Wed, Feb 19, 2:06 PM CST
Forum Moderators: wheatpenny Forum Coordinators: Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 18 8:02 am)
Subject: Add Opacity File in a DUF
flibbits ( ) posted Thu, 02 November 2017 at 12:11 AM · edited Wed, 19 February 2025 at 2:06 PM
I have edited DUF files to load different images onto surfaces.
How do I add an opacity file? I don't have an example to see what the entry/extra lines have to be.
Does anyone know? I want to load an existing transparency map (a black/white image I made to make parts of a clothing item transparent) onto the Opacity node (not sure what to call it).
RHaseltine ( ) posted Thu, 02 November 2017 at 3:51 PM
Online Now!
Why not edit in DS, in the Surfaces pane assuming you are using a pre-made shader?
flibbits ( ) posted Thu, 02 November 2017 at 5:13 PM
Yes, that works,. But I want to make a DUF file, so next time I want to apply this I can apply it with a click of an icon. A DUF file also makes it so I won't have to add a note to say "hey, there are additional custom made textures for this." If there's an icon (from the DUF file and a PNG file) in MyLibrary (generally in the materials sub folder under the clothing item), then it's right there to see.
Razor42 ( ) posted Thu, 02 November 2017 at 6:01 PM
Saving a material or shader preset can do all that. Maybe I'm not quite understanding what you are trying to achieve. Material/shader presets both save as ".duf " A material preset saves for a specific surface name and a shader preset saves for application to any surface.
flibbits ( ) posted Fri, 03 November 2017 at 12:03 AM
I don't know about material/shader presets.
Razor42 ( ) posted Fri, 03 November 2017 at 2:20 AM
You can save all of the surface panel settings as either a material or a shader preset which will create a .duf file which can be applied later.
You can also save a partial preset by drilling down when you save and ticking only the parameters you want to include such as Opacity. When a partial preset is applied it will only modify the included parameters.
Razor42 ( ) posted Fri, 03 November 2017 at 3:39 AM · edited Fri, 03 November 2017 at 3:41 AM
This video covers saving a shader preset: I have set it up to play from saving a material preset, the rest of video covers working with surfaces.
flibbits ( ) posted Fri, 03 November 2017 at 4:55 PM
Thanks.
flibbits ( ) posted Fri, 03 November 2017 at 9:07 PM
I can't believe I've been doing this by editing DUF files, when it can just be saved.
Razor42 ( ) posted Sat, 04 November 2017 at 8:43 PM
Ah well, look at this way. You probably have a better understanding of the file structure then most do, and that can be helpful when creating presets as you know whats happening under the hood. There used to be a time when many things could only be done in a .txt editor, but the Save presets have come a long way over time.
