Mon, Feb 3, 7:25 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 03 2:54 am)
Subject: Show your Poser 13 renders!
RAMWorks ( ) posted Sat, 23 September 2023 at 4:26 PM
Oh, thank you so much!
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
Y-Phil ( ) posted Sat, 23 September 2023 at 4:37 PM · edited Sat, 23 September 2023 at 4:37 PM
Thalek posted at 4:08 PM Sat, 23 September 2023 - #4475126
Y-Phil posted at 4:17 PM Fri, 22 September 2023 - #4475052
RAMWorks posted at 11:14 AM Fri, 22 September 2023 - #4475029
Really gorgeous and classy!  Love to know your lighting setup for this render.  Care to share?
Not sure if my response deserves the Nudity tag... LQnEsI1Eue7qTjqL5wSa1fBWlzKkpJVEYIGSIrQj.gif
I have used three cylinders, strategically placed:
Each cylinder uses a material described by... I don't remember who, but it was here. This setup lets you control:
- the temperature of the light
- power
- and even the distance
No sphere around, background node 100% neutral (Poser's default one)
One of my default scenes uses a similar setup, with the big cylinder and an HDRI on the background node, in order to make some cool portraits.
Quite a sophisticated approach to lighting, at least by my standards as a dilettante.
Thank you for the detailed explanation; I would never have thought of this.
In fact: I've started with my "Studio" startup scene:
- background node with  an HDRi
- area light behind
- the bog cylinder in front
But as you may guess, an area light behind will be visible on the ground, and instead of using a spot, I wanted to try a second cylinder.
Then, I was missing a ray of light on her right thigh, hence the third one.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Y-Phil ( ) posted Sat, 23 September 2023 at 4:39 PM · edited Sat, 23 September 2023 at 4:39 PM
RAMWorks posted at 4:26 PM Sat, 23 September 2023 - #4475128
You're welcome, and it was the least I could do with all what I've learned here qiq00Vv6Qp6S70uLStOEaYt6ae30a6Dmu483mn0v.gif  (distance-controlled lights, better skin, etc...)
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
shvrdavid ( ) posted Sat, 23 September 2023 at 5:04 PM
The magic of lights that don't show :)
Y-Phil ( ) posted Sat, 23 September 2023 at 5:45 PM · edited Sat, 23 September 2023 at 5:45 PM
shvrdavid posted at 5:04 PM Sat, 23 September 2023 - #4475132
Couldn't agree more: these intimate portraits are wondereful
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Bastep ( ) posted Sat, 23 September 2023 at 7:14 PM · edited Sat, 23 September 2023 at 7:15 PM
Hello
New image: Relaxing
La Femme, with the skin based on Gostship's wonderful thread.
The dress is homemade and dynamic.
Have a nice day and good night.
shvrdavid ( ) posted Sat, 23 September 2023 at 8:43 PM
Bastep posted at 7:14 PM Sat, 23 September 2023 - #4475147
Hello
New image: Relaxing
Excellent render :)
Bastep ( ) posted Sun, 24 September 2023 at 5:23 AM
Thank You! :)
RedPhantom ( ) posted Wed, 27 September 2023 at 7:48 AM · edited Wed, 27 September 2023 at 8:46 AM
Site Admin
My first image with Lafemme 2. She's wearing clothes for Lafemme. I only converted the boots. The rest is dynamic and works with the Lafemme shape dial. I used the convert textures script and used a Lafemme texture. Hair was one for  Lafemme and used a Lafemme 2 fit morph. The pose is for Lafemme and used the Lafemme pose dial. The shown shape is her original since I don't have any morphs for her yet.
Bastep ( ) posted Wed, 27 September 2023 at 8:03 AM
Somehow the link to your picture is broken.
RedPhantom ( ) posted Wed, 27 September 2023 at 8:50 AM
Site Admin
Hopefully, the image shows now
Bastep ( ) posted Wed, 27 September 2023 at 11:20 AM
YES! :)
RedPhantom ( ) posted Wed, 27 September 2023 at 4:15 PM
Site Admin
I hadn't planned on spending today playing, but when you get a new toy, it's hard to resist.
hborre ( ) posted Wed, 27 September 2023 at 9:36 PM · edited Wed, 27 September 2023 at 9:36 PM
I was curious if La Femme conforming clothing could be converted to LF2.  So I ran a simple test on V4 cosplay outfit converted to LF.  Results below.
The Tinkerbell dress was originally created for V4 and converted to fit LF.  It is a conforming outfit.  I loaded LF2 into a P13 scene and used the animation palette to animate the transformation from LF to LF2.  Adding the outfit in Frame one, I entered the Fitting Room to create a prop and then entered the Cloth Room to run the transformation animation for 30 Frames.  I had to add constraints to the top of the outfit to prevent it from slipping down during simulation.  After it was done, the final outfit was taken into the Fitting Room again to create the conforming figure.  This may be the first post of LF2 wearing a conforming outfit.
RAMWorks ( ) posted Thu, 28 September 2023 at 9:10 AM
Looks great on her!  Well done!
My Store is HERE
shvrdavid ( ) posted Thu, 28 September 2023 at 11:31 AM · edited Thu, 28 September 2023 at 11:32 AM
Some things, just stop traffic.....
SS Lemura for LF2
RAMWorks ( ) posted Thu, 28 September 2023 at 11:56 AM
Ken's suit and your Lemura play nicely together!  :-)
My Store is HERE
Thalek ( ) posted Thu, 28 September 2023 at 4:12 PM
My memory isn't what it should be, so I don't remember if I actually read this, or I'm huffing paint fumes again.
Didn't they say a free version of La Femme 2 LE would be available?  Or having I been sucking on my car's exhaust pipe too long?
Rhia474 ( ) posted Thu, 28 September 2023 at 4:24 PM
No, you are right. It is in the Included content section of posersoftware dot com and you can download it from there (at least that's where I got it).
Boni ( ) posted Thu, 28 September 2023 at 4:29 PM
LF2
Texture: Dark setting, custom brows
eyes: honey
FXface- dialed
FXbody- dialed
Prae's Briar hair with Ghostship's hair shader
LF2- basic wear
Lights: Included>Profile
Render setting: CPU High
Pose: in LF2's set, with adjustmentsTFUciM8clKreX9MJwiih3aeY5M9nVJ8gU9DdQsxT.jpg
Boni
RedPhantom ( ) posted Thu, 28 September 2023 at 4:32 PM
Site Admin
It's available at posersoftware or if you prefer, it's in the included section of your purchases tab of your library. I know not everyone likes to use that. Just pointing out where it's available.
hborre ( ) posted Thu, 28 September 2023 at 4:51 PM
LF2
Texture: Dark Setting
FXface - Dialed
Fxbody - Dialed
Ali's HR-40 with Ghostship's Shaders
Ghostship's LF-BodySuit, converted and conformed
Ghostship's lights, Construct Big with Blackbody node, 5500 Degree Kelvin
Render Settings: OptiX Ultra Caustics
Rhia474 ( ) posted Thu, 28 September 2023 at 6:24 PM
LF2
FXfaceMorphs - Dialed
FxbodyMorphs- Dialed
Afrodite-Ohki's Kalla Hair with included textures
Frequency's V4 Elixir dress, dynamic, scaled to fit, with included textures
Afrodite-Ohki's EnviroSphere with included material; LIghts are from same set (LevelUp Superfly)
Render Settings: OptiX Ultra Caustics with DoF enabled
No postwork
Afrodite-Ohki ( ) posted Thu, 28 September 2023 at 8:38 PM
I'm loving those renders so much!!!
Feel free to call me Ohki!
Thalek ( ) posted Thu, 28 September 2023 at 9:50 PM
Rhia474 posted at 4:24 PM Thu, 28 September 2023 - #4475480
Thanks!  She arrived stealthily: when I opened the page, she wasn't visible until I refreshed the page.  Naturally, I didn't think to refresh the page the first few times I looked . . .
shvrdavid ( ) posted Fri, 29 September 2023 at 1:13 AM · edited Fri, 29 September 2023 at 1:14 AM
WIP for LaFemme2
lsauvage ( ) posted Sat, 30 September 2023 at 6:12 AM
Hello
New image: Relaxing
Very nice render, but she can not walk, the dress needs an adjustment :)
Bastep ( ) posted Sat, 30 September 2023 at 4:58 PM
lsauvage posted at 6:12 AM Sat, 30 September 2023 - #4475574
Hello
New image: Relaxing
Hello and thank you! The dress is constructed with intention. I wanted to test how body hugging you can make a dynamic dress before it wrinkles very ugly.
Conclusion: very body hugging.
Good night
Bastep ( ) posted Sun, 01 October 2023 at 3:27 PM · edited Sun, 01 October 2023 at 3:28 PM
Hello and good evening
An experiment with Cycles emissions light.
RedPhantom ( ) posted Mon, 02 October 2023 at 8:00 AM
Site Admin
More playing with Lafemme 2. The texture is Maya from Lafemme. The tutu is one of V4. I converted the shoes and arm bands but I just posed the dress because this is one that doesn't drape well so I need the body handles to pose it. I'm not good with rigging yet and don't have anything to use as a doner.
Rhia474 ( ) posted Mon, 02 October 2023 at 3:05 PM
I am continuing to be happy about how older figures and textures render in P13; the ones that were made with attention to detail.
This is MortemVetus' Danne for M4. I actually did not change anything on the texture, except the eye shaders to ghostship's. LevelUpSuperfly lights, background and sphere, an old Neftis hair (that still needs some adjustment at the sides):
Y-Phil ( ) posted Tue, 03 October 2023 at 1:53 AM
Rhia474 posted at 3:05 PM Mon, 2 October 2023 - #4475680
Awesome...
And it's true that MortemVetus has quite a few impressive males.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Rhia474 ( ) posted Tue, 03 October 2023 at 9:30 AM
Y-Phil posted at 1:53 AM Tue, 3 October 2023 - #4475717
Awesome...
Thank you! And yes, their rugged characters have a very 'real' feel for them. Also Tempesta3D's gorgeous ones for males ( Phoenix1966 sadly stopped creating for Poser) are amazing. They work well in P13 with very small modifications if at all.
jroulin ( ) posted Wed, 04 October 2023 at 7:19 AM · edited Wed, 04 October 2023 at 7:19 AM
Playing with Dynamic clothing imported to Poser 13 from MD2. Figure is LaFemme2  with the SSLorraine character. Just needed a litthe tweeking for the texture on the clothing and seting up a simulation.
GiveitUp ( ) posted Fri, 06 October 2023 at 5:34 AM · edited Fri, 06 October 2023 at 5:34 AM
I believe in myself....
So, I'm finished with my "high end" skin shader. Thanks to Cycles and Superfly, nuances are only necessary in the Pantone gradations of the skin maps and in the three color scatter settings. I placed particular emphasis on the slight translucency in order to achieve the most natural look possible. In the picture you can see this on the ear and chin. For this reason, I stopped using SSS Maps altogether. SSS maps interfere too much with the most important instance - the skinmap; They almost completely prevent it from showing through and cause more “damage” than good. LaFemme2 comes with one of the strangest SSS maps I've ever seen and in my opinion it's completely unusable. The settings of the bump and normal maps are a matter of taste. Many rendered faces I saw here remind me more of the surface of the moon. If the bump mapping is too strong, the colors of the skinmaps are severely distorted by microshadows, making it appear darker and dull. Too much shine (also a matter of taste) can then look more like a plastic surface. In the lip area the skin is a little smoother and therefore reflects a little more strongly. In order not to distort the result, I didn't use PostFX. My goal was to achieve a rendering result that no longer required any post-processing. With LaFemme2 I was able to achieve a similar result with just a few settings, even though their skin shader is very minimalistic.
Now it's time to get to the teeth... So far I haven't seen a shader (regardless of which figure) that looked really good. I tried the first approaches with Anna, the red-haired girl. But they are too gray and still lack the surface structure.
shvrdavid ( ) posted Fri, 06 October 2023 at 11:39 AM
Smile :)
GiveitUp ( ) posted Fri, 06 October 2023 at 6:42 PM · edited Fri, 06 October 2023 at 6:44 PM
to shvrdavid...
GiveitUp ( ) posted Fri, 06 October 2023 at 6:48 PM
Pic is 2312 x 1755  Pixels (4.06 MPixels) (1.31) download to see details.
GiveitUp ( ) posted Fri, 06 October 2023 at 7:58 PM
Translucency of the thinner parts of the body, velvet-like refraction of light at the body boundaries. I didn't manage to do that with Poser 12. The figure has its own atmosphere with a delicate elegance.
Don't ask me what those bright spots are on her lower lip... LaFemme2 and I haven't been together that long.
Uhhmm...by the way, has anyone noticed LaFemme's severe conjunctivitis?
GiveitUp ( ) posted Sat, 07 October 2023 at 1:06 PM · edited Sat, 07 October 2023 at 1:06 PM
Shadow existence...
Rhia474 ( ) posted Sat, 07 October 2023 at 6:39 PM · edited Sat, 07 October 2023 at 6:39 PM
Incidentally I was also working on still life stuff today:
Y-Phil ( ) posted Sun, 08 October 2023 at 12:19 PM · edited Sun, 08 October 2023 at 12:19 PM
Both still-life pictures have wonderful textures
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
jroulin ( ) posted Sun, 08 October 2023 at 2:53 PM · edited Sun, 08 October 2023 at 2:53 PM
Old clothing transferred to LaFemme2.
GiveitUp ( ) posted Tue, 10 October 2023 at 5:13 PM · edited Tue, 10 October 2023 at 5:13 PM
amu7X1gBflFZwrfdKFtfjf5QRnvBEfkYSH6PDFkH.jpg.
GiveitUp ( ) posted Tue, 10 October 2023 at 6:56 PM · edited Tue, 10 October 2023 at 6:56 PM
Old but beautyfull...    like me :)
GiveitUp ( ) posted Tue, 10 October 2023 at 7:08 PM · edited Tue, 10 October 2023 at 7:08 PM
Thalek ( ) posted Tue, 10 October 2023 at 11:54 PM
That's . . . just . . . incredible, Charly_99!
GiveitUp ( ) posted Wed, 11 October 2023 at 12:39 AM
Thanks Thalek
But that honor belongs to those who made these pieces. I just set them up in Superfly and put them in the light.
GiveitUp ( ) posted Wed, 11 October 2023 at 12:44 AM
Objects converted to OBJ with Blender. Then imported into Poser. From here: polyhaven.com
Y-Phil ( ) posted Wed, 11 October 2023 at 6:12 AM
Charly_99
Fabulous!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
