DAZ|Studio F.A.Q (Last Updated: 2025 Jan 08 8:49 pm)
For each material zone I apply the tattoo mask as follows
displacement strength 100%, 0 min max 0.3
Ambient color - no mask - just choose color. for this I use RGB 0 117 175
Ambient strength, use mask and crank value to 300% . you have to change limit in parameter settings
Subsurface color - use mask and set color to same as ambient color. subsurface strength is 50%
You can change bump and specularity to personal pref without influencing tatt too much.
Hello Medzinatar--
OH WOW! This looks awesome. Can you email me at: celticknight01@gmail.com please.
Though I use D|S, I'm lacking the knowledge you have on this and am lost. LoL
I'd like to replicate this but, I'll need step by step directions and how you did what, in what program.
THANK YOU a bunch!
i want a step by step tut for this too!!
did you do lie first? then the above?
where did you put the png images??
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
Another person sent me this explantion t othe above and I was able to figure it out.
You have to find the textures in the folder with the other character textures. I put the effect maps should be black with white glow effects image in the ambient channel for each body part, then change the ambient color to the color you want and turn it up to 100%...or higher pending color you are looking for.
The colors for the glow are not always what they seem. I had to go blue in order to get a purple glow.
Also FYI..you will NOT see the actual effect until you render it. This through me for a loop at first as I thought I would see it as i was adjusting each section. You will just have a color over your image with no engravings showing. Once you render, then you'll see what you have and can adjust as you need.
I apologize if this is not the correct forum. Wasn't sure where to post this question.
I was wondering if anyone who has PD Gabriel, figurd out a way to use the Engraved mat even though Petra says it will not work? I tried emailing Petra/PD but not have heard back. All the other mats work fine. just wondering if anyone has found a way to get it to work.
Thanks
Ghriogair
