Thu, Jan 9, 6:06 PM CST
Subject: Is there a way to make a slider for an expression?
  • 1
  • 2
RAMWorks ( ) posted Wed, 20 May 2020 at 5:11 PM · edited Wed, 08 January 2025 at 3:48 PM
Hi,
I've been having fun with the facial chips for L'Homme and made a quirky expression that I really like. I saved it out as an expression file but what I'd really love is a way to make it a dial so little bits of it can be used at a time to mix with other dials.
Any help with this?
Thanks so much!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
EldritchCellar ( ) posted Wed, 20 May 2020 at 5:40 PM
Netherwork's spawn.
Dependency Editor.
And probably some waaaaay more obvious method that someone will post in about 5 seconds.
EldritchCellar ( ) posted Wed, 20 May 2020 at 5:42 PM · edited Wed, 20 May 2020 at 5:44 PM
I would just use the Spawn scripts to one click it into an ERC, setting the controller in the head.
RAMWorks ( ) posted Wed, 20 May 2020 at 5:45 PM
Hmm, I think I have his ToyBox. Is that script in there?
My Store is HERE
RAMWorks ( ) posted Wed, 20 May 2020 at 5:51 PM
Found it here at Renderosity but not sure if it works in Poser Pro 11
My Store is HERE
EldritchCellar ( ) posted Wed, 20 May 2020 at 6:13 PM · edited Wed, 20 May 2020 at 6:16 PM
It does. Perfectly. Also you might want to grab Content Creators Toybox. Both are godsends. CCT is a separate product. They're worth the money. All of his scripts are.
Incidentally, D3d's Perfect Skin works in 11 pro if you install Snarly's AVFix. AVFix also fixes a bunch of other scripts that were broken. I recall you had problems with Perfect Skin SSS.
RAMWorks ( ) posted Wed, 20 May 2020 at 6:24 PM
I bought the ToyBox (which I think NW's updated for more current versions) a little while back at Hivewire 3D. I just redownloaded it and installed it. Good to know about Spawn 2014 working still. I'll get that as well!
Thank you so much!
My Store is HERE
EldritchCellar ( ) posted Wed, 20 May 2020 at 6:44 PM
You're welcome. Glad I could help.
caisson ( ) posted Wed, 20 May 2020 at 7:34 PM
The built in way is to use Dependent Parameters. Create a new Master Parameter by clicking on the little white triangle at the side of the Parameters palette and name it. Go to Keyed Dependencies, teach the maximum first, then zero everything, then teach the minimum if required. So press Start Teaching, set the Master dial to 1, set whatever controls you want at their maximum effect, then set the Master dial to zero and make sure all those Parameters are zeroed. Test it and adjust the Settings for your new dial. Then you can make your own dial groups, name them how you like, drag them into an arrangement you like, nest them, and so on.
Refer to the manual - Parameter Dial Groups p219 and Editing Master Parameters, p822.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
DreaminGirl ( ) posted Thu, 21 May 2020 at 1:08 AM
The way I usually use expressions is to use the animation slider. I apply the expression morph at frame 30 or so, then adjust the slider until I get what I like.
Of course, Caisson's solution is much more sophisticated 😁
KarinaKiev ( ) posted Thu, 21 May 2020 at 7:41 AM
Just make sure that you DON'T use a "zero expressions" pose .pz2 to zero the expressions!
I you do, ALL expression dials will be added to the dependant parametes list, which will blow up your character and may cause trouble with other expressions.
So go step by step:
  • Set value 1,000 and dial in everything you need
  • Now set value to 0,000 and ZERO all dials used before, "ONE BY ONE". Repeat: "DO NOT use a "zero expressions" pose .pz2 to zero the expressions!"
It's a bit tedious (like many of Poser's functions). But it's worth the extra time to keep you out of trouble and getting inexpected results in the future.
RAMWorks ( ) posted Thu, 21 May 2020 at 3:00 PM
I think I'll just use Netherworks script. Hopefully he includes a way to make a zero expression option.....
Thanks folks! 😀
My Store is HERE
FVerbaas ( ) posted Fri, 22 May 2020 at 2:17 AM
Forum Coordinator
KarinaKiev posted at 9:14AM Fri, 22 May 2020 - #4389772
Yes a 'zero the dependent parameters at zero dial setting' button would be very helpful.
perpetualrevision ( ) posted Sun, 24 May 2020 at 7:14 PM
Here's another vote in favor of Netherworks' Spawn script (and really, all of his scripts! I have most of them and they work just fine on Poser Pro 11.3).
As for saving a "zeroed" version of a custom expression, you could do that using Netherworks' Dial Manager script, which lets you save pose files or expression files with only the items you want to be included. You can save selection sets, which would also make it easy to also save a "dialed in" version with only the same items included. That's the only way I'd use expression presets to create a Master Parameter within Poser (without using Netherworks' Spawn, which I also have) b/c of the problem Karina mentioned: when "teaching" a Master Parameter dial how to behave, any dial you adjust in the process will get recorded, so you want to be sure only to adjust the dials you need to create the expression. If you applied a standard .fc2 expression (not saved with Dial Manager), it would add every available dial on the head to your Master Parameter, not just the ones that you dialed in, and that creates a real mess!
Two more nifty things about Netherworks' Dial Manager script: it has a way of detecting which dials have changed from their initial value, which can be nifty if you want to save the values only for those dials; and it can also "resolve" ERC dials so that the pose or expression can be applied to a copy of the figure that doesn't have the ERC dial.
TOOLS: MacBook Pro; Poser Pro 11; Cheetah3D; Photoshop CC
FIGURES: S-16 (improved V4 by Karina), M4, K4, Mavka, Toons, and Nursoda's people
GOALS: Stylized and non-photorealistic renders in various fantasy styles
RAMWorks ( ) posted Mon, 25 May 2020 at 7:45 PM
Yea, it's too bad that Joe is no longer around but he got a better gig, I think in Hollyweird but I could be wrong. Be nice to have some refit scripts for various figures for La'Femme and L'Homme. I mean I can do a fit easy enough in ZBrush but allot of folks don't have ZBrush or just don't like the idea of opening up an external program to do a proper refit of hair or clothing! He is missed. I hope he's doing OK!
My Store is HERE
EldritchCellar ( ) posted Mon, 25 May 2020 at 8:38 PM · edited Mon, 25 May 2020 at 8:46 PM
The hair refit for La homme would be tricky. La homme is a different scale/height than the daz Mikes, so it's a morph ( the easy part) plus you have to manually translate and scale the hair before parenting. Whereas La Femme is the same height as v4 and there's a free skull morph for her that allows you to use your v4 hairs on her. I've tried it and it works great. You simply apply the morph, load the hair and parent.
I recently picked up Evilinnocence's Crossdresser license for La Femme and the morph addon, haven't tried it yet but it comes highly recommended. There's more to fitting conformers with multiple actors to another figure than a trip to Zbrush. Well... unless you know how to rig for Poser?
Anyway, you might want to check out Crossdresser for La Homme if you want to convert clothing to the figure. Once you make the conversion/transfer the rig you can use the built in adjustment morphs to fix any nastiness or go further with Poser's morph brush or zbrush for fix morphs ;)
EldritchCellar ( ) posted Mon, 25 May 2020 at 8:52 PM
For La Femme it seems like dynamic is getting top priority in terms of clothes being made for her. There's some really nice dynamic stuff. Deecey seems to be the one that's consistently making high quality conformers for her... I'm hoping that La Femme sticks around for a while. I've grown fond of the figure.
RAMWorks ( ) posted Tue, 26 May 2020 at 5:52 PM
What I've done for the last couple of refits and even bringing body shapes that I made for another figure (Dusk) I just load up DAZ Studio, load the hair, use GoZ to get into ZBrush and refit the hair there, take it back to DAZ Studio and save it out as an OBJ in Poser format, works better than anything I've found so far. I've not tried Cross Dresser yet for hair refits. I think it does a good job with clothing but never tried it with hair!
My Store is HERE
EldritchCellar ( ) posted Tue, 26 May 2020 at 6:23 PM
Ah. I hear DS is pretty good with making refits and transferring rigs etc. Looks like you're good to go. Disregard my insane ramblings lol ;)
RAMWorks ( ) posted Wed, 27 May 2020 at 9:35 AM
Hey, if there is tidbits of useful information in your ramblings I'll take them! LOL
My Store is HERE
RAMWorks ( ) posted Sun, 30 August 2020 at 11:40 AM
Decided it was time to revisit this. Well I had no luck with Netherworks script. It kept telling me there were dials not set to 0.0000 well DUH. I have a mixture of the chips and other dials like eye wince combined. It seems the script will not allow for that?? Strange.
My Store is HERE
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:20 PM
Save your scene before proceeding. Absolute zero fig all but those dials active you want included.
Run Spawn 2014
Set limits, trackingScale(dial sensitivity), and location of master dial...
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:23 PM
You'll be presented with this, the no duh part that hinders your progress...
Just click Yes...
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:27 PM
...which will lead to this. Self explanatory but maybe a little daunting. Your choice here. Only you know really what to choose. Any uncertainty about various and ask...
Click Ok...
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:30 PM
And here's the dialogue that will give you an actual list of all active settings. Pick only those that you deliberately want included. There will be a lot of JCMs and stuff there, ignore those and check only what your expression dial requires...
RAMWorks ( ) posted Sun, 30 August 2020 at 12:31 PM
AH, OK, the checkboxes were the issue. I should have unchecked the two top ones.
I did make 5 expressions using the chips just now. Quite pleased with myself! LOL
My Store is HERE
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:32 PM
Click ok and there's your controller.
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:35 PM
RAMWolff posted at 1:33PM Sun, 30 August 2020 - #4398168
Hm. Are you certain that the control chips contain no rotations? you'll want to experiment and test.
I've been using a combination of spawn and the dependency editor to create my expressions. Copying to inject requires some experimentation also regarding prior statement.
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:40 PM
Custom face with eye and mouth part translations linked to morph and set up with master controllers, custom smile. Used both spawn and the dependency editor. At the moment there's several controllers but they'll all be baked down once I'm finished with custom mouth open expressions... all copy to inject.
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:41 PM
And likewise...
RAMWorks ( ) posted Sun, 30 August 2020 at 12:42 PM
Yea, the chips I use a combination of just about all of the dials including scaling which can make areas like the lips look more natural when making smiles and frowns!
My Store is HERE
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:47 PM
For face expressions with the chips it's not really that important but for body stuff be aware of copy centers to command. Additionally you can set up linked dependencies that will reposition the chips to match new centers and morph location. I did so in my breast morph presets. In general I've found that unless you are doing very extreme morphs the chips work pretty well still without the copy centers to...
EldritchCellar ( ) posted Sun, 30 August 2020 at 12:50 PM
RAMWolff, be careful with scales. They might not copy properly to injection files... something to be aware of.
RAMWorks ( ) posted Sun, 30 August 2020 at 1:21 PM
Hmmm, I'll have to see how they work. I'm working on skin stuff now! LOL Back and forth, back and forth!
My Store is HERE
EldritchCellar ( ) posted Sun, 30 August 2020 at 2:04 PM · edited Sun, 30 August 2020 at 2:04 PM
Taking a break from La Femme and making a freebie for V4 that's been laying around unfinished. Also playing with Glidman's free NoName Doll... would have probably been better served by a toon render, different camera settings, and better lighting, the figure's texture files and eye setup are more geared toward that rather than GI. NoName Doll, despite her toon leanings, comes with a gang of nice content and bends pretty darned good! Surprised no one has made replacement prop eyes for her with proper iris, pupil, and cornea. Easy ;)
Anyway, just being conversational and sharing... sorry for OT. Woolgathering. My reward for answering your query for which I can just about guarantee nobody would have answered. It wasn't about Superfly, which about 5 people exactly know how to use, or "which hair is this" or "I can't get V4 to install" or "Poser is doomed! Genesis Blah blah". I find that Rendo banner "Poser Pulse; Feel it getting stronger" hilariously self defeatist to be honest.
Best wishes
RAMWorks ( ) posted Tue, 08 September 2020 at 11:48 AM
Since I have my expressions completed I was now looking forward to following your directions but in Spawn 2014 I'm not seeing (at the bottom) "Create Controller" or "Key Unsupported" I'm seeing "Spawn Morphs" only. So not sure what or where I would change what Spawn does to make these controllers viewable!
My Store is HERE
RAMWorks ( ) posted Tue, 08 September 2020 at 12:04 PM
OK, got it figured out with the little right sided arrow presenting me with different tools.
So Spawn 2014 doesn't support L'Homme properly. The chips are not in the line up and it keeps telling me that body parts are rotated but they are not rotated, they ARE zeroed out so not sure why Spawn 2014 is telling me something different! So I guess I gotta figure this out differently, perhaps the path that caisson talked about above?
My Store is HERE
RAMWorks ( ) posted Tue, 08 September 2020 at 12:11 PM
I just don't get the "Teach" command at all. Do I apply the expression to the figure and then hit the Teach button? I don't see anything popping into the dependencies dialog. This doesn't seem intuitive to me, so sorry to be such a pita!
My Store is HERE
EldritchCellar ( ) posted Wed, 09 September 2020 at 12:46 PM
Example. How to create a master controller for LF expression chips with dependency editor.
Load figure.
Disable any active IK. Zero Figure
Select figure's head.
Click white triangle at top right corner of parameters; Create new Master Parameter.
Dependency editor will open. You want to be in the Keyed Dependencies tab.
Click Start Teaching. Set dial next to start teaching to 1.
Select right lip control chip and set lower-raise dial to 0.200
Select left lip control chip and set lower-raise dial to 0.200
Go to master dial next to start teaching and set that dial to 0
Click stop teaching.
Zero figure
Go to figure's head and find your new master controller in the Other parameter group. Test. You'll see that the master controls those 2 control chips at the corner of LF's mouth now. Setting this dial to 1 will raise both her left and right control chips by a value of 0.200.
Clicking settings (little triangle to right of relevant dial) will let you create limits on the dial. For this controller I want a value of 0 as my minimum and a value of 1 as maximum. This isn't a morph per se so dialing values past 1 will have no meaningful effect. The translations were only taught to a specific value in the dependencies. We want the value 1 in the master to reflect the value limits (0.2) of what we taught. Not setting limits will result in a free spinning master dial that will dial values past what we set to no meaningful effect for the dependencies. Be sure to check Force Limits after setting up your preferred values.
Also you can adjust dial sensitivity in the settings of the dial. Setting the value to 1 here will make the dial an absolute ON OFF dial. Setting the value to 0.0200 will be an average fast dial. Setting the value to 0.004 will be a sluggish dial.
If redistribution is a thing I would bake down my control chip expressions to morphs. File: Export: Wavefront Object: Head. All options unchecked. Apply export as morph target. There's your expression baked down to a morph. Up to you if you want to copy centers to. For expressions I wouldn't bother.
Control chip derived expressions won't save to the Faces library. They need to be saved as a select subset Pose....
RAMWorks ( ) posted Wed, 09 September 2020 at 12:52 PM
Is there a way, since I have these saved out already at Fc2 files to use the time line to create a dial?
I have the figure set to zero on frame one and then on frame 30 I applied the expression and I can scrub back and forth and see what I'm after easily but then it begs the question if I can then set up a dial using this method?
My Store is HERE
EldritchCellar ( ) posted Wed, 09 September 2020 at 1:13 PM
How did you manage to save your control chip expressions to save as Fc2? I've only had success with Pz2.
EldritchCellar ( ) posted Wed, 09 September 2020 at 1:27 PM
RAMWolff posted at 2:27PM Wed, 09 September 2020 - #4399014
Probably. Let me know how it goes.
RAMWorks ( ) posted Wed, 09 September 2020 at 2:37 PM
Not sure why your Fc2's are not saving out. Mine do.
Well I'm not very good at the internal knowing's of Poser so I have no idea how to set up a way to save out a time line use of my expressions via the dependencies "Teach" tool
My Store is HERE
EldritchCellar ( ) posted Wed, 09 September 2020 at 3:35 PM
Learn something new every day.
La Femme's expressions can only be saved as Fc2 if you are using the yellow rotate dials to create the expressions. These are renamed as Twist (actually zRotate), Side-Side (yRotate), Up-Down (xRotate)
If you happen to use the orange Translate dials; Right-Left (xTran), Lower-Raise (yTran), In-Out (zTran) they won't save as Fc2 but rather only as Pz2.
Weird. Minor mystery solved.
Can't help you with the animation bit. I haven't played with it in years. Keyed dependencies are very much like key frames in animation though. But like I said animation isn't my thing. I also try not to muddy up things by introducing more complications than already exist.
RAMWorks ( ) posted Wed, 09 September 2020 at 3:40 PM
My expressions use MOST of what the chips offer, they all reload to the face just fine!
Yea, I tried creating a new Master Parameter, naming it and then hit the Teach button and slide the timeline slider back and forth and stopped it. Nothing when I use the slider so that's a bust. Looks like this will be a hard NO for having control over the expressions with a slider! SAD!
My Store is HERE
RAMWorks ( ) posted Wed, 09 September 2020 at 3:45 PM
I'm going to try one more thing if I can make it work. Export the posed face out to ZBrush and import it back in as a morph target and see if that will work!
My Store is HERE
EldritchCellar ( ) posted Wed, 09 September 2020 at 3:53 PM · edited Wed, 09 September 2020 at 3:57 PM
Yeah. You don't need to go to Zbrush to do that.
Zero your figure.
Dial the expression.
File export wavefront object. Select the head only. Leave everything unchecked. Reimport to head properties as morph target: load morph target. A morph dial will appear in head that contains only the deformations as a morph. In the head. Not as a PBM or FBM, totally unnecessary, that GoZ will create. Poser 101. Load morph target.
Remember I said this?
"If redistribution is a thing I would bake down my control chip expressions to morphs. File: Export: Wavefront Object: Head. All options unchecked. Apply export as morph target. There's your expression baked down to a morph. Up to you if you want to copy centers to. For expressions I wouldn't bother."
EldritchCellar ( ) posted Wed, 09 September 2020 at 3:58 PM
That is unless you want a bunch of dials in the Body of the figure for expressions that are in the Head?
RAMWorks ( ) posted Wed, 09 September 2020 at 6:41 PM
Ah, OK. Sorry, was doing a client, he's gone now. I can get back to work.
My Store is HERE
RAMWorks ( ) posted Wed, 09 September 2020 at 6:48 PM
Hmmm, before I do this, in the export dialog there are ALLOT of parts to the head. Do I check all of those or just the entry "Head" ?
My Store is HERE
EldritchCellar ( ) posted Wed, 09 September 2020 at 7:02 PM
Just head. Click the top box for Universe to clear out everything. Then just select the head. You want to capture all the deformations made to the Head actor by the various bones of the face. Reimport as morph target to the head. Zero out your expression. Dial new morph to 1. There's the expression deformations without all the bones being involved...
  • 1
  • 2
