Sat, Jan 25, 10:16 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: Globe glass turns black when rendering.
Daysan ( ) posted Sat, 07 September 2019 at 4:07 AM · edited Sat, 25 January 2025 at 9:45 AM
Globe glass turns black when rendering. what should i do to get glass. I tried all sorts of things, but when rendering, the glass remains black and I don't see genes 8 female in the globe. Who knows a solution for this? Thank you. Greetings Elly from Holland zie mijn voorbeeld; teen josie in globe.jpg
Daysan ( ) posted Sat, 07 September 2019 at 4:15 AM
I forget to say that I render with delight because I have an Intel graphic card. and work with dazz studio 4.11 Greetings from Elly
Razor42 ( ) posted Sat, 07 September 2019 at 8:02 PM
There should be a glass shader example for 3Delight in your Shader Mixer folder. Is that the one you are using on the sphere? Though you may want to turn the index of refraction down a bit for something like this scene.
Remember also that glass and reflective materials are very dependant on what is in the scene to see. The reflection of nothing will be nothing. So try to get your object into a more real world type scene such as a room with some lighting added and I think it will come alive much more.
SilentWinter ( ) posted Sat, 07 September 2019 at 10:13 PM
Also check the Max ray-trace depth in render settings (under 'sampling') - it'll need about 4 for most situations with glass (light entering and exiting twice to come from behind the glass). Also make sure that the glass and whatever it's reflecting is sufficiently lit.
Silent Winter's Facebook Page:
Daysan ( ) posted Sun, 08 September 2019 at 4:23 PM
I don't get it, whatever I try it doesn't work. I think I'll just forget to make this. I am just a beginner in this area Thank you for the answers. Greetings elly
jestmart ( ) posted Mon, 09 September 2019 at 10:14 AM
To apply a shader both the object and the surface of the object must be selected.
Daysan ( ) posted Mon, 09 September 2019 at 3:12 PM
yes i dit This is my results till now. But it is not what I want. globe 3.png
