16 threads found!
Tuck3D | 6 | 45 | ||
Tuck3D | 6 | 49 | ||
Tuck3D | 12 | 448 | ||
Tuck3D | 7 | 74 | ||
Tuck3D | 16 | 95 |
2001 Apr 07 6:45 PM
Tuck3D | 3 | 17 | ||
Tuck3D | 2 | 14 | ||
Tuck3D | 1 | 8 | ||
Tuck3D | 1 | 9 | ||
Tuck3D | 2 | 20 | ||
Tuck3D | 2 | 18 | ||
Tuck3D | 2 | 15 | ||
Tuck3D | 5 | 43 | ||
Tuck3D | 10 | 169 | ||
Tuck3D | 0 | 8 |
(none)
54 comments found!
OK now this might a bit off track but I believe hearing something about this somewhere, dont hold me too this but I believe this rememdy was (And I could be wrong) was to delete the carrara ini file. Thus causing Carrara to reload the settings file. Someone comment on this if I'm wrong.
Thread: A bit OT : free textures | Forum: Carrara
Thread: What screen resolution do you work with ? | Forum: Carrara
Thread: News from Eovia | Forum: Carrara
Sounds like Max hit it right on the head. Fix Carrara before adding more pots to the stove. Perfect one and then move on. (In that order)
Thread: A image you might like | Forum: Photography
No negatives, Im assuming my father did a little film processing at the expense of the Army. Just tons of pictures. I have found pictures of Churchill and Eisenhower since I've started going through them, more thaan I could mention. Just dont know what to do with them
Thread: Windows XP with Carrara Studio 1.1??? | Forum: Carrara
As for Carrara running under XP I have no idea. As for the internet connection you did not need an internet connection to install XP. However it will need to be activated, thus nmeaning if no internet coonection is availble you will be givin a Phone # and a 10 - 50 digit code that will be generated after XP isw installed on your system and that code is sent to MS and then another code is sent tyou which will unlock XP is not registered XP will stop running after 30 days. That is the way BILL G himself explained last night on a PBS program.
Thread: still testing out carrara | Forum: Carrara
Eric or Any Carrara genius, Could you please take a second to explain what some of the stuff in the prefrences to the Interactive Renderer Prefrences do. I've never really unmderstood what all the options do. I would be very thankful, as would the other people like me. Thanks
Thread: Break it Down for me. | Forum: Carrara
Neko.....Just my two cents from another newbie to 3D. Try finding a copy of 3D Artist at your local Bookstore (It does have tutorials for Carrara often and you can get useful information about 3D in general.) Also as mentioned above the "Carrara Bible" is a great reference point to begin with. Also the www.tutorialfind.com has alot of 3D Information. And really cool Tutorials for a variety of Software.
Thread: Carrera used in amazing CG animation-you must see this! | Forum: Carrara
Thread: Please Help a Newbie | Forum: Carrara
Thread: How did you come to 3D ? | Forum: Carrara
I was walking through CompUSA looking for a new video game and seen a copy of Bryce4. That was all it took.
Thread: Shades of Reality? Are they any good? | Forum: Carrara
Teh only thing to consider is if one person made a shader. You can too!! That's going to be the issue around here. Shader recipes should be freely exchanged. LIke i said if one person made a shader what's keeping you from creating the same one. After all there is no secret code or hidden thing you need to know. Just play around with the shader tree. Why pay someone for it.
Thread: Go get your 1.1 Studio patch people! | Forum: Carrara
Thread: Multiple shaders not displaying in texture room under NT | Forum: Carrara
You will beaten and horse whipped.Assume the position!! Dont you just hate it when it's just so simple.
Thread: Carrara release date . | Forum: Carrara
Here's the Amapi question? No integration or plugin connection to Carrara, just a standalone version, similar to what was on the Amapi 5.1 CD plus 5.15 applied to it, essentially. Mac and PC. The Carrara CD is a hybrid too. Amapi 5 exports to RDS 5, so that imports into Carrara's vertex modeler. Of course, if you use Nurbs in Amapi and want to pass it to Carrara, you should convert the Nurbs to polyhedral (double-click the part(s) ) prior to export to predict what polygons you end up getting. -Philip
Thread: Cant load in Shaders...WTF... | Forum: Carrara
