Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Attached Link: http://www.uvmapper.com
I'm not sure I understand whether you want sharp edges or not. But the best thing you can do to improve any obj file, is run it through uv mapper. Did you import to Poser in obj format? I use max and this is what I do. Export from max as a 3ds file, import to poser and get the size right, export as an obj, then open the obj in uv mapper and use 'split vertices' to give me sharp sides. Then I re-export the obj WITHOUT normals (Poser ignores normals) to cut down the file size and open it in poser with all options off. This may seem a long way to do it, but it works for me, I've had nothing but trouble exporting obj from max. mac PS uv mapper is free. See link.Sorry for my bad English and the confusing question. I used max to make some models and export as obj by the max to obj plugin, then import into poser. I dont care the edges sharp or not, I just dont want to have the black color as shown in no.1. The no.1 cylinder is a primitive cylinder I made from max, and I got the black color. So if poser cant smooth a 90degree edge, I need to use uvmapper to 'split vertices' to every model that I want to use in poser?
Instead of extruding the ends, have you tried just splitting the model into tube + end caps? in other words, separate the end caps so that they are disc-shaped groups disconnected from the body of the cylinder. The vertices on around the edge of each disc will just overlap those around the rim of the "tube", but they will be separate. I'm curious how that would look. -Adam
Attached Link: http://http://www.renderosity.com/~syyd/tuts/impexmax/impexmax.htm
OK. The image shows you what you need to do. The top left cylinder was made in max (8 sides) using the cylinder primitive. The top right is an extruded spline. Both were exported as obj files using the Habware plug-in, opened in Poser and rendered as they were. Below you can see the same 2 cylinders after uv mapping. I opened them in uv mapper, used 'split vertices', made a basic map, then imported them into poser and rendered. You can see the difference. I also did the same thing exporting from max as 3ds instead of obj and the results were identical. I just prefer to use 3ds, because I can control the size, but it makes no difference. Below is a link that shows you the exact settings to use when exporting an obj from max. Also, if you export an obj from poser you must uncheck all options on the export dialog box, (unless you're making a figure or morph), and if you re-import that obj, uncheck all options again. Hope this all helps. Any problems, let me know.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
