15 threads found!
isomaster | 9 | 317 | ||
isomaster | 7 | 163 | ||
isomaster | 5 | 123 | ||
isomaster | 3 | 90 | ||
isomaster | 11 | 304 | ||
isomaster | 21 | 245 | ||
isomaster | 2 | 139 | ||
isomaster | 3 | 158 | ||
isomaster | 3 | 192 | ||
isomaster | 3 | 97 | ||
isomaster | 1 | 101 | ||
isomaster | 6 | 232 | ||
isomaster | 4 | 111 | ||
isomaster | 1 | 51 | ||
isomaster | 9 | 628 |
32 comments found!
gotcha, Perfect, worked like a charm. my next question: (Im just getting poser 6 and all and useing something other than the stock judy :) ) how do i use the facal dials to modify mike 3. If i try it now, mikes color is off and it just don't look right? How do I modify him? Thanks, Cedric
Thread: why is mike doing this? | Forum: Poser - OFFICIAL
Thread: Please, How do you animate in Poser 5 | Forum: Poser - OFFICIAL
Thanks for your reponse, Im must getting into the "Poser" animation, so how or where do I turn off spline interpolation and turn on linear section for frames? Thanks, Cedric
Thread: How can I render a short animation with a "Pure" white backgroud | Forum: Poser - OFFICIAL
Great advice, Im going to try the codec first to see if it works, if it don't Im gonna do the image recompile and sync it in flash. Thanks a million, Cedric
Very True, The only problem with that is that it has sound with the animation (poser/mimic). so thats why I need it in a movie format. Cedric
Thread: bringing in 3D in to poser | Forum: Poser - OFFICIAL
I would be VERY intrested in those tutorials also, since Im dealing with this problem now. Cedric
Thread: how to texture map her... | Forum: Poser - OFFICIAL
Thread: how do you animate indepentently in bryce | Forum: Bryce
That helped greatly, You guys are great. Finally a community that answers questions instead of punish newbies Thanks, Cedric
Thanks, With some of your ideas, Im almost have a nice seamless loop going. Once I get it going, Ill show you what I was able to come up with. also, can Bryce make those Fluffy clouds instead of cirrus type clouds. Cedric
Thanks for the info Dave, Well Question, Since you've done some animation in bryce, what would be your best approch to creating a seamless cloud animation. Something simliar to this one... http://www.skyworksinc.com/ (Maybe not as good as that one, but something similar with bryce) Cedric
Thanks, I've actually went through those tutorials and all. The problem here isn't so much "How" to animate in bryce, but how to do simple things that most basic animation tools can do. Like here what I can't figure out. I have a scene with a rock... on frame one the rock is visible.... on frame 10 I want to make the rock invisible... In bryce I can't see how to do this. Ususally you would turn off visiblity on the rock at frame 10 or something to that effect. But If I turn on the hidden feature on the rock on frame 10, then now the rock has disappered through frames 1-9 also? Simple things like how to simply turn on and off objects on the timeline is not working??? Am I overlooking something. Cedric
ok, Thanks for the help, I was copying. So i can get it to animate seperatly now. The only problem is still even though I imported the item at frame 10, it still shows up from 1 - 9? I tried using the hidden option, but it will either not show or show through the whole animation. What would cause that. Cedric
Thread: poserfx.com... anyone intrested? | Forum: Poser - OFFICIAL
No, Im just selling the domains, you get just the domains. No hosting. You will have to find your own host. The domains package is just the 2 domains... poserfx.com & poserfx.net Sorry about the mix up, Cedric
