DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Here is the product here in the RMP
https://www.renderosity.com/mod/bcs/dyncreator-for-dazstudio/113516/
Hi if you have at least DS 4.7 you already something called "dynamic clothing" . This script converts .obj files to optitex cloth somehow giving us Native cloth simulation in DS. sale ends today !!!!
BTW two threads over at the DAZ forums about this product have vanished today so interested parties may wish to secure their purchase in good faith soon...just saying.......
FYI I have no commercial affiliation with this product just excited about getting this ability for my animated genesis figures in DS.
LaurieA posted at 2:15PM Tue, 09 February 2016 - #4254124
Oh, I was under the impression one needed the plugin. Nice indeed :)
There's a basic plugin that comes free with DS, but you can't achieve the same control as the full paid plugin.
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
The script uses a "hack" some of us have known about for a couple of years, problem is that Optitex had a hissy fit when the "hack" was revealed and "demanded" DAZ do something to stop it, so a block was added to 4.7 that stopped the "hack" as is, but with a little knowledge of DSON it was easy to get around, they have since removed the block in 4.8 and 4.9.
The "hack" is still a sore subject over there, and most threads/posts mentioning it tend to vanish, or at least all of mine do.
I was just about to say, if Daz Studio suddenly adopts meaningful physics I will jump up and down like a happy sock puppet.
This is a good start, even if it is not real physics cloth just a dynamic cloth hack.
Will this Dyncreator cloth collide with chairs and things?
The only reason I'm at Poser is because of soft body and native physics. Now Poser has to get real time animation record or Puppeteer to keep me. :D
I tried this yesterday on a variety of daz clothing, everything from v4 clothing all the way up to g3f clothing and had mixed results. The v4 clothing worked the best and I was able to achieve some descent draping. When I tried it on g3f clothing, the performance in daz became so slow that it became impractical for me to wait for the results. I imagine it would drape for g3f clothing as well as v4 clothing but at two minutes plus per frame I just couldnt wait for it to complete. Im assuming that the real strength of this script will be for poser dynamic clothing which is fine for me. I spent a couple hours yesterday looking for dynamic clothing and adding it to my wishlist. I agree with Mythico, if Daz ever adds a good physics model it will be fantastic (if not long overdue). This script is a good start. Im so tired of autofit that even the smallest improvement in dynamic clothing for daz is welcome. I hope that lola69 continues to support dyncreator.
Bejaymac posted at 7:37AM Wed, 10 February 2016 - #4254229
Check for the smoothing modifier, it's a "cheat" that way to many use on their products, that's what will be slowing you down.
Oh, of course. I should of thought of that before. Ill definitely check that. Thanks Bejaymac! I imagine that any HD morphs might also slow things down.
Well, unfortunately my most recent attempt with g3f crashed and I lost it all. However, it was turning out pretty good. I used v7 and the camisole and skirt from the vagabond outfit. Bejaymac's suggestion helped with the time issue. As a matter of fact, I took it a little further. Before converting everything to props, I removed the smoothing modifier, turned resolution level to base resolution, and turned View SubD Level to zero. This improved the both the conversion time and draping time for the items. I let the skirt drape for 51 frames and the camisole for 31 frames. The whole process took under an hour to complete, probably around 45-50 minutes. It crashed when I attempted to increase the draping on the camisole from 31 to 51 frames. I suspect that this may have something to do with the fact that I had it colliding with a skirt prop that I deleted and then replaced at one point for some forgotten reason. Well, off to try again!
The new Dynamic Converted offered here does it's job well and while I am getting mixed results with the plug-in , I am learning it and am finding it to be quite entertaining. Dynamics are the only thing from Poser that I really miss when I am using Daz and now with a little work I can have that too !!!
I have some questions as I am still not having great results with this. Alot of really long conversion and draping times.
I love it, am concerned Optitex will make DAZ block it but until then am having fun I added a smoothing modifier before freezing and after to an obj export reimport for this as it worked better an much faster than converting to prop
Thats great! Any hints or knowledge you could share would be most appreciated.
HassenBenSobar posted at 8:23PM Wed, 10 February 2016 - #4254277
- When I load the clothing item, do I want to parent the item to the figure or should it just be fit to the figure?
- Assuming that im using a clothing item made for the figure im working with, do I still need to edit the rigging for the clothing?
From my short play of the script the other day it only works on props, so "fitting to" and rigging wont come into it, and without a rig means you will need to parent it to the figure before running an animated drape.
Wendy I wouldn't worry about them blocking it, they tried that with DS4.7 back when this hack was first discovered, some of us figured out ways around it and they removed the block after that.
well I just had a post from yesterday modded by them so they are certainly actively combing the forum removing all traces. Which makes me uneasy, but the cat is out the bag IMO
wendyvainity posted at 1:28AM Thu, 11 February 2016 - #4254294
Fantastic Wendy..hope they don't block it as I'm having so much fun with it too:)
**"From my short play of the script the other day it only works on props, so "fitting to" and rigging wont come into it, and without a rig means you will need to parent it to the figure before running an animated drape.
Wendy I wouldn't worry about them blocking it, they tried that with DS4.7 back when this hack was first discovered, some of us figured out ways around it and they removed the block after that."**
Hi, actually I am using 4.7 with is script (probably a latter build)
My experience has been such that you should use high quality,single grouped, dynamic clothing props with high vertex counts and triangulated. DS has built in tools to subdivide& trangulate your imported meshes.
I personally avoid trying to convert previously built conformers to dynamics because of different grouping as seams & such. Really long robes are still a problem with walk cycles in the area of poke through but poser suffer the same issue for us animators in this regard .
Here is a still render of the genesis 2 female a 30 frame animation where she starts in the T-pose with her default shape and morphs into the pose& shape over 30 frames. The tunic dress is a freebie for V4 from Sharecg.
On a side note its a shame that Maxon Cinema4D is at R17 and costs $3700 USD and still can not do basic clothing draping like this (but I digress).
all the lovely Rendo dynamic clothing for Poser is suddenly looking very attractive
pendraia posted at 11:34PM Thu, 11 February 2016 - #4254587
Only just discovered this...can anyone remember the fix for using scaled clothing in the Dynamic tab? I managed this by exporting and reimporting an object but from memory there was a way it could be done.
Here is Simon's explination and tutorial: http://www.daz3d.com/forums/discussion/40199/tips-and-tricks-of-daz-studio-optitex-dynamic-clothes/p1
@ wolf359, there were a couple of public builds for 4.7, so odds are you're using one of the pre block versions, either that or this script uses a method to get around the block.
https://www.renderosity.com/mod/forumpro/?thread_id=2879971
That's the link to the original thread on the "hack", the PoC data is in the first post, you can ignore most of the rest of that thread as it turns into the Stan & Razor e-peen show.
Thanks wolf359 for the heads up. I just bought Dyncreator and it worked in my DS4.8.
So weird seeing my own custom dress draping onto Genesis inside DS viewport... Never dreamed it was possible!
wolf359 posted at 11:21AM Fri, 12 February 2016 - #4254399
I seem to recall DS dynamic clothing are themselves "semi" conformers...
I just check out Dynamic Clothing Control product page
One of the pics seem to show (surface/mat) groupings as "Layers"
If that means different rigid/ soft weighting per group, that would be sweet!
Anyone here has the Dynamic Clothing Control? What those "Layers" do really?
I may finally have a good reason to buy this wish list item after all this time
Oh no digressing at all.
Sometimes I do wonder with my crazy time+$$$$ investment in DS/Poser/iClone/Carrara is better spent on a do it all tool like C4D...
Now you make me feel better !!!
If it is of any help, I did a couple of tutorials on using the 'old' dynamic clothing in Daz which are here: http://siluria.deviantart.com/gallery/51963496/3D-tutorials
As well as a simple workflow I used to get a V4 conforming dress to drape on G3F
If you follow the instructions in Dyncreator you will need to know some of this too
my cloth from wendy vain on Vimeo.
tried something I modeled myselfI have never used dynamic anything either but I quickly picked up this script. I took me about 5 seconds to figure it out. I did a quick test draping a small grid over a mouse. I think this script is amazing.
I picked this up, it was neat to try some of the Poser dynamics I had laying around... they didn't all work so well, but the basic idea is there.
What I wonder is: why don't more people use the dynamics in Studio? The basic plugin is free and there's pages of free content available... Optix Freebies
damn its crazy, people keep asking about this on DAZ forum and if anyone has asked before I say yes they have but best ask over here and get modded for that even. on a lighter note I bought two Poser Dynamic dresses with my 10% off coupie today cannot wait to try with this and maybe in Poser too to compare.
evilded777 posted at 7:41PM Fri, 26 February 2016 - #4255361
Some people want to use the meshes they've made themselves or in Marvelous Designer (which drape really well I might add). :)
Hello, I have bought the plugin and experimented a bit with it, following the pdf tutorial (the biscuits cardigan on G2F). Unfortunately, I'm stuck at the point when it says: "Go to frame 0 and transform your conforming cloth in a prop." If I select Figure --> Rigging, I don't have the "Convert Figure to Prop" option in the cascade menu. I have also tried to contact the vendor via sitemail, but obtained no reply. Any help is appreciated, thanks in advance.
Cabiria999 posted at 1:39PM Mon, 07 March 2016 - #4258533
you may have to customize your menu and manually add the menu option.
forgot which layout, i had to manually add menu items
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Cabiria999 posted at 10:04AM Sat, 02 April 2016 - #4258533
I found it under Figure > Rigging but not from the Edit menu in the top menu bar but in the Edit menu in the scene drop-down menu.
I have another issue though - I'm wondering if this scripts works at all with my setup. I have DS 4.9, Mac 64 bit version. I get to the stage where I run the script and have a Prop_dyn in my scene but the Dynamic Clothing plugin (paid-for version) refuses to see it as dynamic cloth. It just does not see any clothing in the scene at all.
So far, so good. I use the dynamic plug-in (yes I have buyed it a long ago...) and most of my render use optitex dynamic clothes. My workflow : Posing the conforming item (here stocking obviously) => Send to hexagon => Tweek the surface => Save as obj => Import into daz Studio => Convert to dynamic => Ajust the scale to 99.9% (It's solve my exploding simulation problem) => Ajust the panel property inside the optitex plug in => Simulate.
The result (I want to create a loosen effect)
marble posted at 8:52PM Sat, 02 April 2016 - #4263774
Try "unparenting" the prop. For dynamic cloth in my edition of 4.6 the cloth must not be parented to anything.
I don't recall atm if it's applicable, however for several additional plugins, everytime we get an updated D/S, we also have to find and run an updated plugin. After closing/opening D/S [i.e. refreshing it], if the plugin is not working possibly an update needs to be found. [says she hoping it works on a mac, I use W]
Hi I just ran over to the RMP and used some of My vender credit to buy this script.
Well I am not one take to hyperbole but this is a game changer for me as an animator. Apparently the DS cloth dynamics are way faster than posers and now I can make use of all of the free Dynamic clothing for poser but on genesis models as well as model my own .
Here is a simple test where I imported an ankle length robe I modeled in C4D. And had been using in poser. A simple import and conversion to optitex and 5 min 40 seconds later here is the result of a quick 30 frame animation from the default figure To the morphed posed one.
Very useful and worth the $7.20 USD I paid.
My website
