Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
primorge posted at 4:24 PM Wed, 5 October 2022 - #4445918
Thank you. I added the stairs and a safety rail. I will post another pic of it later.Nice work on that Rokket 👍
Just have to figure out how to punch a hole in it.
I changed the textures around a bit. It's still probably too clean, but I'll dirty it up. I need to do a little bit more work on it. I can see when I subdivide in Poser that things don't look quite right. I still need to attach the supports to the legs. And the safety rail isn't right. But I don't want to get too detailed either. Just enough to sell the visual. It will be visible in the background of the scene, and of course a close up on the tank when Kara goes through it...
50% scale again.
Subdivision in Poser isn't forgiving with non-organic objects. You're better off modeling it in. Taking a look at images of actual water towers, the ladder scaffolding like the one you're creating simply doesn't commonly exist. You either have a regular ladder going straight up to the tower or the ladder built along the struts.
A remake of the classic battle of Superman vs Clark Kent from Superman 3.
I found out canon is that BLACK Kryptonite is what causes the good/evil split in the comics. The yellow stuff that Gus Gorman made in Superman 3 was just for the script. So I will reference it in the opening sequence, which will take a few days to do.
Yeah, I need to get myself a dedicated external hard drive so I can save all the pz2's that I make. Once I figure I am done with them, I tend to delete them since my laptop hard drive isn't very big.
I could redo it, I guess. But that will take a lot of time.
I have the water tower about 50% complete. I am still going to add linkage to the legs from the support struts, and make a ladder. I am going to work on better textures. I am thinking maybe I should model the roof as wood. This model is at 50% scale in Poser:
