Sat, Jan 11, 3:18 AM CST
Subject: problem with transparent walls
xpdev ( ) posted Wed, 04 July 2012 at 2:55 AM · edited Tue, 07 January 2025 at 3:21 PM
as seen from the image using an external light source, the walls are almost transparent to light (shade of light to 1.000)
in view of the outer wall is invisible to afford to work.
There is possibility to solve the problem, otherwise it is impossible to use an external light.
thanks
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
outside view
3-d-c ( ) posted Wed, 04 July 2012 at 5:44 AM
i assume you use a single polygon facing inside the room. that means you backlit the polygon from the other side. i would highly recommend you use another polygon facing outside to ensure proper shadow casting. Backfacing polygons dont cast proper shadows...
3-D-Cs Facebook Page: 3-D-C on Facebook
Check the K-Azonica Story and World Evolving:   K-Azonica
Check my website and products and the large freebie section:   3-D-C
xpdev ( ) posted Wed, 04 July 2012 at 6:38 AM
I have not designed the model, how do I fix it?
thanks
3-d-c ( ) posted Wed, 04 July 2012 at 9:48 PM
its a design question...
you can probably try to reduce the minimum shading rate and increase the indirect lightning quality. but i dont think this would resolve the problem at all....
WandW ( ) posted Wed, 04 July 2012 at 10:06 PM
Can you put a square primitive back there to cast a shadow?
xpdev ( ) posted Thu, 05 July 2012 at 1:18 AM
"Can you put a square primitive back there to cast a shadow ?"
it would be possible, but in many places the walls have a complex shape and then the frames of the windows have the same problem.
