2 threads found!
miken999 | 4 | 62 | ||
miken999 | 3 | 93 |
19 comments found!
I registered successfully. Answer to question 3 is Tokyo Metropolitan Area, which is translated like this in japanese : ๆฑไบฌ้ฝ (tรดkyรด to)
Thread: Free 3D Painting application supports Poser CR2 files | Forum: Poser - OFFICIAL
Same problem here, program asks for IL.dllย
Message :
Error...
Could not load the library DataIL.dll
Thread: Poser4 ProPack and V4 V4.1 V4.2 | Forum: Poser - OFFICIAL
Thread: Poser 5.0 & Quicktime 7 Problem ... | Forum: Poser - OFFICIAL
Quote - Hi Miken999!
I always saveย useful ideasย when I browse forums, i searched my computer and found this:
quote:
If you really must have QT installed on you "puter" (as a friend of mine needed it for Illustrator),there is another workaround....
Delete the "Mac" plugin found in your Runtime>ImageIOPlugins folder.
This goes back to the legacy coding as the original Poser was ported to Mac's and used QT for display.
You don't need it...but you will see a big different in your library display.
End quoteI dont have Poser 5 installed myself so I cant tell if it works or if its safe to do this, maybe someone else remembers this trick?
Regards / Jonny
Hi jonnybode, Thanks for your help !!!!
I can now use poser 5 & Quicktime 7.4 !!
I deleted the MAC plugin as suggested, and Poser 5 works as before :)
Thank you again ! :)
Thread: anyone know????????????? | Forum: Poser - OFFICIAL
Quote - > Quote - I Contacted my ISP about DAZ3D access problem ...
They told me to use proxy. So,ย I set my explorer with proxy adressย of my ISP on port 8080
and now I can access DAZ3D without problemย ... 8)Yes, but it works now and have been workingย for a couple of days.
DAZ3D doesn't work for me without the proxy settings ...
If I don't use that proxy, DAZ3D is almost unreachable & no pictures appear.
Same problem here ... I'm able to connect on ArtZone, but when I want to go to DAZ3D I have partial access to website (red cross on all pictures)ย and sometimes it doesn't load at all ...
Last time I was able to access DAZ3D was to download Victoria4.2 from my account,
since no luck :(
I'm on Daz3d since 2000, and it's first time I have that kind of problem :(
I'm in Belgium.
Thread: Poser and ATI 7.12 Drivers | Forum: Poser - OFFICIAL
I'm back as well on 7.10, unable to use Poser 7 in OpenGL Modeย with Catalyst 7.12.
With 7.12 Poser 7ย is unusable in OpenGL :ย Slow down, freezes or crash.
Thread: P6 suddenly locking up | Forum: Poser - OFFICIAL
I had a similar problem with Poser 5 & Poser 6 ...
Uninstalling Quicktime solved the problem.
Thread: Burning Poser 7 ? | Forum: Poser - OFFICIAL
Try to burn your DVD in UDF Format, not ISO format ... :)
UDF Format allows you to burn large files (> 1GB)ย on a DVD.
Mike.
Thread: Francaise de Poser 6. (Poser6 French edition) | Forum: Poser - OFFICIAL
If the French version of the program is similar to the translation on the website, then it's lousy... 8P I'll stay with English version ;p
Thread: looking for a translator! | Forum: Poser - OFFICIAL
If you need to translate French technical terms, that's not a problem for me ... I'm Belgian and speaking French ;)
Thread: HELP! | Forum: Poser - OFFICIAL
Hi,
you should check marketplace,
your picture seems to be a beretta Model 92 or 89...
That gun is in the market place at $5, made by DokieMaster.
http://market.renderosity.com/mp/SoftgoodImage4741a.jpg
Check link :
http://market.renderosity.com/softgood.ez?ViewSoftgood=4741
Message edited on: 12/10/2004 05:35
Message edited on: 12/10/2004 05:36
Thread: New Daz Freebie | Forum: Poser - OFFICIAL
Thread: Japanese forum moving server | Forum: Poser - OFFICIAL
