Tue, Oct 1, 9:40 PM CDT
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Sep 29 9:06 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: What do I clean this up with (bezier curve to flip-flip sole disaster)
klown ( ) posted Thu, 28 March 2013 at 3:00 PM · edited Tue, 01 October 2024 at 9:39 PM
I posted this over at the blender forums but I'm asking here too since the prop will ultimatly be a studio/poser prop for free if it works and the answer may take someone familair with those apps whereas the blender crew doesn't venture too far out of blender for the most part.
Ok, so I made this sole using a bezier curve in 2D, then extruded the live curve, added a slight bevel and converted it to a mesh but doing so it makes these crazy-ass faces.
What tool would a noob go about using to clean this up so it does not render like crap, because it renders like crap and I'm exporting this out to OBJ and rendering in something like poser or daz studio as the native obj file
thanks!
heddheld ( ) posted Fri, 29 March 2013 at 2:01 AM
looks to me like you have modeled the holes for the "thong" bit ? you dont need them(unless your doing an extreme  close up of theflip flop) and mesh will be a lot cleaner without them
unbroken-fighter ( ) posted Fri, 29 March 2013 at 4:26 AM
one major issues you will have is the use of long,thin triangles
poser hates them and distorts them badly
hedheld is correct that they dont need to be so detailed as to include the holes because unless you intend for photoreal renders they will never be seen
the triangles kill in poser and id guess in studio as well since i do not use the program
retrace the steps with palnar modeling and you should be fine
Touchwood ( ) posted Fri, 29 March 2013 at 5:34 AM · edited Fri, 29 March 2013 at 5:35 AM
A manual cleanup is really the only way if you want to keep the detail.
Alternatively, you can make the sole a seperate object and use the shrinkwrap modifier to fit to shape. Add a cube and make sure it is a little larger than the sole and has enough subdivisions to get the detail then add the modifer to the cube. The cube mesh will shrink to fit.
Hope that helps.
klown ( ) posted Fri, 29 March 2013 at 10:50 AM
doing a closeup, photoreal, holes required, otherwise I'd use someone elses model.
@touchwood, never used shrinkwrap, I'm still noobing with blender on and off my not retaining everything I learn until I do it like 50 x.
ok, I went a tried shrinkwrap, it's picking up some bad geometry from the holes I cut and I noticed so I may start over with that part.
heddheld ( ) posted Fri, 29 March 2013 at 3:27 PM
well if you must have the holes the best I can sugest is keep the outside curve, make the holes and build the faces out from the holes to join with curve, it will be boring but you will get a clean mesh
have fun
ps I wanna see the pic lol (if I can) cant think of a pic where the flipflop is the important bit ;-)
unbroken-fighter ( ) posted Sun, 31 March 2013 at 12:48 AM
if you still need help post a link to the mesh and i can walk you through the fastest fix for what it is at origin
basicly delete loops but you need to keep some common points
the edges look to be ok from the posted image but without seeing the real mesh its a crapshoot
you could duplicate it SHIFT+D and in editmode change tris to quads , remove doubles. and smooth manualy but i do not know the mesh
the holes have waaaayyyyy too many loopcuts to be effective
im not knocking the modeling but for studio and poser its too heavy, theres too much to render
poser hates long thin anythings, and even now with blender working correctly in non-gnoms it even worse
klown ( ) posted Wed, 03 April 2013 at 10:17 PM
I went in over my head, and I posted a freebie but the poly count was insane. I went back to the drawing board and did it all in box modeling and kept my poly count down and should have something by morning, though not a flop flop.
thanks for the help everyone.
unbroken-fighter ( ) posted Thu, 04 April 2013 at 12:59 AM
i tend to do everything in mass scale and mass poly counts so dont freak on it
make what you make and if people like it they are happy and if they dont    who cares?
heddheld ( ) posted Thu, 04 April 2013 at 8:20 AM
lol I prefer low poly but sometimes its hard to get "right" shape without a lot of polys
anyhow heres my idea of how to keep poly count down ;-) maybe give you some ideas for the future, has 538 polys at the mo' so 1 subD would push it to a couple of thou then the strap would push it to about 5,000 but with some practise I could maybe get it a bit lower
(yes I know its not quite right shape but I just wanted to see the best way to make it )
klown ( ) posted Thu, 04 April 2013 at 9:21 AM
Sorry if this is a long post, I'm aware rendo is not my personal blog but I've just simutanously drank a bottle of coke and had a huge cup of coffee, but I tacked the solo to "Hey Joe" and nailed that too. Hey, when did Rendo get rid of spell check? My speelling is a train wreck.
The method to my madness is
Sole:
box
sub devide box about 5 or 6 times
model the rough shape of the sole
subsurf to 1
smooth shading.
Straps:
all the above and then apply to a curve, which I'm still painstakingly learning
array a fixed number, curve modifier.
export to Daz Studio 4, see all the normals that I hosed, go back into Blender and try and fix.
Modeling with the curve did not work when it came to the surfaces, but it was great for getting the shape in fewer clicks.  I don't know what happened with the first set of polys but the sandals were tanking my Dual Xeon 2.4 with 8GB RAM at work. Granted it's a Mac, on further inspection I saw I had layers of invisible polgyons hidden under other objects. SO DO I JUST CUT THESE OUT AND LEAVE THEM OR DO I CUT THEM OUT AND CLOSE THE FACES EVEN IF THEY'RE NOT GOING TO BE SEEN?
these should hit rendo today, either the fixed version or the ones that have more polys than a pixar character.
http://www.sharecg.com/v/68486/view/5/3D-Model/V4-Star-Sandals-OBJ-File
the next batch are still being worked out, almost ready for frebies. I just wish I didn't wait so long to go back and try to learn Blender.
keppel ( ) posted Sat, 06 April 2013 at 9:36 AM
I downloaded your model from sharecg.  A couple of things stand out.  You can reduce the polycount of your model by more than half by reducing the edge loops of the strap stitching alone.  You have 48 stitches each made up of three braided strands.  If you delete just half of the edge loops of each stitch you will go from around 81,000 faces to around 39,000 faces.  The largest, most visible areas of your model should have the mose detail and the smallest least visible parts should have the lowest detail.  With this in mind the sole parts of your flip flop could have a subdivion modifier applied and the stitching detail reduced as mentioned above would give better balance to your model.  Also look closely at your model and look for areas that will not be seen and delete those extra faces.  For example the top foot support part of your flip flop has an underside that is inside of the model that can't be seen so this can be removed, and the main sole has a topside that is covered by the foot support.  Parts of the stitching that are inside of the strap can be deleted.
When you used the array modifier to create your strap you have ended up with each of the stap "panels" overlapping indicating that you may have used an incorrect offset.  If you modeled your origin strap panel symetrically then using the relative offset set at one should give you a clean array.
Lastly before you export to .obj apply all your modifiers and use the "remove doubles" function to remove duplicate vertices.
My Renderosity Store
Virtual Furnishing
My Portfolio
klown ( ) posted Mon, 08 April 2013 at 7:39 AM
thanks Keppel, I'm still working out how arrays work and still not comforable with them. I thought I had removed doubles but I'm still working out the kinks as and could have probably done the stitching with a displacment map but that means I have to learn how to UV map with Blender. So much to learn.
keppel ( ) posted Mon, 08 April 2013 at 8:56 AM
With your array if your offset is correct then each of the array duplicates will be exactly adjacent to the next which means that you will have overlapping vertices.  When you apply the array modifier then remove doubles you are "welding" those overlapping vertices together.  With your mesh, the duplicates are not overlapping with a small enough threshold so removing doubles will not actually achieve anything.
There is nothing wrong with modelling the stitching just keep the level of detail at the lowest level whilst still achieving the look that you want.
Virtual Furnishing
My Portfolio
klown ( ) posted Tue, 09 April 2013 at 10:27 AM
So remove doubles before applying the modiifer?
keppel ( ) posted Tue, 09 April 2013 at 6:31 PM
No, remove doubles after applying the modifier.  Consider removing doubles as a clean up exercise after the model is done.
Virtual Furnishing
My Portfolio
