79 threads found!
JAFO | 3 | 135 | ||
JAFO | 3 | 354 | ||
JAFO | 4 | 469 | ||
JAFO | 1 | 200 | ||
JAFO | 10 | 742 | ||
JAFO | 4 | 640 | ||
JAFO | 3 | 428 | ||
JAFO | 0 | 357 |
(none)
JAFO | 5 | 492 | ||
JAFO | 1 | 496 | ||
JAFO | 4 | 619 | ||
JAFO | 22 | 1574 | ||
JAFO | 24 | 1864 | ||
JAFO | 3 | 592 | ||
JAFO | 3 | 369 |
717 comments found!
Now that you've set up your preferred scene, click save-as and save that preferred scene somewhere convenient that you'll remember on your drive. Next time you start from scratch or upgrade, you can open that saved scene and under preferences-you can save your preferred scene without having to fuss with all the details of getting it the way you like.
As mentioned:
You'll want to set preferred scene in two places. Both edit/preferences/document and edit/preference/interface.
Y'all have a great day.
Thread: Show your Poser 13 renders! | Forum: Poser 13
Just posting to keep this thread near the top. Just happen to be working on a hair prop, materials for strand hair drive me up the wall...
Thread: Why is Poser rendering a blank screen | Forum: Poser 13
Here's how I keep track of my camera, its parented to the head of the tripod and locked. If I need to make adjustments I move tilt or rotate with the tripod, keeps things more 'real world'.... LOL
Your screenshot above showing your render in preview mode, still you shouldn't be seeing a blank screen.
Could you show a screenshot showing the preview screen and the properties tab with the camera selected?
Have you tried rendering from a different camera?
Thread: Dial triggers | Forum: Poser - OFFICIAL
Here are a couple of video's from nerd you may find helpful:
https://www.youtube.com/watch?v=7Vv9jN2445c
https://www.youtube.com/watch?v=5NtjvlVRTSw
They're dated but still relevant
Thread: Shortcuts? | Forum: Poser 13
Thanks Nerd, most helpful as usual.
Found and backed up to an archive drive...
Oops I mean Poser 13...LOL. Short spin-cycle on the edit button...
Thread: Can I Decimate/Simplify the Geometry file in Poser? | Forum: Poser 13
Thread: Poser 14 | Forum: Poser 13
Thread: No GoZ in Poser13? | Forum: Poser 13
Update::
I tried installing an earlier version of ZBrush, still no GoZ in poser.... Reinstalled Poser13 and now GoZ works fine....
"It shows the render as it works but when finished it is blank."
This rings a bell for me... In a previous version I had a similar problem with SuperFly, turned out the contrast in PostFX was set to -1 somehow(I didnt do it). Try unchecking 'apply post effects to render' and see if it makes a difference...
I have no idea why Firefly isn't working, but I suspect there may be a cross-bleed of settings that shouldn't happen... I've had renders in SuperFly that showed red splotches(like those that appear when calculating indirect light in Firefly) or incorrect Gama that seem to have been alleviated by turning off or adjusting settings in Firefly. Strange things sometimes surface in the unlikeliest circumstances, I think those are commonly referred to as 'bugs'.
Hope you find a solution...
Thanks @hborre...Seems the problem is with ZBrush 2024, theres no Poser folder in C:\Users\Public\Pixologic\GoZApps. Anyone know how to remedy this? Maybe revert back to a previous version???
Thread: Problems with scenes created in previous versions of Poser. | Forum: Poser 13
@nerd: The problem is not the lights, its attempting to set render options that causes the crash on every scene created in previous versions. The older scenes load and render fine(but very slow compared to P13). My suspicion is that it has something to do with differences in the way adaptive sampling is implemented that resulted in faster renders, just a hunch...
Loading the old scene into a new scene cures the issue, the only reason I delete the lights from the new scene is to prevent duplicates.
Try creating a scene in P12 set render options and save to disc(or use an existing P12 scene), then open that scene in P13 and attempt to change render settings see if it works for you. If you don't have an issue I'll know its on my end, though i cant imagine how that's the case.
I've wrestled with this issue for months...Reinstalled P13 several times including uninstalling and fresh installs... after several attempts I (formatted drive)upgraded the OS from Win10 to Win11 same problem persists...
Thanks for your reply...
PS: I loaded an older scene and deleted all the lights and got the same result.
Thread: Cloth room tutorial for moving figure | Forum: Poser - OFFICIAL
If you want your characters hands to interact with a cloth item, I recommend you create and use gloves as collision objects. The characters fingers snag on cloth items, creating undesirable results.
Here's a quick video showing the results...
https://www.youtube.com/watch?v=qawKvP515RQ
Of course you would hide the gloves during render...
Thread: I Just Bought Poser 13 and... | Forum: Poser 13
