Virtual World Dynamics F.A.Q (Last Updated: 2024 Dec 10 3:45 pm)
Nice Writer's Block! I have yet to try to drape hair....
Have a creative day!
Thank you!
Great to see all those vwd images!! Wonderful!
A test with a longer hair made for VWD.
ErickL88 posted at 5:30PM Sat, 11 June 2016 - #4272132
Here's one of mine (resized) I still need to find the right setting(s), to make the wrinkles/folds less "tube-y" looking (like on the bended arm), as I still find them a bit to round and to big on their radius. I want them to be kind of thinner, with a smaller radius (If that makes any sense) =D
Looks good.
Maybe try less stiffening.
Thank you for all these marvelous images. For me, it is a great pleasure to see renderings with VWD elements. Thank you again.
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
@All : Thank you for these wonderful renderings. Now, I know why I wrote VWD !!
@ErickL88 : The stiffness of a cloth depends on its mesh and the springs. To reduce the stiffness of a cloth, you can :
Great renders everyone.
Here's one from me, but it only has two elements utilizing VWD. The pants, and the belt. Both are conforming clothes objects, but were done in two different draping sessions. The pants are single dynamic mesh, and an animated drape was used. The belt is comprised of separate meshes, and was added after for a quick static drape.
My interest in VWD is to enhance animations - when it works, its quite easy to get results like this. Rendered in Carrara 8.5 with Philamo's plugin
Anothr VWD Cloth Sim Test from m d on Vimeo.
@Ashfire45: VWD is an external plug-in working with Poser (Natively) and DS4 (using the plug-in developped by Phil). So you need to buy VWD (light or complete version depending of your needs) and then the plug for DS4 when it will be available. Same for Carrara : VWD + the plug.
If you have Poser you can made a scene in DS4 export to Poser, made the simu with VWD in Poser and then come back to DS4. Of course the plug from Phil will simplify all these! When you are in VWD it's the same either you are coming from Poser or DS4 or Carrara. So you could already master the beast :-)
Don't worry, the investment is worth.
About V4 clothes on Genesis 2 or 3 here is one: (Gaia dress on G3F)
Smaker1 posted at 6:30PM Sun, 10 July 2016 - #4275273
OH! I see! So I'll be purchasing the program by itself and then the plug in when it comes out! Sounds expensive, but as you said... Completely worth it! Can I ask where I can buy the actual stand alone program? And if I'll be able to export from Daz Studio using it?
Also.... That render!!!!!!! WOW!!!!!!!!! <3 I can't express how jaw dropping this is! I mean, the lighting and composition is absolutely lovely - but the way that the clothes are sitting on her... Goodbye, auto-fit, lol! Absolutely sensational! <3 If I wasn't dying to get a hold of this before, I really am now!
Smaker1 posted at 7:15PM Sun, 10 July 2016 - #4275273
Outstanding. :)
Hello,
thanks for your kind comments
@Ashfire: you can buy VWD here at Renderosity. There are now two versions: a "light" one for static renders and a "complete" one for animations. As I have the "complete" I don't know all the differences. Read the informations on the two products to find what's the best for you If you have Poser you can already use VWD, I made standard obj export from DS4 to Poser and then go back to DS4 with simulated clothes imported (I don't do animation renders). As I'm testing the beta version of Philemot DS4 Plug in: it's far more efficient. It will be a must buy for DS4/VWD users !!
Don't say good buy to autofit it still has it's use!! With dynamic simulation the fun part is to find the best way to do it and it depends of the clothe, the pose, the character,..... But I agree with you that I don't use autofit anymore for long dress :-) I talk about dress (V4) not made for the character (Genesis3F)
VWD is not, like all clothe simulators, a one click solution but it's the best one and the more efficient to tests new scenarii. I thinks that I use only 10% of the tool.
Smaker1 posted at 8:13AM Mon, 11 July 2016 - #4275338
Hello,
I only use G3F, well rarely G2, and they are all much more natural.
With regards to which version of VWD to get, I don't do animations, but I am still glad I bought the animation version. I exported animations back and sometimes if I only want one image, chose the one that looks best.
I don't know if the lite version can import animation, make the simu and then only do a static export. If not: the complete is mandatory because making animation simulation even for static render is one of my scenario
Personally, I don't do global animation exports from VWD because I systematically make some drape adjustments on one frame (generally the last one) so I export only this frame (static). If it's not the last frame (rarelly) I go in DS4 on the same frame.
But there are so many roads to Rome :-)
Smaker1 posted at 7:05PM Mon, 11 July 2016 - #4275382
Not sure to follow you Writer: you are doing multiple exports from VWD? and rename the -VWD object?
If I do an animation (as an example 30 frames); once I'm happy with the poses I want, I send it to Daz.
In Daz I Edit>Duplicate>Duplicate Node Hierarchies. This must be done before sending another pose as the previous one will be lost.
I then remame the duplicate (eg: I want to keep frames 5, 9, 15, 22 and 25); this is in part to avoid confuse and so it makes sense to me, but also I don't want 'VWD' lieing around needlessly. :)
I'll rename it and put the frame number in the name to show what positioin it was.
When renaming, I also use 'VeeWDed' in the name to be sure I know what it is.
Example: VictoriaSitting-VeeWDed-pose05, VictoriaSitting-VeeWDed-pose09, VictoriaSitting-VeeWDed-pose15 etc.
It seems that VWD is used as an identifier by VWD, so I make sure to avoid those three letters anywhere, and especially at the end of the name. Just in case.
Yes, thank you, Writers_Block, for the heads up on Duplicate Node. This is far better than my work-arounds.
Since I just started using DS4.9 to use the VWD_DS Bridge, i did not know they implemented it into DS. It was something I was wanting for many years.
I just tried today, and it works great. Thanks again.
I actually have a question for you all! Are any of you aware of using XNALara to import models extracted from games? Some Daz artists use this to get more hair options... For instance, these:
http://moogleoutfitters.deviantart.com/gallery/47851035/Hair-Female
My question is - I'm sure you can see where this is going - would it be possible to use VWD to make these morphless obj. files act like actual hair? >.>
Ashfire45 posted at 9:47AM Thu, 21 July 2016 - #4276380
The mesh.ascii format can be converted using Blender to OBJ...then you can import and use that. The importer may be a addon/plugin for Blender, but I've done it many times, its pretty simple.
I was not satisfied by long hair simulations. I just tried a new method which improves the simulation. Tell me if this method seems better for you. Here is the link : https://www.youtube.com/watch?v=8JXXclWqjAQ
I will do a video tutorial to explain this method.
VirtualWorldDynamics posted at 10:30AM Sun, 31 July 2016 - #4277990
I absolutely adore this hair and am really, really looking forward to using it in VWD; it animates so beautifully in your video and I'm definitely looking forward to seeing that tutorial! =D
EDIT: It occurs to me, was this animated in Daz Studio or Poser?
VirtualWorldDynamics posted at 1:18AM Mon, 01 August 2016 - #4277990
This simulation has been made using a new method to animate long hair. The top of the hair uses a rigidification by neighbourhood and the bottom of the hair uses a rigidification by extension. A video tutorial will be made to explain this method.
By 'Neighbourhood' do you mean fall off distance?
Having finer gradient between pinned and unpinned mesh area is always good, for hair, or even clothing.
The lack of easy to implement fall off control was the key shortcoming of DS Dynamic Clothing Control (and Carrara Bullet soft which uses tedious vertex selection to compensate).
The video shows off very good simulation fidelity, as all your videos and animation choices do!
Mythico posted at 11:12AM Mon, 01 August 2016 - #4278108
The two methods of rigidification are under vertex groups. Neighbourhood is for parts that are not connected, so useful for hair: the upper parts, and say making sure buttons stay where they are supposed to and not drop on the floor. Vertex Extension is a direct connection between vertices; a simple example is a cube, where they are all connected.
I'm so happy this little forum has grown so quick & that everyone is participating & helping each other out. Now this is what it's all about! With that said, let's all share our renders! I'll start....
Moon Dancer (used VWD on the top skirt).![moondance1.jpg](https://live.cdn.renderosity.com/forum/threads/2903129/file_eecca5b6365d9607ee5a9d336962c534.jpg)
My Lil' Store
