primorge posted at 5:38 AM Tue, 23 August 2022 - #4443190
I think that might be because my loader can only generate deltas along the normal directions for sub-d levels greater than 0. I couldn't figure out how Poser encodes the other directions, so if I included them, that produced garbage. I'm assuming the authors of the GoZ loader had access to the Poser source code, so they didnt' have to guess.Glad you figured it out. That's not the issue I was having, mine was the morphs appearing less refined than I originally made them in the sculpting software. Sort of like it was dumping a subdivision level or something, like it was at the proper level but the results were as if at a lower level. I didn't do any further testing because SudD morphs weren't a priority at the time. I'll do some tests and post what I come up with.
A likely way around it is to create some fixed deltas, see where that makes Poser move the points, and from that create an atlas of sorts that can be used to transform world space deltas into the form that's needed to create the correct morph. I think that atlas creation might be quite slow and involve some writing and loading of intermediate files, but maybe it could be done once for each figure and then the loader could stash the atlas away for future use. Something to try one day, when I feel adventurous.
Antonia's critical point regarding automatic grouping was the strake between the breasts, where garments that do not have a recess between the breasts and spans from bust point to bust point. The garment then is at some distance from the chest facets while the normals of the facets of the breasts point across it. I recall some cases where the fitting room generated grouping did not have a line of chest facets separating the facets of the left and right collars.
One way around this is a spandax morphed donor figure.
Well, if I change the geometry file anyway, maybe I could modify the collar groups to that they don't include the breasts. If I understand you correctly, that would help with the auto-grouping of clothes?
To clarify what I see happening with a subd morph when a body part is set to "subdivide separately from figure." The image on the left shows unmorphed Antonia at subd 2, the one on the right a test morph I made in Blender and loaded into Poser with my script, the middle one what happens to the test morph when I subdivide the eye separately. If you look closely, you see the smoothed out remnants of the lower one of the two ridges I made, which happened to align with the subd mesh and thus get baked down. The upper ridge on the other hand is completely gone.
Leave the iris flat. It's easier to morph a convex/concave from a flat than vice versa. Concave is a hack to give the illusion of refraction. Not necessary. A tiny bit of conconvity is fine, otherwise it's just more of a PITA.
I'm hoping you welded the iris to the sclera... Creating Iris morphs are nearly impossible, or extremely more difficult, otherwise. Having unwelded parts to an eyeball makes 0 sense. It just introduces problems and solves none.
Remember something, these are Poser figures, not Humans. While its good to always try and emulate what goes on in a human body anatomically and surface for better realism, often times in practice the results just won't work or be unnecessarily complex. They're 3d models. More like cartoon simulations that have to obey a different set of rules than what might seem right from a human anatomy perspective. Just my take on it.
hborre posted at 9:30 AM Thu, 25 August 2022 - #4443311
V4's eyes are a mess. I don't know what they were thinking there. By comparison Genesis' eyes are way better.Point taken. I do agree with the iris morph though, no need to overcomplicate a feature that won't be noticed in an average scene. V4 has a morph builtin for the iris.
Here's a better view of what I currently have, mesh-wise. Yes, the iris is welded to the sclera, and the cornea is extended to go all around. I think the outer iris should probably be slightly concave with a gentle rim in order to catch the light correctly. But honestly, I have no strong opinions as far as eye construction is concerned. As long as it's easy to do and I can get decent renders out of them, I'm very open to suggestions.
ETA: And yes, I realize that rim around the iris is by no means gentle yet.
hborre posted at 8:28 AM Thu, 25 August 2022 - #4443305
For the cornea, I'm using this shader that you taught me. Since the cornea covers the whole eye, I'm hoping it will take care of all the required glossiness.Slightly concave is the preference just like human eyes. As for PBR, some users are incorporating a glass shader as opposed to a glossy one for eye work.
There's a lot of questions...
The eye mesh you show above is just about perfect in my opinion. Plus you have the cover completely enclosed, which I like very much and you rarely see. In fact both the cover and eyeball both look water tight which is great. It's a little thing but covers certain situations you might not expect.
I prefer a receded pupil like you have in your image. It doesn't effect any realism and makes morphing a lot easier; octopus, rectangular, and star shaped pupils are easy to make with such a pupil.
The square grid is much much better than the pole. I'd say the topology you have for all parts is about ideal, at least for my preferences.
As far as the hard rim goes you can just slide those loop a bit further apart from each other. It can be done as a morph but it's probably best to bake that softness into the base topology before you UV.
Very well done odf, perfect imo really.
The only problem I can see you having with that kind of configuration is it makes UV mapping more difficult. Just as long as the frontal is completely flat UVs, you can get away with some distortions at the back. Obviously it might bother a perfectionist but it's tricky to get it done without a bit of stretching (sometimes quite a bit actually). If you can manage UVs that are at the lower range of stretching or distortion I'd be mightily impressed.
odf posted at 2:24 AM Fri, 26 August 2022 - #4443369
Just my 2-cents:
I have tested your solution with my Sasha19 (a weightmapped Vic4) and that give the left part below.
On the right part: Ghostship's explaination (a fewdays ago: using a Blinn node)
The result: we can also see point-like lights, which disappear using Gloss or Glass nodes.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I have seen that post and I do not totally disagree with the node arrangement. But if you examine the Blinn reflectivity, the setting is unrealistically too high for organic material like the eye. That value should be slightly lower; for portrait renders, it is good enough to have that hint of catch-light, a sparkle to the eye. It really comes down to artist preference and how you want the image to render.
Good pointI have seen that post and I do not totally disagree with the node arrangement. But if you examine the Blinn reflectivity, the setting is unrealistically too high for organic material like the eye. That value should be slightly lower; for portrait renders, it is good enough to have that hint of catch-light, a sparkle to the eye. It really comes down to artist preference and how you want the image to render.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
primorge posted at 11:22 AM Fri, 26 August 2022 - #4443375
Phew! Glad to hear it. Seriously, your approval means a lot.Very well done odf, perfect imo really.
This kind of modeling is really easy to do in Blender. Also, I built these from Antonia's original eyes, so the existing UVs should basically still work. I wasn't going to touch the UVs at this point unless I had to.
Toni's new breasts after some mesh surgery, more mesh surgery to copy the topology changes from her left breast to her right breast, some smoothing and reshaping, and an extra round of emergency mesh surgery after I noticed that the previous surgery had messed up the UVs.
And a render with new eyes and breasts:
Geometry changes so far:
- brows removed
- toe caps removed
- eyes rebuilt
- breasts retopologized
I don't want to make too many further changes at this point, lest I trigger my perfectionist streak and end up faffing about with mesh and shape changes ad infinitum. I am debating though if I should take the opportunity and add a few strategically placed polys to her vulva while I'm at it.
If I do that, I might not be able to share any pictures of that work here, seeing as the TOS explicitly forbids genital-centric imagery. I'm not sure if that's restricted to gallery renders and maybe crotch shots of mesh WIP would be acceptable, but better err on the side of caution. If a mod happens to read this, feel free to weigh in.
Primorge your post has been removed because it was a Terms of Service violation.
No Physical arousal [This includes but is not limited to]: no images of an erect penis/ no “implied” erection through clothing/ no images showing the inner portion of the vulva or vaginal area.
Any image that is exclusively depicting genitals or breasts is subject for review or removal.
Please refrain from posting images like this.
To be perfectly honest, I don't want to even start imagining what kind of issues Lovecraft had with vulvas. From what I hear, that person's mind was the biggest horror of all. But I was talking pre-sculpt here, so shape-wise it's more in the camel-toe Barbie stage right now.
Anyway...
Here's a quick side-by-side render of the current vs future Antonia, with the corresponding mesh parts. We can't really see those extra edge loops, but even just knowing they exist is so exciting.
You may have noticed that Toni's looking slightly cross-eyed in the "after" shot. That's because I've seen the light and modeled her new eyes pointing forward rather than at a slight outward angle. So much easier to work with. The actor coordinate system will also be axis aligned, of course. The anti-cross-eyed fix can easily be done with a dial.
The cross eyed thing is something I've seen with a few Poser figures that have strict axis aligned eyes. Seems like the larger the eyes the worse it might appear, toon figures for instance. 3d Universe's Skye had this problem. It's also somewhat dependant on how the socket modeling is done, if the lacrimal is farther from the sclera contact this helps to alleviate that somewhat. This does give more of a deep set appearance though.You may have noticed that Toni's looking slightly cross-eyed in the "after" shot. That's because I've seen the light and modeled her new eyes pointing forward rather than at a slight outward angle. So much easier to work with. The actor coordinate system will also be axis aligned, of course. The anti-cross-eyed fix can easily be done with a dial.
She’s looking good so far.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
I think I'm done with the topology changes, so I had another go at transferring Antonia's existing rigging in the fitting room. Looking pretty good, as far as I've checked so far.
- Groups have carried over nicely except for the eyes which had some of their polys assigned to the head. I don't know a software that's good at editing poly groups directly except maybe Wings (but honestly, I can't remember, it's been too long), but there are workarounds.
- The jaw WMs look good except for the usual isolated vertex out of place on the upper lip, which I can fix very easily.
- JCMs mostly look good, but will need a tad of cleaning up. Probably not too much work, so I'll have a go at it even though eventually I'd like to weight-map the figure and dial down JCM usage to a minimum.
- Other morphs seem to generally transfer well, including the expression morphs. But I might reload those from OBJs anyway, just to be on the safe side.
I think that's everything. Here's a test render:
For the real transfer, I'll start with a stripped-down version of the Antonia 1.2 CR2 and add details back by and by using whichever method works best for the task at hand.
After some juggling between Poser, Blender and the Unix sed program, I now have an OBJ with the new mesh and the correct grouping. So in particular, the eyes can now move about without exploding. I've also had a closer look at the JCMs and it seems that they're only a bit off at the body part seams. Should be an easy fix.
Looking good! Will this model be released?
As far as Fverbaas' observation goes, it's easy to create a morph for the breasts that emulates a spandex. Sort of like the figure is wearing a clingy tshirt. I've made this on a few occasions, frequently before a retopo when I want to extract a geometry to create a dynamic shirt. I create the spandex between the breasts and completely flatten the navel into the surrounding mesh. This could easily be included in your utility morphs.
