15 threads found!
Lord_Lucan | 4 | 156 | ||
Lord_Lucan | 10 | 45 | ||
Lord_Lucan | 3 | 16 | ||
Lord_Lucan | 6 | 529 | ||
Lord_Lucan | 2 | 229 | ||
Lord_Lucan | 8 | 153 | ||
Lord_Lucan | 5 | 107 | ||
Lord_Lucan | 23 | 669 | ||
Lord_Lucan | 10 | 284 | ||
Lord_Lucan | 4 | 232 | ||
Lord_Lucan | 3 | 448 | ||
Lord_Lucan | 12 | 551 | ||
Lord_Lucan | 15 | 325 | ||
Lord_Lucan | 4 | 88 | ||
Lord_Lucan | 5 | 119 |
109 comments found!
Attached Link: PDFcreator
Personally, I make the layout in Indesign and save as a PDF, but on my laptop (or for non indesin docs) I use pdfcreator from sourceforgeThread: Poser 6 won't display PNGs in external runtime. | Forum: Poser - OFFICIAL
I actually just created a folder called 'runtime' on a usb HDD (installed the files there), and in Poser added a runtime and navigated to the new runtime. I can use the files and view the thumbnails, but only if they are in RSR format, not in PNG.
Thread: Poser 6 (poser4) render aginst black - incomplete | Forum: Poser - OFFICIAL
Thread: Help on Bitmap Cleaning | Forum: Photoshop
Sounds like you need a data recovery prog. You can get a prog, but there are some professional data recovery sites that reqire you to send them the media (and i'm guessing a suitably hefty fee) - only if your data is very important.
Thread: Java : where do i get it? Partly off topic. | Forum: Poser - OFFICIAL
Attached Link: http://www.autopatcher.com/
This is an installer for all the Microsoft updates.Thread: moneystile filter? | Forum: Photoshop
Attached Link: http://www.andromeda.com/info/cutline.html
or Cutline from Andromeda. As for India Ink, read the blurb or download the demo(325k).Thread: Angelic sound effect | Forum: Poser - OFFICIAL
What's that 'Sisters of Mercy' song with the "ahhhhhhhh" bit at the beginning? This Corrosion? You could try sampling that or s'thing like it.
Thread: i need a good text editor | Forum: Poser - OFFICIAL
Attached Link: http://www.liquidninja.com/metapad/
I use Metapad - haven't really used a lot of them, but I prefer it over Notepad.Thread: OT - ASCII image makers | Forum: Poser - OFFICIAL
Thread: Poser 5 Animation to 3DS Max 6... | Forum: Poser - OFFICIAL
Thread: opacity fade.gif? | Forum: Photoshop
Correction lundqvist; IE Browser support is lousy!lol! You can add some code to the html with the PNG to enable IE to support the aplha transparency (though it uses activeX, so if the surfer has it turned off in IE, they won't see it.)
Thread: How to delete a frame in the middle of an animation? | Forum: Poser - OFFICIAL
can't you just select all the frames after and then move them back a frame? Would that not write over the frame?
Thread: Postwork effects. | Forum: Poser - OFFICIAL
Thread: Making Morphs | Forum: Poser - OFFICIAL
Personally I prefer ZBrush. Though if you are using v1.5(versions before & after sre ok) you will need to download the X-flip zscript from ZBrushCentral if you are making morphs for poser. Plenty of advice on Poser morphing(full body even) in the ZBrushCentral forum. I have no experience of the other 2 apps, but there are plenty of members who do.
Thread: OT - how to create a .pdf readme | Forum: Poser - OFFICIAL
