98 threads found!
megaionstorm | 13 | 350 | ||
megaionstorm | 0 | 59 |
(none)
megaionstorm | 0 | 63 |
(none)
megaionstorm | 5 | 77 | ||
megaionstorm | 21 | 374 | ||
megaionstorm | 32 | 718 | ||
megaionstorm | 5 | 120 | ||
megaionstorm | 5 | 82 | ||
megaionstorm | 21 | 273 | ||
megaionstorm | 13 | 185 | ||
megaionstorm | 1 | 61 | ||
megaionstorm | 0 | 20 |
(none)
megaionstorm | 5 | 136 | ||
megaionstorm | 0 | 34 |
(none)
megaionstorm | 1 | 84 |
78 comments found!
"Beside the fact that you are completely incorrect, you'll need to find the spot in the Game Dev license agreement, with each piece licensed as Game Dev, saying freeware is covered as well."
Extended License Quote:
"3d) The Buyer may use the Product to incorporate and embed into an electronic game or interactive media and distribute that new work provided there is encryption protection ...ย "
If i'am not wrong then i can use it in freeware, shareware software and equal business models without asking back !
Thread: Standart and Extended License | Forum: Poser - OFFICIAL
"If think the vendor has given his agreement at the moment he had decide to sell his product with the extended license !" - Who is there a complaining in this sentence ???
I don't complaining, i try only to give a suggestion.
A suggestion for a third license type, like in other online stores.
A third license type like an 'Indie Game Developer License'.
"Just because YOU choose freeware doesn't mean a vendor wants to participate in that business model."
There are a lot online stores who have different licenses for freeware (non commercial use) and commercial programmers.
I think there is a need for a third type of license, then the extended license makes no difference between freeware games and commercial games.
The actual extended license could be a good solution if the game is a commkercial game and should be sold for $100.- each item.
But ... but there are freeware game programmers.
If think they must have there own license type, with a price not higher as the doubble from the standart license price !!!
Quote - You need an extended license if you are using the models in a game where you need to redistribute the models.
Is unity3d from this included or excluded ?
Thread: Dia | Forum: Carrara
The default and turbulence cones goes through the wall !
The gel idea is good, but not very usefull for my plans.
I want constructe a building. This building should have colored glass.
If the sun is moving the colored light should follow the movement.
Then i want port it to poser 7, carrara 7 expressย and shade 7 !
It's more a slice projection effect !
Thread: Real Dia Effect in Poser 7 ? | Forum: Poser - OFFICIAL
Quote - First attempt using a gel.
I would have increased Angle Start and Angle End to reduce the fall-off (vignette, I think it's called), but Poser crashed on me and I lost the scene.
ย
What poser version do you use ? Version Nr. ? Standart or pro ?
Yes, sounds simple with this projection.
Here the complete idea:
The only houses i know with colored glass are church and similar.
You stand in the building, through the windows can you see the colored lightrays and the projection on the ground. Outside the sun is moving, the lightrays and the projection moves with the sun. That's it.
I use carrara 7 express. Who can i find this caustic parameter ?
I mean like a slide projector works. A little frame with a transparent photo. I can project the picture with a slice projector on a wall !
