Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 13 10:25 am)
You guessed it, you can't use them.
Anything derived from a copyrighted mesh, no matter how changed, is still technically part of that mesh. Otherwise, everyone and their dog would be making and selling/giving away bodysuits/masks/cowls/skullcaps etc for every figure ever made by doing essentially the same as you did. In fact, that's pretty much how a bodysuit is made anyhow. In fact, it would be the quickest and simplest way to make almost any kind of clothing.
I know for a fact there are some masks and stuff out there - not made by the figure owners - derived from the original figure mesh but that doesn't mean it's right to do so; it just means they haven't been found out.
If you make the mesh penetrate the figure instead of sitting on top, you'll get the effect you're after. I guess it won't be applicable in every instance but it'd certainly work for a spine piece.
Although the above is correct, the one fact that is not mentioned is that you need the copyright owners permission. Ask Smith Micro if you can use the mesh to do what you are trying. They may say yes based on the fact the newest figures are allowed to be used in the way you are using Miki4. If they say Yes then you are good.
Poser 5, 6, 7, 8, Poser Pro 9 (2012), 10 (2014), 11, 12, 13, 14
Richard60 posted at 12:56PM Mon, 28 November 2016 - #4291205
I'm not so sure. The way Nerd3d was talking prior to Poser 11's release, there seemed to be some roadblock to having both Paul and Pauline available for use as resources, although they did eventually get it squared away. At least, that was my take on it.
SamTherapy posted at 12:29PM Mon, 28 November 2016 - #4291183
That was my intention. In Blender, there is the shrink wrap utility, when you first apply it, the mesh gets pushed into the mesh. I am hoping this will do the trick. Well, that and a good modeling job.
tonyvilters posted at 12:31PM Mon, 28 November 2016 - #4291224
So? I will have to write it again :
Poser comes with 6 meshes that allow this. The Poser-Pro figures, Low and Medium resolution, male and female, so that are 4 figures. And the Poser11 Paul and Pauline. It is very clear in the Poser Eula. But who reads those things? LOL. Best regards, Tony
I am using Poser 10. I don't have access to any of those figures...
tonyvilters posted at 3:39PM Mon, 28 November 2016 - #4291224
Wasn't really the question being asked Tony. Granted, Paul and Pauline are currently the only two figures that allow this, but Nerd did mention that there had been discussions along thee lines of allowing other figures to be used as resources as well. To my knowledge it has not gone any further. However, that does not mean that if someone asked, allowances couldn't be worked out.
Rokket there is an offset property in the shrinkwrap modifier that will let you pull the mesh in closer or out . You could use this to move the mesh out a bit and then use the solidify modifier to give it thickness.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Well I'll be an Onkey's Muncle. It worked. I am not keeping these boots. Actually, I might, but not for this project. I am going to make the legs to match the left arm. The right arm and torso will be covered in the costume made from the shrink wrap and solidify technique.
Vey Kool...
I can never repeat anything I have ever created. I guess that's why I save everything I create. Here is my attempt at using the shrink wrap and solidify utilities to create her body implants. Not the same, but not bad either, I guess...
Hope she doesn't need to scratch her nose. Could end up with a perforated head. :D
So...
Right handed - in fact, so strongly right handed she has to use it to scratch her nose? And has a powerful weapon in her left hand?
I can't see where anything could possibly go wrong there.
That's because they don't want a perforated head, silly. :)
Cool. Bet she can't juggle, though.
I've seen people juggle one handed. I'd bet she could do that. But where in that suit will she carry a hankie?
RedPhantom posted at 12:56AM Sun, 11 December 2016 - #4292362
You don't want to know. Really, you don't.
LOL, probably not.
For once I can't think of a Smart Ass One Liner.
That came out of her nose? Maybe she does need to use her other hand.
Nice head on shot.
Ah, she pulled it out of a clown's nose. I see.
You really need help.
Ok, that's cool, hidden panels, or maybe not hidden, except from my point of view in the legs.
Aha! A "Leg's open" pose.
Note the apostrophe.
SamTherapy posted at 2:51PM Mon, 12 December 2016 - #4292484
Couldn't help yourself, could you?
I am creating a cyborg suit for Miki 4. In the render you can see the left arm - all me. I modeled it. The eye, all me too. There will be legs that I also modeled, and you can't see it, but there is a spinal implant that I modeled. So what's the question you ask?
The prosthetic devices on her face and torso are made from her mesh. They are shell extrusions. So the question is, if I do this, can I distribute this as a freebie? Or does the fact that I used her mesh to create these negate that fact?
