're supposed to use one infinite for sunlight but it sure doesn't look like sunlight to me.
Weapons of choice:
Glitterati3D ( ) posted Tue, 21 February 2012 at 11:52 AM
The Leather Coat for M4 is in Rendo freestuff now, so anyone who wants to play around can.
MistyLaraCarrara ( ) posted Tue, 21 February 2012 at 11:58 AM
i tried using the material room wacro to add SSS to a dress.
the node says skin scatter, but it doesn't have the drop down arrow for skin, apple, etc options.
JAFO ( ) posted Tue, 21 February 2012 at 11:59 AM
Quote - The Leather Coat for M4 is in Rendo freestuff now, so anyone who wants to play around can.
grabbin it now TYVM
:O)
JAFO
Y'all have a great day.
Eric Walters ( ) posted Tue, 21 February 2012 at 10:31 PM
There is a leather shader that comes with PPro2012. I don't know if it is in P9.
JAFO ( ) posted Wed, 22 February 2012 at 9:36 AM
did you guys check out Michael's gallery?  im no expert but his leather looks spectacular to me....just sayin...
:O)
JAFO
