18 threads found!
stelhar_1999 | 14 | 238 | ||
stelhar_1999 | 2 | 79 | ||
stelhar_1999 | 2 | 82 | ||
stelhar_1999 | 4 | 137 | ||
stelhar_1999 | 1 | 90 | ||
stelhar_1999 | 2 | 61 | ||
stelhar_1999 | 2 | 109 | ||
stelhar_1999 | 9 | 287 | ||
stelhar_1999 | 6 | 146 | ||
stelhar_1999 | 1 | 7 | ||
stelhar_1999 | 4 | 22 | ||
stelhar_1999 | 2 | 19 | ||
stelhar_1999 | 8 | 33 |
16 comments found!
Thread: thigh boots question!!!! | Forum: Poser - OFFICIAL
I also tried a transparency map but the part that i wanted to be transparent was visible (white colour or black!) i think I messed up a little with the dials for the transparency! . I tried the same method which I use for the V2 eyebrows . I Think!!
Thread: Request for an Animation Gallery. | Forum: Community Center
Thread: Joint Editor problem in Poser 4!!!! Can anybody help????? | Forum: Poser - OFFICIAL
Thread: Has anyone tried to make conforming clothes for Poser using Maya? | Forum: Poser - OFFICIAL
Find out what the reason was or having such a problem, when I started to make the armor I checked the "keep faces together" parameter and went a little on modeling then I closed MAYA to get some sleep (sometimes s*** happens!!!) and whe I opened the file again I din't checkthis parameter again!!!! now works just fine (a little to fine I might add!!!! so how can I keep Poser from smoothing polygons tooooo much????
Thread: WalkDesigner and high heels problem!!!! | Forum: Poser - OFFICIAL
Thread: newbie question!!!! | Forum: Poser - OFFICIAL
I have to say just thanks and thanks. rtesponse time around 8 minutes!!!!! thats why renderosity kicks! thanks everybody out there!!!!
Thread: Poser avi to 3dsmax 3.1 | Forum: Poser - OFFICIAL
From what I know at least the maximum pose, works like this: it takes the file (pz3) and the animation that is included and it transforms it in a series of obj objects in order to import them in 3DsMax. How can I use the bvh file, can it be transformed with the character studio? And something else If I have to use Maximum pose how many polygons does the posette and the p4 man have?
Yes I know about PPP but I wonder whether there is a another much simplier way to do this without the need of an application! (after all I can't just spend 99USD for the full program!
Thread: AAAArgh my nerves......!!! | Forum: Poser - OFFICIAL
well actually it worked by using the application mentioned earlier but I think your way is correct too! Thanks!
Thread: Animated clothing??? | Forum: Poser - OFFICIAL
well actually you can buy him from zygote (like victoria!) but if you can' t afford him(!?!) just use th P4man!
well it needs some time and effort but it pay back! first take a front-face picture of your self (remebmer don't smile!)then open the texture file which you will use for mapping the skinhead of your model (if you are using Michael the texture file for the head is separate from the skin body texture file!) make sure you scan your photo in big analysis because the texture files for poser are rather big! For that job (changing heads!) I use photoshop but I think you can do this with any other program! (if you have dificulties tell there tell me) After all that you are half way there! you need to morph the model's head to look a bit like you! At this part download some morphs at morphworld if you use the poser man model (if you use Michael just search a little bit around to find some!) after that take a good look at your self and start modeling and morphing! Well these few words for now, if you want some extra help tell so and I'm sure a bunch of people will help you (including me of cource!) Happy rendering!
Thread: P4Fem Gillian model (modified from Dave's "Looks Like Gillian..." model) | Forum: Poser - OFFICIAL
well the texture is a 10+ and thanks Dave for his work! Your model needs a little work more ot the nose. Because you use the P4 fmodel there is a lack to face morphs! download a few from bushi (or something I can't remember!) and you'll have a great model! (her upper lip needs a little work too!)
Thread: Gimme you best shot | Forum: Animation
Thread: Creating Morph Targets with MAYA problem!!! | Forum: Poser - OFFICIAL
