Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
If I've understood the problem correctly, you could try the following.
Create the larger circle (position 0,0,0)
Create a smaller circle and position as required
Parent the smaller circle to the larger one
Select the small circle, activate the group tool and select all the small circle then select create prop. This should create a new small circle at the same postion as the first
Select the larger circle and rotate along the verticle axis by 30 degrees
The original smaller circle should also rotate
Repeat steps 4 - 6 until the dial is built.
Parent all the smaller circles to the main dial.
I gather by your responses there is no guide in poser to align. And there is no grid either.
Yes, each item is a prop. The small discs are actually flattened spheres (BB's orb) because I figured it would be easier to align.
Starting point? Don't know what you mean by that, PhilC.
Good idea ironsoul, thank you, I could do that and I may. I was hoping for guide lines. If nothing better comes along I'll have to start over and do this option.
Rename the downloaded file to circle-guide.pp2, then put it in any props folder.
Load it, scale it to the right size, then Z-rotate it to populate with child circles.
My python page
My ShareCG freebies
You could also place the small circlular prop wherever you want it (12 o'clock, 3 o'clock, whatever), use the joint editor to set the origin of the small circle at 0,0 and then edit:duplicate the circle, and Y-rotate 30'. Repeat...
OSes: Win7Prox64, Win7Ultx64
you could use collision detection so they won't go over the edge of the big sphere.
it's an interesting exercise. would be kewl idea to make for free stuff
i would type in the x and z parameters for precision placement.
starting with the spheres at origin 0,0,0
select one, x= 3, (or whatever your distance)
select 2nd, x= -3
3rd z = 3
4th z = -3
the others, hmm. what equation to use?
don't think the slope formula would help here, y = mx + b
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
X=radius*cos(angle)
Y=radius*sin(angle)
1 o'clock: X=1.5, Y=2.598
2 o'clock: X=2.598,Y=1.5
And the other clock positions use these same values, but are negative where appropriate.
P.S. The clock hand (the radius) and the X and Y coordinates are related by their squares:
r^2 = X^2 + Y^2
In the bottom half of the clock face, Y values are negative. On the left half of the clock, the X values are negative.
Rounding 2.598076211... to 2.6 for illustration, the X,Y coordinates look like the diagram.
(I'm using Misty's radius of three in this example)
How do you expert poser users align objects in relation to one another in Poser?
