Virtual World Dynamics F.A.Q (Last Updated: 2024 Sep 15 1:40 pm)
Thank you MrFiddles22,
You are really kind to my English speaking. With time, I will improve it.
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
Hello,
I Have no feedback of the dynamic morphs in the forum.
After several tests, The "Normal" version of the presets are the best ones.
But, for me, the best settings are "no parallelization", "Fast move = 3" and "Iterations = 8";
Then if you want to stiff or soft the wires, you can play with the Iterations count. You can Increase this value to stiff the morph and Decrease this value to soft the morph.
Please, give me some feedbacks.
Thank you
I will create two new threads.
Gérald
headwax, kwan, I sent you the latest version of the program.
Surody, when I say "no parallelization", I just want to say no multithreading and not GPU. These two checkboxes have to be unchecked.
With Biscuits, we made a video.
This video uses "Choker dress" and "Amie hair" and shows the quality of Biscuits's products sold in this marketplace.
The simulations have been made with VWD, of course.
The character used is Genesis8 with a complex animation.
Here is the link to this video: https://www.youtube.com/watch?v=F_h-msAmJiM
Give us your feedbacks.
VirtualWorldDynamics posted at 4:53AM Tue, 01 May 2018 - #4329174
I really would know how you set up that dress and hair, my results are definitely always worse. It looks really really good, there's not alot to say. The only thing you could maybe fix would be unlocking the axis parameters because the animation has some glitches.
Yes, Surody, the animation has some issues. I didn't take time enough to correct it.
I will do two tutorials to explain how I made this video.
No sales in April, I explained to Surody why I regularly said I will have more time in some weeks. In fact, the main part of my time is used by two projects. I write new functions for VWD late in the evening or in the night. These two projects will finish in July. From this month, I really will have more time to work on VWD and, of course on the Patreon project.
VWD will continue to this condition alone.
In some days, I will start to add collision objects in the GPU. I will set this count to 5. This will allow to work without any constraints in GPU simulations.
VirtualWorldDynamics posted at 4:55PM Tue, 01 May 2018 - #4329323
To avoid those glitches you just have to unlock all bones. They are limited in movement and alot of preset animations overexceed this limitations, causing keyframes not to behave correctly. Not sure if you know that already.
Yes, you are right, I don't remember if I unlocked the bones rotations. Thank you.
VirtualWorldDynamics posted at 6:40AM Fri, 04 May 2018 - #4329094
Hello,
Thank you
Gérald
I finally got a chance to review the video tutorials for the dynamic morphs, it looks really easy to do. Amazing to see that Daz will have this ability similar to Poser. Great work Gerald you are a genius!
Can the dynamic morph script be applied to any other body parts or objects that have movement morphs?
I will test it out as soon as I can.
MrFiddles22 posted at 9:28AM Fri, 04 May 2018 - #4329489
Hello,
Thank you
Gérald
Yes you can.
Currently, the Dynamic morphs function has a reference vertex and 2 direction vertices. You can choose the reference vertex, choose the morphs to modify and then generate the wire.
When you generate the wire, the 2 direction vertices are generated in the program in X and Y directions. These vertices will be used by the function to define the 2 planes which will be used to calculate the morph to use and the value to apply to it.
This solution is correct if your reference vertex (its normal in fact) is close to the Z direction. (fine for the breasts and the glutes). if the vertex is far from this direction, the result will not be fine. You could rotate the character to resolve this issue, but the recording of this dynamic morph will not be recorded correctly because only the reference vertex is recorded.
I want to give the ability to make any rotation you want when you generate the dynamic morph. To record correctly this dynamic morph, I have to record the 2 directions vertices. I will do this modification soon.
If my reply is not clear enough, I can explain better with an image.
This means all mesh with morphs can be modified dynamically.
Thank you Writers_Block.
The modification for the dynamic morphs works fine now.
It is possible to rotate the character, select any vertex as reference and generate the dynamic morph. Even if the initial animation pose is very different from the pose used for the generation, the morph will be modified correctly.
This will allow to animate any morph dynamically from any part of the body.
VirtualWorldDynamics posted at 5:31AM Tue, 08 May 2018 - #4329558
That's a nice improvement! Does the GPU part progress too? CPU is really ridicolous slow and GPU doesn't deliver trustworthy results sigh. Anyway, keep up the great work! Hope you will be able to set up Patreon soonish.
Surody posted at 6:09PM Tue, 08 May 2018 - #4329650
What issue do you have with the GPU? Other than an error when first starting VWD, which doesn't seem to make a difference, I don't recall any errors; I've also found it to be consistent.
I just started to work on the multiple collision actors.
The modification is not so easy to do. I will give some informations on the development.
I also try to resolve the issue at the starting of VWD.
Hello Surody,
I am not sure to understand, you want to know if VWD is able to read other animation formats?
Hello,
I will not be at home during the next week. I will try to reply to your messages.
I certainly will start a new thread on the Patreon project. I really would like to know if this project interests some persons.
Have a fine week.
Gérald
VirtualWorldDynamics posted at 5:36AM Tue, 15 May 2018 - #4329951
Hello Surody,
No, I'm just asking if it would be possible to import the animations of hair or clothes into VWD too, not just the collission object.
Hello Surody,
In the next version, it will be possible to import a simulation made by VWD. Perhaps in others version it will be possible to read cache files like PC2 or ABC, with a change of the scale to adapt to the program. This will not be made immediately, but this could be interesting in some cases.
Hello,
Excuse me for this long time without messages. A lot of work to finalize the other projects.
I worked on the "Animated by host" function to make it easier to use. Now I am convicted this function will be very useful in many cases. For clothes and for hair. I just made two tests for Biscuits and I used this function in both simulations.
I finalize a new beta version and I will send it to those who are interested.
VirtualWorldDynamics posted at 6:49AM Fri, 01 June 2018 - #4330929
Hello,
Awesome, can't wait to take a look!
Gérald Count me in I am interested. You have my email address, but you need I can send another email to you if you can't find mine. I tried the last few updates you sent me, and I was having difficulty with using the simulation in an animation. Once I clicked start Dynamic Simulation in VWD nothing happened. It did not crash, the animation just never starts in the view port. The animation was well over 3000 frames could that be the issue?
Hello kwan,
I suppose your tests was made on a GPU version. Perhaps you have a problem with OpenCL. Did you make the same test with a Multi threaded simulation?
I made some simulations with several thousands of frames without any problems. I don't think the issue can be the frame count.
I will send you the new version as soon as it is made.
Hello Leonides02,
The multi collision actor in GPU is the next modification. I had some issues when I tried to implement it in the program. I want to finalize this function before to start the Patreon project.
Hello itou31, I sent you a new sitemail.
I start the modifications to integrate the 5 collisions actors to GPU.
Hello,
The 5 collisions actors in GPU seem to work correctly.
I certainly will generate a new version. This version will be very close to the final version which will be used to start the Patreon project.
Gérald
Hi everyone, I have some remark to be confirmed about "memory usage" at the bottom status of VWD. When import only g8f base with default parameters :
So working on hair, the "memory usage" increase as expected in the same amount on the 2 PC. On PC1 if I go too high in springs, I have memory crash when reach about 1.3GB, so I have only 800MB dedicated to hair to play with.
What is your experience on "memory usage" ?
Hello Ashfire45, For me DForce has been created for cloth poses and VWD has been created for all kinds of animations. We don't work on the same way. Thank you for encouragements, It warms the my heart.
Hello itou31, The memory usage will be the most important thing to explain in the video tutorials. Currently, I make some good simulations with hair having 350,000 or 400,000 vertices without any problems. Creating a 64 bits version could resolve the problem but I think it is better to keep the spring count lower than 20,000,000. You can make some tries by using the "Min distance" parameter. It is a magical function. For very dense hair, you can use a distance by neighborhood set to 0.5 and a Min distance set to 0.49. This will generate only efficient springs.
This week, I will generate a new version. This version will include the 5 collisions actors in GPU, the "Animated by host" function, the exportation to Daz Studio using a script (absolutely necessary for large hair). I will have to make a video to explain.
Hello itou31,
currently, when I want to make test on an unknown asset, I make some tests. In future, the best way will be to have a test system which would allow to automatize this action.
Hello,
I begin to think to a multi layers simulation. This will be very helpful in some cases.
I will give you some news soon.
I continue the developments before the starting of the Patreon project.
I want to have a finalized version before starting this project. Then I will start the rewriting of the documentation.
Excuse me, I'm still asking my question about DForce. Some of you have made some very dynamic animations using it or can send me a link showing this kind of test?
I can generate one and awesome news! Can't wait to take a look at volumetric mesh simulations. I'm little bit busy currently so I'm more in the background but I try to read every comment under VWD.
Hello Surody,
I just want to finish the current version and I will come back to you to start the Patreon project.
agape posted at 11:43PM Thu, 26 July 2018 - #4333791
Gerard, is there a newer version than V1.1.522.3630? That was the last version you sent me in May of 2017. I bought directly from you so I am dependent upon you to send me updates.
There's a newer version. Just write a mail to virtualworlddynamics@gmail.com and request a newer version. All updates are alpha/beta builds and nothing is a official release yet.
Hello agape,
I did not forgot all the direct buyers. Currently, the version can be considered as a Beta version.
I have you email, I can send you this version if you want. All the tests you will do on it will be fully welcome.
In all cases, I want to send the updated version to all the direct buyers at the end of September when the new documentation will be rewritten.
VirtualWorldDynamics posted at 11:50PM Sat, 21 April 2018 - #4328679
Stop worrying about your English or accent, I can understand you just fine. You're doing great!
