Sat, Jan 18, 1:25 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Jan 18 1:14 pm)
Subject: add jpg pic to prop
drawn ( ) posted Mon, 27 May 2024 at 4:59 PM · edited Sat, 18 January 2025 at 7:21 AM
I have this basic scene, not rendered, of stairs, wall, 2 girls...I need to add a jpg or a pretend sign to the school wall. cut n paste didn't for me. any way?
drawn
drawn
RedPhantom ( ) posted Mon, 27 May 2024 at 6:23 PM · edited Mon, 27 May 2024 at 6:23 PM
Site Admin Online Now!
Go into the material room. Hit the edit tab. Right click on the Materials pallet. Go to new node>2d textures>image map
Now click on where the new node says none and hit browse on the new popup. Navigate to where you have your sign saved. Select it and hit open.
Now drag from that dot next to the word color to the dot next to the diffuse color on the poser surface to "plug" the node into that slot. It's also recommended to change the diffuse value to about .85.
hborre ( ) posted Mon, 27 May 2024 at 7:03 PM
The width x height of the JPG image might cause some issues when it is previewed in the scene.  You will need to match the X- and Y- scale of the square to the image and then scale the square to the right size of the figures.
nerd ( ) posted Mon, 27 May 2024 at 7:09 PM
Forum Moderator
Even easier Drag n' drop the JPG (PNG, TIF, whatever) onto the material edit window. Poser will auto-create the node. All you need to do is plug it in. Done.
nerd ( ) posted Mon, 27 May 2024 at 7:12 PM · edited Mon, 27 May 2024 at 7:12 PM
Forum Moderator
P.S. Use the "One Sided Square" prop for making billboards.
hborre ( ) posted Mon, 27 May 2024 at 7:22 PM
For some reason, P13 and Win 11 do not allow drag & drop anymore.
hborre ( ) posted Mon, 27 May 2024 at 7:40 PM
Never mind, I figured out the problem.
