Did the installer work for you?
Yes the installer work for me. I use Vue 11 Infinite you must downlod the Vue 11 xStream** **patch.
Mazak
the import is improved of poser genesis, however the skin is still all wrong. eyes look okay but the skin looks like the UV is wrong or something.
Love esther
I aim to update it about once a month. Oh, and it's free!
even keeping poser textures doesn't help. The same problem with the skin occurs.
Does this happen with every figure?
As far as I know it only happens with the new DAZ Genesis figures; Victoria 5 and Michael 5. Importing as an OBJ doesn't help either. Vue Tech support have known about the problem for quite a while. I now use DAZ Studio for those charcters.
Adriaan Barel (a.k.a. Vege
Mite)
"Morality, like art, means drawing a line someplace." --
Oscar Wilde
I have only tested michael 5 and victoria 5 and it happens with them. I was hoping the new beta would fix it but although the geometry looks far better in vue than it did with the previous version, the texture on genesis look like I showed you in the pic.
Mazak
well I used the mec4d script to convert my M5 to M4 UV map and applied a M4 texture that looked fine in poser, but did not import into vue. I haven't tried V4 texture on V5 yet though.
Love esther
Okay I used same script to make the genesis figure take V4 textures, and the V4 textures weren't perfect ie you could see a faint line between the forearm and arm etc but the big white patches were gone.
However after Imoprhed her I had clothing poke thru, so I ran the morph follower script and now when the figure renders in vue you get a double figure with one in default position. although the preview image doesn't have this.
Love esther
Masai your textures aren't perfect. look closely at her arms. U can see faint lines where different texture maps meet.
Love esther
PS did you get my PM the other day?
Oh I think I know why the render turned black. It's because I should have kept poser materials as I did some tooning. I think
Yes, just tried itin one of the sample scene 3 and it is fine. Have you selected the correct poser SDK and folder.
I have 56GB of RAM. I don't know if it helps or not. Perhaps a different video card would help more.
NEW Beta:
Vue 11 Infinite - Build 11004282 - BETAThe following is a list of bug fixes and improvements included in this update:
Publishing Date: Public Beta: 12/21/2012
Mazak
This is the Grizzly I have. It's the one with Poser hair.
http://contentparadise.com/productDetails.aspx?id=13961
Mazak
Ja the Vendor has moved to CP. I purchased the item here at renderosity too. Google is your friend.. hrhrhr :D
Mazak
Attached Link: http://www.e-onsoftware.com/resources/?page=updates
Vue 11 Infinite - Build 11003442 - BETA The following is a list of bug fixes and improvements included in this update:Publishing Date: Public Beta: 11/23/2012
Google+ Bodo Nittel
