Thu, Nov 21, 9:51 PM CST
Subject: Dwarvez rendering problem.
mr_red ( ) posted Sat, 20 May 2023 at 2:03 PM · edited Thu, 21 November 2024 at 9:50 PM
Online Now!
has any body else had this problem rendering Dwarvez? As you can see he looks find untill he is rendered the this happens, I have never had this problems before with clothes in all the years I have used poser so i'm baffled. Im use poser 11.
Sunfire ( ) posted Sat, 20 May 2023 at 2:38 PM
By any chance are you rendering in superfly instead of firefly? Go into render settings and select Firefly and see if you still have the problem, if you don't it means you're rendering in superfly and the materials aren't set up right for superfly.
Sunfire's Creations
hborre ( ) posted Sat, 20 May 2023 at 2:42 PM
Online Now!
Two places, try copying joint zones from the Dwarf to the clothing (Figure > Copy Joint Zones from...) and under Parameters/Properties, check the boxes under 'When Conforming'.
TwiztidKidd ( ) posted Sat, 20 May 2023 at 2:44 PM
There's something wrong with his outfit. Perhaps a transparency map has been altered. Delete his outfit and load it back on.
You could render just the outfit by itself to make sure it's okay before you conform it to him.
If it still looks messed up, download and re-install the outfit overwriting the existing files.
hborre ( ) posted Sat, 20 May 2023 at 2:46 PM
Online Now!
Sunfire posted at 2:38 PM Sat, 20 May 2023 - #4465892
There shouldn't be any difference between the two render engines.  The only maps that might cause the problem would be incorrect gammas on grayscale and transparency maps.
hborre ( ) posted Sat, 20 May 2023 at 2:52 PM
Online Now!
TwiztidKidd posted at 2:44 PM Sat, 20 May 2023 - #4465895
It's not transparency maps causing the problem, those are pokethroughs.  Without seeing how the material zones are set up, it is difficult to judge whether there is a problem with the maps and gamma settings.
hborre ( ) posted Sat, 20 May 2023 at 3:04 PM
Online Now!
@mr_red: Judging from the difference in the preview and the render, it appears that you are attempting to render Firefly Material in Superfly.  Please verify this information or elaborate further what is your workflow.  Also, provide a screenshot of your Material Room.
mr_red ( ) posted Sat, 20 May 2023 at 3:18 PM
Online Now!
to anser one question. i tried it in both render setting before i posted and they are the same result. this was rendered in firefly.
thanks for the help so far i will make notes and try a few things out .
mr_red ( ) posted Sat, 20 May 2023 at 3:29 PM · edited Sat, 20 May 2023 at 3:29 PM
Online Now!
as you can see the clothes alone still look bad.
meaterial room of the vest.
mr_red ( ) posted Sat, 20 May 2023 at 3:45 PM
Online Now!
I just made a small bit of headway buy unticking the displacment box . you dont get the poke through . but the clothes are still going grey? as you can see the skin is fine!
Rhia474 ( ) posted Sat, 20 May 2023 at 4:19 PM
The material settings are all wrong for newer Poser versions, yeah. I managed to untangle in Superfly by using the GoPhysical script, but wow, indeed. Firefly looks awful.
TwiztidKidd ( ) posted Sat, 20 May 2023 at 4:33 PM · edited Sat, 20 May 2023 at 4:41 PM
Do you have an option to make his outfit look weathered and one to make his outfit look new? Does it give you that option in the description, the store you got the outfit from? What's his outfit called?
The chewed up look of his outfit looks like a setting to make him look like he's a zombie or undead.
RedPhantom ( ) posted Sat, 20 May 2023 at 4:42 PM
Site Admin Online Now!
The alt specular is too high. The shine is washing out the colors. And uncheck the reflect lite multi
hborre ( ) posted Sat, 20 May 2023 at 4:55 PM
Online Now!
First, lets untick the Reflection_Lite_Multi, that's probably what is causing the over metallic look.  Next, expand all the nodes to display the previews and settings.  I see a potential problem but without the expanded nodes, I can't be sure.  Get rid of the Edge_Blend node and plug the image map into the Diffuse Color; drop the Diffuse Value to 0.85, it's too high.  No natural material is 100 percent diffuse.  Disconnect the texture map from the Specular Color, it's value is 0 and not contributing to the rendering calculations.
TwiztidKidd ( ) posted Sat, 20 May 2023 at 5:20 PM
I forgot how to use Poser but yeah re-download it and re-install everything. Thank you for the figure, nice find!
hborre ( ) posted Sat, 20 May 2023 at 5:24 PM
Online Now!
TwiztidKidd posted at 5:20 PM Sat, 20 May 2023 - #4465929
That will not fit anything unless the file is completely corrupted.  I don't think that is the case.  It's a Poser 7 compatible figure with some serious ancient hacks.  Aside from completely converting it for P11, the Firefly part can be repaired and refurbished.
TwiztidKidd ( ) posted Sat, 20 May 2023 at 5:59 PM · edited Sat, 20 May 2023 at 6:05 PM
Version 4, 5, 7 and 10 is all I have installed. Sometimes you could save a lot of time using an older version of Poser to render.
Rhia474 ( ) posted Sat, 20 May 2023 at 6:10 PM
And since the OP stated they use P11, those versions you are using are of no help unfortunately.
Rhia474 ( ) posted Sat, 20 May 2023 at 6:12 PM
hborre posted at 4:55 PM Sat, 20 May 2023 - #4465925
Goodness, didn't even realize it has Refl_Lite_Multi there. That's old.
hborre ( ) posted Sat, 20 May 2023 at 6:14 PM
Online Now!
It's a Poser 7 figure, definitely an update candidate.
mr_red ( ) posted Sat, 20 May 2023 at 6:48 PM
Online Now!
thanks for all the help guys, it's past midnight where i am so i will take notes  when i get up and try a sort this with freash eyes. I will post results. just to add I just tried adding the other dwarf outfit i bought and that renders ok so i do know now its down to the settings.
mr_red ( ) posted Sun, 21 May 2023 at 1:08 AM · edited Sun, 21 May 2023 at 1:08 AM
Online Now!
I have followed the instructions given and below are the results and the stats (i have made them as big as i can.)  bit better but still washed out look.
TwiztidKidd ( ) posted Sun, 21 May 2023 at 6:16 AM · edited Sun, 21 May 2023 at 6:18 AM
Did you re-download and re-install the updated version of Dwarvez?
This updated Dwarvez includes Dwarvez_P9SSS material preset for Poser 9 and higher.
" 3 Full Body Morphs, teeth morphs and P9 material preset (with normal map) "
mr_red ( ) posted Sun, 21 May 2023 at 7:01 AM
Online Now!
I think thats the same as i have but i will do as you say and give it a try thanks.
TwiztidKidd ( ) posted Sun, 21 May 2023 at 7:13 AM · edited Sun, 21 May 2023 at 7:16 AM
Cool, once you finished installing it, apply the selected P9SSS material to your character. Start fresh, especially the clothes + boots :)
Happy Sunday.
mr_red ( ) posted Sun, 21 May 2023 at 7:36 AM · edited Sun, 21 May 2023 at 7:36 AM
Online Now!
TwiztidKidd posted at 7:13 AM Sun, 21 May 2023 - #4465972
Happy Sunday.
I did that and....back to square one!
TwiztidKidd ( ) posted Sun, 21 May 2023 at 7:50 AM · edited Sun, 21 May 2023 at 7:52 AM
Dang, that means the update is only for the character, not the clothes and boots.
You will have to manually create your own P11 leather-like material for each and every one of them: the vest, pants and boots.
Use the 1 texture map and 1 bump map given for each piece of clothing found in the Texture folder. It's something you would have to do in any 3D rendering program.
Do you know how to do that?
TwiztidKidd ( ) posted Sun, 21 May 2023 at 7:54 AM
Unless... someone that has P11 installed wants to do it for you, that would help a lot!
TwiztidKidd ( ) posted Sun, 21 May 2023 at 8:26 AM · edited Sun, 21 May 2023 at 8:30 AM
How good are you at editing stuff? lol You would have to edit four of the .mc6 files shown in my screenshot above, using notepad or a text editor. It's not too difficult.
You'll have to do this for each .mc6 file:
RedPhantom ( ) posted Sun, 21 May 2023 at 8:29 AM
The problem lies in the glossy node. When I use your posted shaders, I get this
When I disconnect the glossy node from the alt specular, I get this
TwiztidKidd ( ) posted Sun, 21 May 2023 at 8:36 AM
Four .mc6 files to edit:
The pants and the vest are figures
The bracer and the boots are props... I think
TwiztidKidd ( ) posted Sun, 21 May 2023 at 8:55 AM
https://sharecg.com/v/84580/browse/10/Software-and-Tools/MC6-to-PZ2-Batch-Converter
mr_red ( ) posted Sun, 21 May 2023 at 9:00 AM
Online Now!
I have no clue how to edit files that way @TwiztidKidd. I know roughly how to use templates to make new textures with my are program, but ive never coded them.
mr_red ( ) posted Sun, 21 May 2023 at 10:00 AM
Online Now!
well with the help of you guys and working a few things out i came up with a solution im happy to say (as this has been annoying me)  I will put my solution here for people who might have the same problem at some point.
1. uncheck reflection lite mult
2. lower deffuse value to .85
3 delete all nodes leaving only Image map and image map 2
Image map connects to Diffuse col and spec col.
Image map 2 connects to bump and Displacement.
this needs to be done on every part of each clothing item.
huge Thanks to you guys for the advice.
