51 threads found!
dante | 13 | 1183 | ||
dante | 10 | 4490 | ||
dante | 2 | 357 | ||
dante | 5 | 944 | ||
dante | 4 | 139 | ||
dante | 6 | 240 | ||
dante | 12 | 454 | ||
dante | 5 | 114 | ||
dante | 16 | 332 | ||
dante | 2 | 109 | ||
dante | 6 | 134 | ||
dante | 6 | 167 | ||
dante | 1 | 27 | ||
dante | 1 | 122 | ||
dante | 1 | 30 |
189 comments found!
Thread: Poser 11 DSON importer "pose" problem | Forum: Poser - OFFICIAL
I actually have two folders...one for Daz with it's content, and another separate runtime only for the companion files...could this be the problem?
Well I can't make it work in poser 11 anyhow...unless I add the clothes on a pose by pose basis...that is not exactly much practical is it?
Thread: Poser 11 pro and DSON importer problem | Forum: Poser - OFFICIAL
The trick with unticking "show progress on load" think resolved the problem...thanks so much adzan
Thanks hborre...but if i remember correctly this didn't happen in poser 2014 pro...i may reinstall it...
It is allready undocked, I wonder if reinstalling DSON will resolve the problem...thanks folks
Thread: Cannot find out this outfit | Forum: Poser - OFFICIAL
Thanks Jura...that's it, man I have searched high nand low for this stuff...all the best brother
Thread: Poser do zbrush and back tut? | Forum: Poser - OFFICIAL
The rigging won't change at all. You cant embedd into geometry without breaking the polycount, that's why you have to extract the normals and displacement maps to, fake the higher cage on a lower polygon model. There are plenty tutorials on the internet for that.
Thanks a lot brother...I'll hunt around All the best
Hey!
What do you want to know exactly? if you want to build hair that is possible but you have to select the subtool( in this case hair) and than use goz to poser to get the hair mesh aligned on the model. With adding detail you can substract displacement maps and also normal maps from the high subdivided mesh and use those maps on your lower polygon mesh.
Yeah, but a tutorial on how to do all that without loosig the original rigging or the original UVs (if possible) would help me a lot...for instance I would like to have vascularity and scars embeded into the geometry... Thanks for answering
Cheers
Thread: Poser libraries don't work anymore | Forum: Poser - OFFICIAL
Hello all...had this problem with poser pro 2014 sr 1...did the E11 elimination and it worked just fine...installed sr 3...no problems there, but today, bam...libraries window blank...any help someone?
Thanks
Thread: Poser and Reality | Forum: Poser - OFFICIAL
