Sun, Feb 2, 7:13 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: How do I make a primitive object be a light emitter?
Michaelab ( ) posted Sun, 14 July 2013 at 11:29 AM · edited Sun, 02 February 2025 at 7:10 PM
I inserted a pyramid into my scene and I want it to emit light, like a flourescent light as if the shape itself was light and slightly glowing. How do I do that?
bagginsbill ( ) posted Sun, 14 July 2013 at 11:40 AM
Set Ambient_Color to whatever color you want it to glow at and set Ambient_Value to 1
Michaelab ( ) posted Sun, 14 July 2013 at 11:47 AM
Thanks. I have Poser 9 and if you're meaning the Map Strength % value in the Material Room for the Ambient Value, I can't adjust it. The dial in unmovable at 0%
TrekkieGrrrl ( ) posted Sun, 14 July 2013 at 11:47 AM
Note that you won't get any "halo" effect this way. The object will glow and light up surrounding areas, but it won't get any fuzzy halo to "show" that it's glowing.
IF the glowing halo is what you're after together with the actual lights, I'd suround the pyramid with a slightly bigger duplicate made almost transparent and also with ambient on
Michaelab ( ) posted Sun, 14 July 2013 at 11:48 AM
Oh, I see it in the ambient value in advanced
TrekkieGrrrl ( ) posted Sun, 14 July 2013 at 11:51 AM
Oh yes. ALWAYS switch the Material Room to Advanced. The simple version is practically useless..
luckybears ( ) posted Sun, 14 July 2013 at 9:01 PM
Apply an edge blend node to alt spec then apply an edge blend node to the input of the first. Do a topic search because this has been solved by someone whose name I do not recall, for that reason I'm not putting the image of the nodes here, the credit belongs to someoneelse.
rokket ( ) posted Mon, 15 July 2013 at 12:29 AM
Quote - Apply an edge blend node to alt spec then apply an edge blend node to the input of the first. Do a topic search because this has been solved by someone whose name I do not recall, for that reason I'm not putting the image of the nodes here, the credit belongs to someoneelse.
seachnasaigh is the one who has the aura effect down to a science.
Michaelab ( ) posted Sat, 20 July 2013 at 12:53 AM
Where can I find BB's "Soft Light Studio"?
And, while I did a search for seachnasaigh and found his 'aura' producing posts I have yet to see any node settings. Could someone point me to it?
seachnasaigh ( ) posted Sat, 20 July 2013 at 5:11 AM · edited Sat, 20 July 2013 at 5:18 AM
     Thank you for the compliment, cousin Rokket.  :blushing:
Michaelab, is this a four-sided pyramid, or other?  Smooth-sided or stepped ziggurat style?  I can whip that up with IDL emitter and aura pretty quickly.  But I need to know what version of Poser you are using.  What color is it to glow?
EClark1894 ( ) posted Sat, 20 July 2013 at 6:54 AM
Quote - Oh yes. ALWAYS switch the Material Room to Advanced. The simple version is practically useless..
Depends on what you want to do. I like to use the Simple version to apply texture maps, or make things transparent or sheer. Maybe to cut down on the highlights a bit. but for everything else, then yeah, the advanced version is definitely better.
Michaelab ( ) posted Sat, 20 July 2013 at 8:32 AM
Hi **seachnasaigh** and thank you!
Poser 9, glow color white. I have four of them on this object and they are flattened very elongated pyramids, more the shape of a triangle but essentially so flattened as to be a 2d triangle. Think of their shape more link a long needle and more 2d with pointed end and a flat end. (see attached - the white objects are the flattened pyramids)
I used a pyramid instead of a triangle because when rotated I couldn't see the other side of the triangle but could with a pyramid.
I'll have another set of four where the glow color needs to be blue-white. Blue close to the flattened pyramids and transitioning to white further out if that's possible.
I'm looking for the glow to extend less so on one side (If that's possible) because that side of the pyramids are butted against another object, but if not possible or practical, it can glow on all sides. Glow amount? I guess something like a glow stick, more or less.
Your help much appreciated seachnasaigh.
seachnasaigh ( ) posted Sat, 20 July 2013 at 8:46 AM
     Ah, not a simple pyramid.
     Is this geometry something which you made?  That would require custom fitting an envelope to the shape.
Michaelab ( ) posted Sat, 20 July 2013 at 8:51 AM
It's from the Poser primitives library and I just morphed it to death.
seachnasaigh ( ) posted Sat, 20 July 2013 at 8:57 AM
     That would be distributable then.  It is probably best if you post or send me the prop so that I can tailor an IDL emitter and an aura to it.
     I'll be leaving soon and won't be back until this evening - and then I'll be busy cleaning weapons.  But tomorrow I should be able to work on this.
Michaelab ( ) posted Sat, 20 July 2013 at 8:59 AM
Ok. How and where do you want me to send it?
seachnasaigh ( ) posted Sat, 20 July 2013 at 9:14 AM
PM sent.
seachnasaigh ( ) posted Mon, 22 July 2013 at 11:47 AM · edited Mon, 22 July 2013 at 11:51 AM
Michael, your assemblage of primitives is 128,490 polys. :blink:   That's gonna take a disproportionate amount of memory to render.  I could form that shape using probably less than 2,000 polys with no diminution in shape quality, and even give it a pommel and finger-grooved grip.  Do you want to use your model, or would you like to go with a low poly model?  I don't know how much RAM you have.  I can make an emitter and aura either way.
Michaelab ( ) posted Mon, 22 July 2013 at 12:08 PM
Well, as you can see, the curved sections I cut out of two other pyramid shapes. I used PhilC's scissors. But to get anywhere near to the cut I wanted I had to use his application to increase the poly count.
Would love a pommel and finger groove grip as an optional grip. Let's try your low poly model and see what comes out of it. Thanks!
Michaelab ( ) posted Mon, 22 July 2013 at 12:17 PM
BTW seachnasaigh, I'm trying to get a metallic gold texture on this (except for the edges, of course). Maybe it's the lighting but I just can't seem to get it to sparkle or shimmer like gold would do in the light.
I would like a gold like this:
http://images.wikia.com/olympians/images/9/98/Sword_of_imperial_gold_by_corellastudios-d37zl6s.png
or:
http://25.media.tumblr.com/dfcc7d56bc77f1cdb200eb3556b4d95b/tumblr_mksrrwFiQ91qbs1x4o1_500.jpg
I'm using Colm's IDL 2 light set but it's still not getting me the results I want. Any suggestions with making gold 'pop'?
seachnasaigh ( ) posted Mon, 22 July 2013 at 1:41 PM
     OK, I'm form a low-poly version and post a screenshot when it's built.  You can then choose which model you want to use.
     I'll search/review BB's advice on gold shaders.  What are the edges supposed to be?  Silver?  White?  Or did you intend the bulk to be metallic gold and the edges glowing white?
Michaelab ( ) posted Mon, 22 July 2013 at 1:47 PM
The edges, which is the part that need a glow to them, need to be white and glowing white. And it would be great - if possible - to have another version where the edges are blue and a glowing blue.
The rest of it is to be a metallic gold in both versions.
Thank you, seachnasaigh!
Winterclaw ( ) posted Mon, 22 July 2013 at 3:14 PM
What's the best way to control brightness, ambient value or the Intensity setting in D3D's firefly renderer?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
seachnasaigh ( ) posted Tue, 23 July 2013 at 3:00 PM · edited Tue, 23 July 2013 at 3:04 PM
     Winterclaw:  this is just me, but I adjust the ambient.  If I post a freebie which requires rendering via D3D's Python utility, a lot of newer folks would be lost.  *I* use that script, but a lot of people never read the *readme*.  Very high ambient can cause splotchiness.  If you increase the scene IDL sensitivity too much, some things which should be passive may cast too much light.  Both approaches have hazards.
     Here's a raw mesh screenshot, Michael.  Does this look OK?  Changes you want, if any?  Re-scale grip versus blade size?  I want to have the sword shape finalized before I start fitting an IDL emitter mesh and aura to it.  P.S., under 700 polys! :woot:
Michaelab ( ) posted Tue, 23 July 2013 at 4:19 PM
Hi seachnasaigh,
Looking pretty good but the handle is about 2x too thick. Can it be reduced in diameter?
Thank you. Really!
seachnasaigh ( ) posted Wed, 24 July 2013 at 3:08 AM
     Handle thinned...
Michaelab ( ) posted Wed, 24 July 2013 at 12:21 PM
much better. I'm going to make the handle gold as well. can the pommel be made flatter or smaller? If I can do it in Poser that's fine.
seachnasaigh ( ) posted Wed, 24 July 2013 at 1:02 PM
Pommel reduced, handgrip gold...
Michaelab ( ) posted Wed, 24 July 2013 at 2:56 PM
Good to go! Thanks.
seachnasaigh ( ) posted Wed, 24 July 2013 at 4:40 PM
OK, shape being established, she goes into the Numenorean workshop to be fitted with IDL emitters and a glow aura.
Michaelab ( ) posted Wed, 24 July 2013 at 5:20 PM
Wow! Sounds like a real process. Can't wait to see it.
moogal ( ) posted Wed, 24 July 2013 at 9:16 PM
> Quote - **IF** the glowing halo is what you're after together with the actual lights, I'd suround the pyramid with a slightly bigger duplicate made almost transparent and also with ambient on
I've been doing auras and blooms in Virtualdub and have been pretty happy with the results.  My method only works if the glowing object is the brightest element in the scene, but otherwise it takes no time to add and little time to adjust.  It's just a filter chain using the filter blender and can be saved as processing settings.
The top of the image is with the glow effect applied, the bottom is as it was rendered in Poser.  I'm using threshold and box blur, so it shouldn't be too hard to reduce the spread and/or softness of the effect.
seachnasaigh ( ) posted Fri, 26 July 2013 at 8:02 AM
     That looks like a simple and workable solution, moogal.  ^^
     Here is the test render of the quatrefoil sword, in an "off" (no glow) state:
     One infinite light at 8%, a spotlight 2 at 67%, spotlight 3 at 50%
seachnasaigh ( ) posted Fri, 26 July 2013 at 8:05 AM · edited Fri, 26 July 2013 at 8:12 AM
     IDL emitter and glow aura "on";  Spotlights lowered to 20%, sword is lighting the scene:
     I haven't made a blue/white texture yet, but that shouldn't be difficult.  Visibility of the aura can easily be dialed up or down.
     This was done on my older (32bit) laptop;  you'll want to use more IDL quality and irradiance caching, and maybe more raytrace bounces to reduce the splotchiness on the walls/ceiling.
     I need to do some steel work outside this morning;  when I get back to the computer I'll work up the blue/white texture, and then I'll need to pack this up in a runtime zip.
Michaelab ( ) posted Fri, 26 July 2013 at 3:57 PM
Love what I see, seachnasaigh. Is it too late to make the handle a bit longer, say by 20%? If it's too late, don't bother. Thanks.
seachnasaigh ( ) posted Fri, 26 July 2013 at 4:05 PM
Quote -   ...make the handle a bit longer, say by 20%?
     I can do that. yep
seachnasaigh ( ) posted Sat, 27 July 2013 at 10:59 AM · edited Sat, 27 July 2013 at 11:06 AM
Grip section 20% longer.  blue & white glow texture.
     E-mail with zip pack attached has been sent.
Michaelab ( ) posted Sun, 28 July 2013 at 10:28 PM
Perfect!
