Mon, Jan 6, 2:34 PM CST
Subject: Rendered in Superfly
hborre ( ) posted Thu, 09 April 2020 at 9:23 AM
Online Now!
Very nice.
hornet3d ( ) posted Thu, 09 April 2020 at 2:48 PM
ghostship2 posted at 8:47PM Thu, 09 April 2020 - #4385798
Thanks
That looks better! hornet3d posted at 8:04AM Thu, 09 April 2020 - #4385485
OK so here's the second attempt.
bobbesch ( ) posted Mon, 13 April 2020 at 9:40 AM
BeetlePS.jpg Found an old model from Toffanello in a forgotten runtime and thought to give it a go with superfly.
ghostship2 ( ) posted Mon, 13 April 2020 at 2:13 PM
Everything is better with Superfly!
Miss B ( ) posted Mon, 13 April 2020 at 2:39 PM
bobbesch posted at 3:39PM Mon, 13 April 2020 - #4386123
Very nicely done. 🙂
_______________
Butterfly Dezignz
bobbesch ( ) posted Tue, 14 April 2020 at 1:50 AM
Thanks!
raven ( ) posted Wed, 15 April 2020 at 11:30 AM
ghostship2 posted at 5:28PM Wed, 15 April 2020 - #4386165
Except for items that use/need micro-poly subdivision displacement! 😁
ghostship2 ( ) posted Sat, 18 April 2020 at 9:53 AM
:) raven posted at 8:53AM Sat, 18 April 2020 - #4386303
hborre ( ) posted Fri, 15 May 2020 at 4:53 PM
Online Now!
Through the asteroid field!!!
structure ( ) posted Sat, 16 May 2020 at 9:34 AM
Forum Coordinator
Locked Out
Kalypso ( ) posted Tue, 19 May 2020 at 2:14 AM
Site Admin Online Now!
I really like all these little splashes of colour against the white!
ironsoul ( ) posted Mon, 25 May 2020 at 9:22 AM
Curious if anyone has thoughts to moving to 8K maps, we have been using 4K since 2006 at least. Below is an 8K interpolated from 4K miki textures,
ader ( ) posted Mon, 25 May 2020 at 1:33 PM
I've started using 8k maps for hair, not simple resizing though. So far I've just taken 4k maps into photoshop and quadrupled them so the details/hairs are finer. No issues with RAM so far, even my 6-year-old iMac has 32GB RAM.
What's your process for moving 4k to 8k? My other half is a graphic designer and she finds: http://waifu2x.udp.jp useful so I thought I'd try it, but it didn't seem to make any difference for me.
That eyebrow looks good btw... is that standard miki? texture or geometry or both...?
Maybe we should start a 4k versus 8k comparison thread?
ironsoul ( ) posted Mon, 25 May 2020 at 3:59 PM
8K texture map was generated in Substance Painter from a mixture of 4K base Miki textures and the texture.xyz demo mat that came with SP. I was surprised how much the jump in resolution improved the details, guess much of this is anti aliasing. I'll see if its possible to generate some native 8K textures and do another test.
NobbyC ( ) posted Wed, 27 May 2020 at 2:30 AM
8K texture are great! This is a free model fro RenderHub with 8k textures
NobbyC ( ) posted Thu, 28 May 2020 at 9:44 AM
For about 3 weeks, i ask myself if it is possible to get the same effect as light passes through an prisma.
Stupid idea. It takes many test render and sleepless nights.
Here is the result:
And some of my test render:
ironsoul ( ) posted Thu, 28 May 2020 at 7:23 PM
Intriguing project, modelling IOR for multiple wavelengths could potentially be applied to other uses such as SSS and special effects like chromatic aberration.
NobbyC ( ) posted Fri, 29 May 2020 at 2:08 AM
The idea behind was, to create an better "gemm / diamond shader". On the beginning i played a lot with glass and refaction shaders. But at the end it was very simpel, i only need for the prisma a "glass shader" and for the rainbow effect i use "light path and transmision rays"
ghostship2 ( ) posted Sat, 06 June 2020 at 2:21 PM
For details that small when using an 8k map wouldn't it be helpful to also use uncompressed TIFF or PNG files? You can see the files compression artifacts in bump maps on reflective surfaces.
estherau ( ) posted Sun, 07 June 2020 at 5:42 AM
ghostman - the image with the girl in sunglasses and hat looks 100% photo real to me. very nice image - lovely character and pose. skin looks amazing. lighting is perfect. REally good job!!
MY ONLINE COMIC IS NOW LIVE
NobbyC ( ) posted Mon, 08 June 2020 at 1:08 AM
Hi ghostship2, sorry for my late reply. That is a really good question and i think that you are right.
The most figures with 8K textures that i found have PNG files for the texture maps but sometimes they use TIFF files for bump or normal maps.
But our problem in "Power world" is that these files are very huge and my graphic card won't like it (Only 6 GB ram -> cuda error).
For my render "back out of hell" i have to cheat a little bit. This model has a lot of polygones so i use for the upper torso the 8k textures and for the lower torso only the 2k textures.
ader ( ) posted Wed, 10 June 2020 at 9:41 AM
ghosthip2 is right, uncompressed image formats are better for rendering. They don't take more memory because even compressed images are uncompressed for use. The only benefit to compression is file-size on a hard-drive (and size to download if relevant). So use uncompressed where possible, especially for close-ups.
NobbyC ( ) posted Mon, 15 June 2020 at 7:47 AM
GND: Anastasia by Blackhearted. Still my favorite Poser character.
NobbyC ( ) posted Thu, 18 June 2020 at 3:03 AM
WIP - The Metropolitan Collection - London V4.2 by danae
CHK2033 ( ) posted Thu, 18 June 2020 at 12:18 PM
Pretty
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
NobbyC ( ) posted Fri, 19 June 2020 at 1:05 AM
Thanks!!! But is still not finished yet. The Necklace and cloting needs some more adjusting.
DarthJ ( ) posted Sat, 27 June 2020 at 1:25 PM
Who needs a full beach ?
ghostship2 ( ) posted Sat, 27 June 2020 at 8:02 PM
I just bought some new shoes for V4 and wanted to show them off... Amethyst 1.jpg
Miss B ( ) posted Sat, 27 June 2020 at 11:05 PM
Uhhhh, did you forget to render the shoes you just bought for V4????? 😉
_______________
Butterfly Dezignz
TwiztidKidd ( ) posted Mon, 29 June 2020 at 12:02 AM · edited Mon, 29 June 2020 at 12:04 AM
@ghostship2 - Those shoes don't work with that outfit lol
@Miss B - I know... right? Whose idea was it to put them waaaay down there... on your feet? On your hands would be so much easier 😄
VedaDalsette ( ) posted Mon, 29 June 2020 at 9:42 AM
I wish Superfly didn't take so long. This took me at least a half hour to render. I selected Superfly Ultra non-branched, HDRI, no lights. I'm no artist, so, of course, I have no clue what looks good and what doesn't. But, just like a certain unfortunate world leader, lack of knowledge, skill, and judgment won't stop me!
"With the right color dress, you don't have to worry about grass stains."
W10, i5-8600K @ 3.60GHz, 32.0 GB RAM, 64-bit, video GeForce GTX 1050 Ti, 4096 MB
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
rokket ( ) posted Tue, 30 June 2020 at 9:02 AM · edited Tue, 30 June 2020 at 9:03 AM
Superman WIP.jpg Superfly. Don't remember the settings. ezdome and an HDRI I got from HDRI Haven. This was one of my first attempts with Superfly and I botched a lot of stuff. I still had a lot of artifacts that are plainly visible.
VedaDalsette ( ) posted Tue, 30 June 2020 at 10:32 AM
rokket, which size HDRI do you use from HDRI Haven? And do you subdivide your sphere?
Old lady hobbyist.
ghostship2 ( ) posted Thu, 09 July 2020 at 11:59 AM
another portrait. It's what I do.
DarthJ ( ) posted Sat, 11 July 2020 at 11:21 PM
qaz ( ) posted Fri, 17 July 2020 at 1:04 PM
I've been working on this for a while. Just Superfly. Sorry didnt use Ghostships hair mats. Got bored and wanted to publish. V4 model.
PilotHigh ( ) posted Thu, 30 July 2020 at 3:25 PM
Just quick renders of the Ancient Persia Kitbash sets.
NobbyC ( ) posted Thu, 06 August 2020 at 5:03 AM
Soon in Alain's store (3DClassics) this beautiful "Car rapide" Renderd in Poser Pro 11 with "superfly"
DarthJ ( ) posted Fri, 14 August 2020 at 10:44 AM
More than 30°c outside combined with mandatory face masks. Somebody wants us to die. This image is meant as a computer screen background.
ghostship2 ( ) posted Mon, 17 August 2020 at 5:37 PM · edited Mon, 17 August 2020 at 5:37 PM
Good stuff! Were the hair shaders taking too long to render?
qaz posted at 4:36PM Mon, 17 August 2020 - #4394668
qaz ( ) posted Mon, 24 August 2020 at 12:13 AM
ghostship2 posted at 12:04AM Mon, 24 August 2020 - #4397199
No just takes me a while to set up using Snarly script. I'm spending all my time improving the morph. I'm never satisfied. Of course I only have to do it once, so I'm being lazy.
johnpf ( ) posted Sun, 30 August 2020 at 5:25 AM · edited Sun, 30 August 2020 at 5:26 AM
Rejuvenating an old Maddie 3 figure.
This is the feeling I used to get on a Sunday evening, with the threat of a week of school hanging over me. EDIT: Of course, back then there were none of the videogame consoles shown here. I'm not that young!
ghostship2 ( ) posted Tue, 01 September 2020 at 9:56 PM
@johnpf Something off about the texture map you used on Maddie. I am assuming this is supposed to be a child and not an adult midget? Too much freckles and age spots, the eyes have dark skin/makeup around. Just a thought.
johnpf ( ) posted Wed, 02 September 2020 at 5:28 AM
Ghostship2: Now that you point it out, yes I see what you mean. Thanks for mentioning it!
